SFCfix repair issues. Please help, Thxs
terence
My lenovo laptop is having problem and have spent 4 days on it. Through different sites, I come across your great tool and have ran it. Attached is the log and I do not have the disk to repair the corrupted registry files. I did save the entire image in a backup drive but failed to make the CD for the registry, my bad!
The laptop is crashing due to 100% disk usage which slow every down. I also think I was hit by virus and have corrupted the registry which is causing window explorer crashing. So i think i need to repair the registry and then due with the 100% disk and any virus remnant. This virus have caused my 360 having problem (not running).
Since I am sending this via another computer, I will try to use your other method to upload large CBS file. i hope that procedure will be able to upload via a flash drive. Thank you again and I hope you can help me to restore order! Very frustrating! Much obliged.
P.S. I have uploaded the CBS file (7MB) per your instruction with the two files on desktop. I hope you can find it because I did not see any log about the upload!
Before we fix your Windows Update/Servicing issues I feel it is important for you to get your machine checked out for malware in our security section. Please start a new thread in our Security forum.
In the subject please put "WU Thread 19997 - For BrianDrab". Information on what else to post is here.
As I'm qualified for malware removal, I'll pick up the thread. We'll ensure you are clean then come back here to finish up any remaining Windows Update/Servicing issues.
