Captain77450
- May 27, 2020
- 3
I have a Windows 7 Ultimate x86 with SP1 using an SSD drive machine and SFC is not working on or offline (Always errors with ""Windows Resource Protection could not perform the requested operation" ") and I have tried every trick to fix W7 updating. I am a 20 year tech and this is my machine. I have tried a recovery overwrite of windows and it always fails and tells me to reboot and try again. The Windows overwrite seems to have a pending update or file rename operation pending but I have worked for two days and pretty much exhausted the internet help on that. I get 80073712 error on trying windows updating everytime. I have chkdsked and run the MS update fix utility and the System Update Readiness tool without any joy. I have restored to earlier restore points and even used the registry backup folder to manually go back to the older registry files. I can boot to windows and have malwarebyte'd and Hitman Pro'ed it. I have cleaned the registry with two different tools without success. I used Tweaking.com's Windows Repair 4.8.0 fixing and still no change. So bottom line is I need to SFC my windows files and fix the Windows Updating function and probably a overthetop Windows reinstall. I believe it is clean but Running Sophos Malware scan now. PLEASE HELP ME B 4 I TAKE A DIRT NAP!!
Does MS have a rule to NOT let anyone overwrite install Windows 7 anymore?
So I tried SFCFix and the log file is:
Start time: 2020-05-27 18:35:55.791
WARNING: Components hive failed size test and may be corrupt.
SURT total detected corruption count: 1
Failed to process registry database in location 2 with error code ERROR_FILE_NOT_FOUND.
WARNING: Failed to process registry database in location 3 with error code ERROR_INVALID_HANDLE.
Failed to process registry database in location 4 with error code ERROR_INVALID_HANDLE.
Failed to process registry database in location 4 with error code ERROR_FILE_NOT_FOUND.
Finish time: 2020-05-27 18:38:12.017
CBS log zip at : CBS.zip
