[SOLVED] [SFC] Need help fixing corrupted files
Primajin
Hi Guys, i have some corrupted files causing BSOD and crashing Programs on my Win 8.1 Pro x64 - and I heard that you awesome guys provide help to fix them?
Appreatiate your help and many thanks in advance.
Lennart
That's quite a few corruptions. I need a current log so if you could do the following it would be greatly appreciated.
  1. Right-click on the Start
  3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post:
    C:\Windows\Logs\CBS\CBS.log
Thanks for looking into the logs.
I always get error 0x800f0906 which google tells me has something to do with .net Framework 3.5
I tried reinstalling it, changing group policies, disabling KB2966826 KB2966827 and KB2966828, and enabling via dism (Dism /online /enable-feature /featurename:NetFx3 /All /Source:G:\sources\sxs /LimitAccess)... but no succes so far.
I will attach cbs and dism logs anyway.
Thanks
Lennart
View attachment logs.zip
Good. We may need that. Please do the following.
Step#1 - SFCFix Script
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-05-30 20:22:01.845
Using .txt script file at D:\Downloads\Downloads\SFCScript.txt [0]
Trace::
Successfully traced component amd64_038598ac7f1b44215b57a32af3cbef6e_b77a5c561934e089_4.0.9600.17187_none_720f0467ecbe2156.
Package_2_for_KB2934501~31bf3856ad364e35~amd64~~6.3.1.1.2934501-86_neutral_GDR2
Successfully traced component amd64_0392bf6cc0b3d55e2556095d8554de0d_b77a5c561934e089_4.0.9600.17187_none_f59b3728df40898d.
Successfully traced component amd64_03c3cbc4e1132dd877d005ba98db56a5_b77a5c561934e089_4.0.9600.20681_none_55604487e5f7c7d0.
Successfully traced component amd64_06e32e9d6eebc5a54ea3fe369bec232b_b03f5f7f11d50a3a_4.0.9600.20681_none_71d0cc46cd762fba.
Successfully traced component amd64_0825943d8fc95ed7321c12689b636e69_b77a5c561934e089_4.0.9600.20681_none_bf2b2d6b323f0f41.
Successfully traced component amd64_0a37ac72db9ce42cbc44b1c30914a33d_31bf3856ad364e35_4.0.9600.17187_none_7762559d4aad94a3.
Successfully traced component amd64_0c777537217aeb33077c27488f8435a3_b03f5f7f11d50a3a_4.0.9600.17187_none_4c794ff09a017b45.
Successfully traced component amd64_0ed2aa387067baab0b6d9dbc1351499b_b77a5c561934e089_4.0.9600.17187_none_72c123e88fb73d3c.
Successfully traced component amd64_17d445112f9ad940423bb2679dd0f1c9_31bf3856ad364e35_4.0.9600.17187_none_294dd1744c062a44.
Successfully traced component amd64_18be3390712d43f5360f059d3455a399_31bf3856ad364e35_4.0.9600.20681_none_c5a663a009c439b8.
Successfully traced component amd64_219b5ea166927a84a31866bec30bd46f_b03f5f7f11d50a3a_4.0.9600.20681_none_134fb101731ffc52.
Successfully traced component amd64_240b1012d07e06dfd2e390e172a6c638_b77a5c561934e089_4.0.9600.17187_none_61e7206e3cfdfc41.
Successfully traced component amd64_2a86a68ee72102ee7284f5c1c28b4352_b77a5c561934e089_4.0.9600.20681_none_5eb885f59dd751ba.
Successfully traced component amd64_31383fe8eb0c764b97fa8b33bafc2f67_b77a5c561934e089_4.0.9600.17187_none_85eee44222e92382.
Successfully traced component amd64_3384d8a82a3e5d2074614c25711afd1c_b77a5c561934e089_4.0.9600.17187_none_a3ab12c8e9d2f653.
Successfully traced component amd64_3771f5f76b168db51e416fdac89a89f6_b03f5f7f11d50a3a_4.0.9600.17187_none_911ed289d9f3f0ca.
Successfully traced component amd64_38edb476e6032d75fc09f46f3f167a8f_b77a5c561934e089_4.0.9600.20681_none_8ac9880c362c65c4.
Successfully traced component amd64_3d9c1db179cedafe5c61db8e1ab431fa_b77a5c561934e089_4.0.9600.20681_none_3a2b25f7b76c4fcb.
Successfully traced component amd64_3e317113f6e5318cada3ad05771c6340_b03f5f7f11d50a3a_4.0.9600.17187_none_78311a2591921e81.
Successfully traced component amd64_3e4e127c83f6d7a525b3006e7b861d03_b03f5f7f11d50a3a_4.0.9600.17187_none_50dd35791ff879a8.
Successfully traced component amd64_445e32f37f4d0449d35a0df1107a4955_b77a5c561934e089_4.0.9600.17187_none_fdaecd7d93a0e316.
Successfully traced component amd64_45112dac8ed88bd540481ae6740ed5c5_31bf3856ad364e35_4.0.9600.20681_none_b720c5d98de60cc0.
Successfully traced component amd64_45b6a286b27affb1f0a1cccf60ad6012_b77a5c561934e089_4.0.9600.20681_none_2153c6c5dabf6001.
Successfully traced component amd64_47ad22fb7657fe43896db7ff9e7ef56e_31bf3856ad364e35_4.0.9600.20681_none_e687c4ec7ab302a6.
Successfully traced component amd64_48e00dbb86401c2171f49c50408d0ced_b77a5c561934e089_4.0.9600.20681_none_ad7e4e9aed0dd7f6.
Successfully traced component amd64_519f3189f6d6ab46a2533c2e66c6ae62_b03f5f7f11d50a3a_4.0.9600.20681_none_0e2c8e7c96a69565.
Successfully traced component amd64_521da7c608d743d40a9236e380d0f547_31bf3856ad364e35_6.3.9600.20681_none_5451c5e1d758023c.
Successfully traced component amd64_5422137ef1f3cab335b4afc1ed85b654_31bf3856ad364e35_4.0.9600.17187_none_494097284f36c60c.
Successfully traced component amd64_5610ba82807113e68939f29099404793_31bf3856ad364e35_4.0.9600.17187_none_7759e5fbb57b5ca5.
Successfully traced component amd64_644a9c742a07dd2de722e4ddd62592c8_31bf3856ad364e35_6.3.9600.17187_none_c64464eeef0a4bf5.
Successfully traced component amd64_655fa0a75df5d0ce6ffb7cdb6d30141e_b03f5f7f11d50a3a_4.0.9600.20681_none_7d6b3a61b779a7ec.
Successfully traced component amd64_668a9aa5f4bfc9f074bc27d6bfe52b7d_b03f5f7f11d50a3a_4.0.9600.17187_none_6ca36d56a79191bd.
Successfully traced component amd64_6b463b68c362b0ed29a72d2fec251793_31bf3856ad364e35_4.0.9600.17187_none_408a17865a79e9ca.
Successfully traced component amd64_6e668ebbd3011149f4a245725a17a4e3_31bf3856ad364e35_4.0.9600.17187_none_aa95f8e8c0407e1d.
Successfully traced component amd64_6ed47f00a21030df5a4e67d8435194b7_31bf3856ad364e35_4.0.9600.20681_none_af0fc290c2e9af95.
Successfully traced component amd64_6f06f8d1762a932e6a4d4b2dec52a114_31bf3856ad364e35_4.0.9600.20681_none_f1d0355019103f76.
Successfully traced component amd64_70fa28fe435616c602857b675c335f1f_b77a5c561934e089_4.0.9600.17187_none_a22362fd006e86ae.
Successfully traced component amd64_723ed8a70d89a1e9bc2ac792f502d0c3_b77a5c561934e089_4.0.9600.17187_none_10e6c3a2eb63f98c.
Successfully traced component amd64_740db2a60db059308a9ce2b9dd3df74e_b77a5c561934e089_4.0.9600.20681_none_bdf869dc9a92c5d0.
Successfully traced component amd64_747c7f036da6bd201b143bf847cc8ea5_b77a5c561934e089_4.0.9600.20681_none_273c12de2dad344c.
Successfully traced component amd64_79622522f760b41600e863e95fbc61e4_b03f5f7f11d50a3a_4.0.9600.20681_none_3b531b572691060c.
Successfully traced component amd64_888f4fd0b0f5e6b32c06557945f034a8_b03f5f7f11d50a3a_4.0.9600.17187_none_0af72a519240a32f.
Successfully traced component amd64_8c25f7bc5a054b291b312dc88a795651_b77a5c561934e089_4.0.9600.17187_none_1c82b2eb0ebf19c2.
Successfully traced component amd64_8d38c70376375accdf36de89e0fd2889_b03f5f7f11d50a3a_4.0.9600.17187_none_47f3ce1205c2db64.
Successfully traced component amd64_8f0f78764ec7de1c55b22bdc6a339a91_b77a5c561934e089_4.0.9600.17187_none_fbbe1c462bd4d4f6.
Successfully traced component amd64_91bde1bc40b052ad2fed75b59bef6bed_b03f5f7f11d50a3a_4.0.9600.20681_none_627700dc3bdba625.
Successfully traced component amd64_9aecbd48f86efb55f21b76b5fdf0a852_31bf3856ad364e35_4.0.9600.17187_none_f68fca686f691f2a.
Successfully traced component amd64_a56ddeeb5ebee64324b9e3963f1e98ea_31bf3856ad364e35_4.0.9600.20681_none_7438d927aa17a2a0.
Successfully traced component amd64_a83ea304aac4bc8cefa92fc5b64d1a87_b77a5c561934e089_4.0.9600.20681_none_59cfcb097bb7adbb.
Successfully traced component amd64_a93eec2184c0900752d8fc7937508dd4_b77a5c561934e089_4.0.9600.17187_none_eda731b58a582cf3.
Successfully traced component amd64_b290ff91dd1bda773bdfbf96bbb0f443_b77a5c561934e089_4.0.9600.17187_none_fbb4a00b97fe9364.
Successfully traced component amd64_b755a43471271ab86b0a9dfad645bd4c_b77a5c561934e089_4.0.9600.17187_none_9715cc36d67950c5.
Successfully traced component amd64_bac81a399283afc2e4746893de5b5a57_b77a5c561934e089_4.0.9600.20681_none_37e8ba4dc78dcea5.
Successfully traced component amd64_ca3e3c407f5121d1a2530b3e50f7e5ed_b03f5f7f11d50a3a_4.0.9600.20681_none_2d46aa25167d9012.
Successfully traced component amd64_ca4b30200e497d35411aaeb0352db4b8_b03f5f7f11d50a3a_4.0.9600.20681_none_b1fc198f3173490a.
Successfully traced component amd64_cafa3801e8007d987ea7dab421e136cf_b03f5f7f11d50a3a_4.0.9600.20681_none_44e13273bc3791d1.
Successfully traced component amd64_cd9c31d5325b11955f2b5e07482fb130_b77a5c561934e089_4.0.9600.20681_none_75bb9b9cc7bd1601.
Successfully traced component amd64_d1f81e3347d6952619743917c54a2bc6_31bf3856ad364e35_4.0.9600.17187_none_cbb03e9340afa4b9.
Successfully traced component amd64_d2c38ead3bc6e4ba13077aaffb455d0e_b77a5c561934e089_4.0.9600.20681_none_34cff734b1c2a1f6.
Successfully traced component amd64_d2cd4129c32059820e554cf0a89fddae_b03f5f7f11d50a3a_4.0.9600.17187_none_191f0598c105c9ab.
Successfully traced component amd64_d4d8167411cc2f7f424e8e4f80b985dd_b77a5c561934e089_4.0.9600.20681_none_843d244ed8b9f36a.
Successfully traced component amd64_d6b7c0c42e6fbaddf6cfd8e077cacd2a_b03f5f7f11d50a3a_4.0.9600.17187_none_635e9b6aa5820c23.
Successfully traced component amd64_d7aeb586f13c5973fb3b81210c02ba7d_31bf3856ad364e35_4.0.9600.20681_none_607523b411e3c8f4.
Successfully traced component amd64_d855a9b0e38437cc2bd5e6bf7a8cd9d5_b03f5f7f11d50a3a_4.0.9600.17187_none_ab101d21ce0b0a03.
Successfully traced component amd64_e406a573aca57cae1d800b154f6e4d3b_b03f5f7f11d50a3a_4.0.9600.17187_none_80409edd889e88e8.
Successfully traced component amd64_e440e7e7e85743fe904e732b3bce04d8_b03f5f7f11d50a3a_4.0.9600.20681_none_7dfecb77894e07fa.
Successfully traced component amd64_e5b44c32df7d99e50d8be336a4703c22_b77a5c561934e089_4.0.9600.20681_none_96513a6183434ab7.
Successfully traced component amd64_e839f667ff90020e591710cf80b24216_b03f5f7f11d50a3a_4.0.9600.20681_none_ef9133e020f25750.
Successfully traced component amd64_ec27af5936ccc3ed06204e79d64ad549_31bf3856ad364e35_4.0.9600.20681_none_30db86baed5bdbe9.
Successfully traced component amd64_edfda5755f8fa2439a53083ea2b74514_31bf3856ad364e35_4.0.9600.20681_none_2530033f96127429.
Successfully traced component amd64_ef2d74c6ee6a3105216ce8b0cf0bcad4_b77a5c561934e089_4.0.9600.17187_none_89ce871b85299cfb.
Successfully traced component amd64_f07827d4f9b95f9860612c4f4383ec89_b77a5c561934e089_4.0.9600.20681_none_15cf509f40de2776.
Successfully traced component amd64_f32578ebcfbc80c9ac2a31a3492ffbd2_31bf3856ad364e35_4.0.9600.17187_none_d4bcd2f7f093e6f6.
Successfully traced component amd64_fd550ddbdad3394f2bdb2a9abbe714d4_b03f5f7f11d50a3a_4.0.9600.17187_none_29d4f59c93ac35bc.
Successfully traced component amd64_fd8b4e006a941da0e81e4be7c3c327ed_b03f5f7f11d50a3a_4.0.9600.20681_none_458b563b73a887bf.
Successfully traced component amd64_fef28b64ed2477e5a0cac59bd7ae9ec0_b77a5c561934e089_4.0.9600.17187_none_32f277f341e54844.
SFCFix version 2.4.3.0 by niemiro has completed.
Finish time: 2015-05-30 20:22:06.346
Script hash: iwWYdXwb/5PcyaMjVy8TwK2c7+x/D3wyomGZZUbdd/Q=
So when you go to Programs and Features is your .NET Framework currently enabled (with the dot inside the checkbox) or disabled (clear checkbox)?
SFC Scan with Log
After reviewing your logs, your corruption is too extensive to try and fix manually. It will be quicker to do a repair install. You will not lose any data when doing a Repair Install. You will have to run Windows Updates and get all the updates that are lost but your data/programs will be intact. You should still ensure you have a backup of all your data before doing this. There are many articles on doing the repair install. A very good one follows.
https://www.winhelp.us/repair-your-computer-in-windows-8.html
