EXCELSIOR
- Feb 6, 2021
- 11
here are the files
OS Name: Microsoft Windows 10 Pro
Version: 10.0.19042 Build 19042
OS Manufacturer: Microsoft Corporation
System Manufacturer: MSI
System Model: MS-7721
System Type: x64-based PC
GPU: Nvidia Geforce GTX 750 TI
Processor: AMD A8-7680 Radeon R7, 10 Compute Cores 4C+6G, 3500 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date: American Megatrends Inc. V8.5, 01/11/2018
SMBIOS Version: 2.8
BIOS Mode: Legacy
BaseBoard Manufacturer: MSI
BaseBoard Product: A68HM-E33 V2 (MS-7721)
BaseBoard Version: 9.0
Platform Role: Desktop
Installed Physical Memory (RAM) 16.0 GB
BRIEF:
-I use the "MediaCreationTool20H2.exe" from Download Windows 10
-After I got the ISO from the MediaCreationTool20h2, I use "Rufus 3.13" Rufus - The Official Website (Download, New Releases) to make it bootable. But then I still get the same problem.
-Then I just tried to use CMD to make a bootable usb device, because maybe rufus is the one corrupting the OS installation but its not.
Start time: 2021-02-07 12:24:47.003
Microsoft Windows 10 Build 19042 - amd64
SFCFix version 3.0.2.1 by niemiro has encountered an unhandled exception.
Finish time: 2021-02-07 12:26:40.957
[[ CBS LINK LOG ]]
CBS.log
[[ CBS Persist Link LOG]]
CbsPersist_20210206072439.log
SMBIOS Version: 2.8
BIOS Mode: Legacy
BRIEF:
- What was original installed OS on system?
-Windows 10 Pro
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
-I have no idea
- Age of system? (hardware)
-Almost 2 yrs, I think.
- Age of OS installation?
-New
- Have you re-installed the OS?
-Yes
-I have no idea
- Is driver verifier enabled or disabled?
-I have no idea
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)
-None, only Windows Defender
- Are you using proxy, vpn, ipfilters or similar software?
-None
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)
-None
- Are you currently under/overclocking? Are there overclocking software installed on your system?
Yes, its been on OC before but I've been having BSOD, but now OC is on Default.
[[ CBS LINK LOG ]]
CBS.log
