Rollback problem with KB3147461
Hi PetrSavelev :)
Sorry for the delay, do you still need help with this issue?
Alright :) Let's start with a SFC scan (I don't see one in your CBS folder).
System File Checker (SFC)
    Run as Administrator
It's not bad, it's just that it doesn't contain the information I'm looking for, like the CBS.txt you just submitted :( The CBS.log is very volatile, so I need you to upload it as soon as the SFC scan is over. Can you try again?
Thank you, the log contained a SFC scan trace. Since it's clean, let's see if DISM have anything to report instead.
DISM - Fixing Component Store Corruption
Follow the instructions below to run a DISM operation on your system.
  • Let the scan run until the end (100%). Depending on your system, it can take some time;
  • Copy the C:\Windows\Logs\DISM folder and C:\Windows\Logs\CBS\CBS.log file on your Desktop, then right-click on it, go to Send to... and select Compressed .zip archive;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
Note: Please note that the CBS.log is volatile, which means that if you don't upload it after the DISM scan is completed, it won't contains the information from the scan anymore. So archive it and upload it as soon as you can.
Alright so DISM also returned clean logs.
Can you tell me what the exact issue is with the KB you are trying to install?
