[SOLVED] Reset to device, \Device\RaidPort1, was issued.
Keciak
  • A brief description of your problem (but you can also include the steps you tried)
  • Reset to device, \Device\RaidPort1, was issued. im plagued by this error. whenever it happens my pc black screens and freezes. I can only unlock it by : turning the PSU off, turn it back. my pc immediately restarts with diod on motherboard red for CPU. I restart by using the power button - diod red on motherboard again. second restart and at this point the pc is back to usable- for how long it is very random I had a period of 10 hours yesterday working perfectly and today 2 restarts in 2 days.
I tried:
First of all we need to change "AHCI Link Power Management" which is a hidden setting on power management. Open up registry editor and change the following settings.
HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\0012ee47-9041-4b5d-9b77-535fba8b1442\0b2d69d7-a2a1-449c-9680-f91c70521c60
Change attributes from 1 to 2
HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\0012ee47-9041-4b5d-9b77-535fba8b1442\dab60367-53fe-4fbc-825e-521d069d2456
And again change Attributes from 1 to 2.
Now go to Control Panel -> System and Security -> Power Options click on "Change Plan Settings" and then click on "Change advanced Power settings".
Now under "Hard disk" you should have AHCI Link Power Management - HIPM/DIPM and AHCI Link Power Management - Adaptive options.
Change "AHCI Link power management" To active, which means there is no power management for AHCI and finally change Adaptive to 0 milliseconds (Although if you enabled "active" this option has no effect).
Finally under "PCI Express" Change "Link State Power management" to OFF.
I also turned off in the "hard disk" setting - turn of hard disk after: never
I did download the xraid2 utility and updated my main samsung drive to setting in bios today and the error stills persists.
I did install windows 11 and 10 on both my drives (1tb samsung and 1tb kingstone) same issue happening. I tried with 2 different motherboards (gigabyte aorus master x870e and msi x670e elite tomahawak), with 2 different sets of ram and 2 different processors (ryzen 9 9950x3d box and ryzen 7 9800xd3)
  • System Manufacturer: msi MAG X670E TOMAHAWK WIFI
  • Laptop or Desktop? Desktop
  • Exact model number (if laptop, check label on bottom) n/a
  • OS ? (Windows 11, 10, 8.1, 8, 7, Vista) - both windows 11 and 10
  • x86 (32bit) or x64 (64bit)? x64
  • (Only for Vista, Windows 7) Service pack?
  • What was original installed OS on system? windows 11
  • Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? purchased from retailer
  • Age of system? (hardware) newborn except for ssd's nvme
  • Age of OS installation? newborn
  • Have you re-installed the OS? many times
  • CPU : amd ryzen 7 5800x3d
  • RAM (brand, EXACT model, what slots are you using?) Kingston fury 32gb (2x16gb) CL40 5200mhz beast black (not overclocking)
  • Video Card : Gigabyte GeForce RTX 5080 Gaming OC 16GB GDDR7 256bit DLSS 4
  • MotherBoard - msi x670e elite tomahawak
  • Power Supply - Gigabyte Aorus P1200W 80+ Platinum Modular
  • Is driver verifier enabled or disabled? - i think disabled? its the first time i hear about it
  • What security software are you using? windows defender
  • Are you using proxy, vpn, ipfilters or similar software? nope
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) nope
  • Are you currently under/overclocking? Are there overclocking software installed on your system? - nope
  • bios installer 7E12v1H https://pl.msi.com/Motherboard/MAG-X670E-TOMAHAWK-WIFI/support
I just installed the amd chipset drivers but when booting up my pc this error shows up again.
I'm also getting several errors of this type when booting up my pc
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
Windows.SecurityCenter.SecurityAppBroker
and APPID
Unavailable
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
System Information > Problem Devices:
AMD Radeon(TM) Graphics PCI\VEN_1002&DEV_13C0&SUBSYS_7E121462&REV_CB\4&38E43222&0&0041 This device is disabled.
Not Available ACPI\AMDIF031\0 The drivers for this device are not installed.
Not Available ACPI\AMDIF031\2 The drivers for this device are not installed.
Network Controller PCI\VEN_14C3&DEV_0616&SUBSYS_061614C3&REV_00\8&8DE8AFB&0&002000400011 The drivers for this device are not installed.
RAID Controller PCI\VEN_1022&DEV_43BD&SUBSYS_10621B21&REV_01\6&1ADCE5FD&0&00680011 The drivers for this device are not installed.
Generic Bluetooth Adapter USB\VID_0E8D&PID_0616&MI_00\9&13C806E8&0&0000 This device is disabled.
RAID Controller PCI\VEN_1022&DEV_43BD&SUBSYS_10621B21&REV_01\8&24E8DFC&0&006800400011 The drivers for this device are not installed.
Not Available ACPI\AMDI0101\0 The drivers for this device are not installed.
Not Available ACPI\AMDI0204\2&DABA3FF&0 The drivers for this device are not installed.
Not Available ACPI\AMDI0052\2&DABA3FF&0 The drivers for this device are not installed.
Thanks. I'm gonna have a look in the morning if I'm able to install the drivers. Any advices to what device look at? I believe it is related to my hard drive, but I might be mistaken
I really worry when people start troubleshooting by implementing registry hacks. From where did you get the advice to do that - and make those other config changes?
Those devices missing drivers look to be chipset related to me. Open Device Manager and post a screenshot of that window.
Sorry forgot to quote you
You didn't answer @ubuysa, question: I really worry when people start troubleshooting by implementing registry hacks.
i attached a link with the first screenshot on the guide how to fix my issue. please see here 1000002077.webp
@ubuysa, didn't tell you to seek out solutions on the web and try to fix it your self.
Also pls remember the rules of this forum, to be nice and gentle to other people. You're getting passive aggressive cause you didn't read my answer properly and because you cannot read that I'm supposed to provide all the things I tried before addressing this forum and generating the zip file with my pc data.
Which I all did.
So with all due respect, please let's be nice to each other :)
@ET_Explorer please read previous posts carefully before responding. @Keciak did inform us of the website the mentioned registry changes in the first posts were from and said these registry changes were done BEFORE coming to us.
Also @Keciak, no need to quote someone's post that's just above your own post, unless you want to respond to a specific portion. Ubuysa should receive notifications about new posts in this thread whether you do quote a post or not :-)
Getting back to the Device Manager output, there are several devices listed there that are missing drivers. You need to sort those out before doing anything else. From that Device Manager output, and the list of problem devices that were referenced in post #4, it's clear that you are missing some important drivers.
I understand the desire to help yourself, I also understand the urge to implement 'solutions' that you found on the web, but until you get all the correct drivers installed anything else you try is likely wasted effort.
Hi Ubuysa. This is where I'm coming to you for help. I tried everything to install them but this seems to be an impossible task to find them. I updated the bios before running the pc for the first time and I installed the AMD chipset drivers for windows 10. I cannot find anything else...
Thanks ET explorer.
Network controller was easy to install, raid controller is a harsh matter and it doesn't have an installator built in.
I decided to call the informatic services nearby my place and they told me to try with another PSU because with everything I have already done and swapped within hardware since I started getting those issues, it seems the PSU might be unstable and cause those crashes on my motherboard.
Going to receive one on Friday and I will let you know how does it go (my new PSU was doing strange noises from the beginning that I'm not used to hear with psu's in general like popping noises)
