[SOLVED] Request for sfc Help 12-21-16
DrJoeSanDiego
Active member
re: Request for sfc Help 12-21-16
sfc /SCANNOW
Wow.
The last fix lasted a LONG time (I last asked for sfc Help in April 25, 2015).
I ran sfc /SCANNOW etc (eg, SURT), but
"Windows Resource Protection found corrupt files but was unable to fix some of them."
My System:
Operating System: Windows 7 Professional, 64-bit (Service Pack 1)
MoBo: Z87 FTW EVGA 141-HW-E877-KR
CPU: Intel Core i7-4771 CPU @ 3.50GHz
RAM: 8 Gb DDR3 1600Mhz DU Corsair
Graphics card-NVIDIA GeForce Experience, GTX 760-4096 MB, Dedicated VidMem: 2048 MB GDDR5
DirectX version: 11.0
Monitor: DVI-I to VGA Adaptor to KVM to Samsung
Virtual Machine(s)
OR:
Per Speccy:
Operating System
Windows 7 Professional 64-bit SP1
CPU
Intel Core i7 4771 @ 3.50GHz 38 °C
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 (9-9-9-24)
Motherboard
EVGA INTERNATIONAL CO.LTD 141-HW-E877 (SOCKET 0) 28 °C
Graphics
SyncMaster (1280x1024@60Hz)
4095MB NVIDIA GeForce GTX 760 (EVGA) 34 °C
Storage
931GB Western Digital WDC WD1003FZEX-00MK2 SCSI Disk Device (SATA) 33 °C
1863GB Seagate ST2000LM003 HN-M201RAD (USB (SATA)) 31 °C
Optical Drives
HL-DT-ST DVDRAM GH24NS95 SCSI CdRom Device
Audio
Realtek High Definition Audio
: Per Speccy as of December 21, 2016
:smile9:
Thanx again, DrJoeSanDiego.
OK, please start with the following.
SFC Scan
  1. Click on the Start
Please start with the following.
Step#1 - SFCFix Script
Start time: 2016-12-29 14:17:11.214
Using .zip script file at C:\Users\Admin Joe\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4 to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_10mbps_h264.mp4.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_MPEG2_HD_15mbps.mpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_1080_5sec_VC1_15mbps.wmv.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480i_5sec_6mbps_new.mpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480p_5sec_6mbps_new.mpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4 to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\Clip_480_5sec_6mbps_h264.mp4.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsat.wmv.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv to C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4\winsatencode.wmv.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini to C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv to C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Chrysanthemum.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Chrysanthemum.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Desert.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Desert.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\desktop.ini to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\desktop.ini.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Hydrangeas.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Hydrangeas.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Jellyfish.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Jellyfish.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Koala.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Koala.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Lighthouse.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Lighthouse.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Penguins.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Penguins.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\SampleRes.dll to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\SampleRes.dll.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Tulips.jpg to C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Tulips.jpg.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini to C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3 to C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3 to C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3.
Successfully copied file C:\Users\Admin Joe\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3 to C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3.
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsatmediasamples_31bf3856ad364e35_6.1.7600.16385_none_0b34d0642122c1c4
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Currently storing 47 datablocks.
Finish time: 2016-12-29 14:17:47.915
Script hash: 87Q3sXJVr+yk6HdAmFtnG/bBnmkQvRCn1Ivq4VsFa3k=
Excellent. Please do the following again.
SFC Scan
