Problems installing May CU with error 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING
Start the
  • Right-click on FRST64.exe and select "Run as administrator".
  • Press the Fix button.
Afterwards attempt to update again. If it fails attach a new copy of the CBS logs.
Step 1. Download
Step 2. Run the following DISM command but it will fail with Error 2: so please provide the new CBS logs for the next fix.
Step 1.
Step 2. Run the following DISM command and post the result. When completed successfully attempt to update again and post the result.
the DISM command was successfull. I got the following error after trying to update:
There were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x800736b3)
Please reboot the server first and attempt to update again. If it fails attach a new copy of the CBS logs.
Still the following error:
Please run the following DISM command and attach a new copy of the CBS logs.
Step 1. Start the
Step 2. Run the following DISM command and attach a new copy of the CBS log.
This looks good, no remaining warnings reported. So please try to update again and post the result.
Another error appeared:
There were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80073701)
Please provide a new copy of the COMPONENTS hive, it seems several RTM components are still missing.
Afterwards attempt to update again and attach the new CBS logs.
Unfortunatly still no luck, still assembly missing error:
Yes, we'll need to replace several keys to fix the remaining issues.
Step 1.
Step 2. Run the following DISM command it will fail with Error 2, so please attach the new copy of the CBS log to provide the next fix.
