Problems installing May CU with error 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING
prolannic
I have one 2022 Windows Server that is getting the error 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING
In CBS Log I found the following:
2025-05-22 08:37:18, Info                  CBS    Failed to pin deployment while resolving Update: Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~11.0.20348.2849.Internet-Explorer-Optional-amd64 from file: (null) [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2025-05-22 08:37:18, Info                  CBS    Failed to bulk stage deployment manifest and pin deployment for package:Microsoft-OneCore-OpenSSH-Common-Package~31bf3856ad364e35~amd64~~10.0.20348.3451 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
Attached you find the logs needed.
Hi @prolannic,
Upload your COMPONENTS hive.
Export CBS (Component Based Servicing) hive
  • Click on the Start button and type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
