Hi again, thanks for waiting. I did the procedure with the SFCFix.zip file you sent and got the following Post Reboot Corruption Detection report (I don't know what you mean by "put
tags around the log to break up the text):
Start time: 2022-03-16 09:15:02.530
Using .zip script file at C:\Users\frank\Desktop\SFCFix(1).zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_0bfc08bf3ea166ba\poqexec.exe
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-ole-automation-legacy_31bf3856ad364e35_6.1.7601.23452_none_3c774fa97936755d\olepro32.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\poqexec.exe
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.1.7601.23717_none_128f060d602cb356\Rules.System.Diagnostics.xml
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-l..istry-support-tcpip_31bf3856ad364e35_6.1.7601.23496_none_e478281935696fc1\tcpipreg.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_0bfc08bf3ea166ba\poqexec.exe to C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_0bfc08bf3ea166ba\poqexec.exe.
The file \\?\C:\Windows\WinSxS\x86_microsoft-windows-ole-automation-legacy_31bf3856ad364e35_6.1.7601.23452_none_3c774fa97936755d\olepro32.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini to C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv to C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\poqexec.exe to C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\poqexec.exe.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\desktop.ini to C:\Windows\WinSxS\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\desktop.ini.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\SampleRes.dll to C:\Windows\WinSxS\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\SampleRes.dll.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.1.7601.23717_none_128f060d602cb356\Rules.System.Diagnostics.xml to C:\Windows\WinSxS\amd64_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.1.7601.23717_none_128f060d602cb356\Rules.System.Diagnostics.xml.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini to C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3 to C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3 to C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3 to C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-l..istry-support-tcpip_31bf3856ad364e35_6.1.7601.23496_none_e478281935696fc1\tcpipreg.sys to C:\Windows\WinSxS\amd64_microsoft-windows-l..istry-support-tcpip_31bf3856ad364e35_6.1.7601.23496_none_e478281935696fc1\tcpipreg.sys.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\desktop.ini to C:\Windows\WinSxS\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\desktop.ini.
Successfully copied file C:\Users\frank\AppData\Local\niemiro\Archive\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\win7_scenic-demoshort_raw.wtv to C:\Windows\WinSxS\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\win7_scenic-demoshort_raw.wtv.
Successfully pended file for replace over reboot: \\?\C:\Windows\WinSxS\x86_microsoft-windows-ole-automation-legacy_31bf3856ad364e35_6.1.7601.23452_none_3c774fa97936755d\olepro32.dll
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_0bfc08bf3ea166ba\poqexec.exe
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_0bfc08bf3ea166ba\poqexec.exe
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\poqexec.exe
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\poqexec.exe
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.1.7601.23717_none_128f060d602cb356\Rules.System.Diagnostics.xml
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.1.7601.23717_none_128f060d602cb356\Rules.System.Diagnostics.xml
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-l..istry-support-tcpip_31bf3856ad364e35_6.1.7601.23496_none_e478281935696fc1\tcpipreg.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-l..istry-support-tcpip_31bf3856ad364e35_6.1.7601.23496_none_e478281935696fc1\tcpipreg.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802
Reboot:: directive completed successfully.
PostRebootCorruptionDetection::
No hash verification failures detected.
PostRebootCorruptionDetection:: directive completed successfully.
PostRebootRestorePermissions::
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-ole-automation-legacy_31bf3856ad364e35_6.1.7601.23452_none_3c774fa97936755d\olepro32.dll
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-ole-automation-legacy_31bf3856ad364e35_6.1.7601.23452_none_3c774fa97936755d\olepro32.dll
PostRebootRestorePermissions:: directive completed successfully.
Currently storing 18 datablocks.
Finish time: 2022-03-16 09:38:03.603
So I checked disk management and it still gives the error when I try to initialize the new disk. Did a reboot, and still no luck. I re-ran SFCFix and it reported that no corruptions were detected.
So, to summarize, any time I try something in disk management (on any drive), even just to check properties, I got the following error....
"The operation failed to complete because the disk management console view is not up-to-date. refresh the view by using the refresh task. if the problem persists close the disk management console, then restart disk management or restart the computer."
Followed by this error after trying any other command....
"An unexpected error has occurred. check the system event log for more information on the error. close the disk management console, then restart disk management or restart the computer."
Over the past several days I have been baffled by this issue. I have tried, in no particular order:
1. Rebooting in safe mode - no luck.
2. Running Windows start-up repair from original installation dvd - nope.
3. sfc /scannow - nada.
4. chkdsk - no.
5. command line diskpart, list volume, clean, automount etc. - zilch.
6. Tried plugging the new drive into my Window 10 machine and it works fine.
7. Works fine in my Linux machine.
8. When I plug in an older USB drive that I had not used in about a year. It works fine.
9. When I try any other new USB drive, either HDD or SDD, no joy.
10. Tried to update driver in device manager. Windows says the correct driver is installed.
11. Uninstall device and restart - nope.
12. MiniTool Partition Wizard found the drive and I could format and assign a drive letter, but it didn't stick.
13. Easus data recovery just started and hung.
14. Tried a system restore from a few days back - waste of time.
15. Checked UEFI bios settings - all good. Disabled fast boot - no help. Re-enabled fast boot.
16. Virus scans came up clean.
17. Windows troubleshooting under Hardware and Sound found problems, but could not fix them automatically.
18. Windows fixit tool - no fix.
19. command line clean all - hangs.
20. Disable USB power save setting in power options - no help.
21. Uninstalled a few old AV programs that might have left traces.
22. Tried Tweaking.com pro as administrator - no help there.
OK, so I was thinking about trying a windows upgrade reinstall from my original Win7 installation disk, but was really reluctant for fear of losing any programs and settings. I remembered somebody suggested uninstalling all the usb hub controller drivers worked for them. So I tried uninstalling one-by-one, but got some glitches like device manage quitting and I think one blue screen, so I gave up on that idea.
Then I tried uninstalling all the usb mass storage drivers. After restart, my external hard drives were gone! All NINE of them. Looked in device manager - gone. Looked in disk management - gone. Beads of sweat start forming on my forehead. I try looking in devices and printers. THERE they are. Tried troubleshoot on them, windows found but could not fix any problems. Again, MiniTool Partition Wizard located all the drives, but the drive letters were gone. Could assign new drive letters, but they wouldn't stick.
So I go back to devices and printers and for each did this:
- right-click on properties
- select hardware, disk drive
- select properties
- select change settings
- under driver tab
- select update driver
here, if you choose Search automatically for updated driver software, windows just says the correct driver is already installed. Instead select Browse my computer for driver software. Instead of using Search for driver in this location (I tried c:\Windows\System32\ include subfolders, it doesn't work), use Let me pick from a list of device drivers.
- check Show compatible hardware box. I my case in the Model window, there was one digitally signed disk drive.\
- no need to click on Have Disk
- just click on Next and BANG it works!
This procedure restored all my external usb hard drives, including the new one which was unrecognized before.
I hope this helps others who may have run into this problem. As I said, it seems to be an issue for a lot of people on all windows platforms, not just windows 7.
