Good Morning Everybody,
I have been struggling for the past few weeks with an issue with my Win7Ult 64bit install, I noticed some weeks ago that Updates were failing to install, and then I created a backup image (a trial in itself) and commenced an upgrade repair of the OS, it failed and rolled back stating it had failed to update, so I ran CHKDSK across the disks, then SFC /scannow both from inside windows and from the command prompt under the install/repair disc.
I was running 2xVelociraptors in Raid0 but purchased an SSD to replace them, I used Samsungs own software to transfer the OS onto the new drive and swapped them over.
I have re-run the SFC and read the log, and seen that there are multiple entries for bootres.dll and iesysprep.dll listed as corrupted.
Seeming I kept running into the issue, and after trying another 'upgrade' repair install and having the installation stall at 18% of expanding files, I searched for some more assistance and ran across Sysnative, so hopefully I get get further down the track and repair my OS.
I've run SFCFix as advised and here is the report:
SFCFix version 2.3.0.0 by niemiro.
Start time: 2014-07-20 01:12:39.093
SFC verification failure on file bootres.dll of component Microsoft-Windows-BootRes (amd64, version 6.1.7601.17514). Permissions may be damaged - attempting automatic repair.
Successfully repaired permissions and ownership on file C:\Windows\winsxs\amd64_microsoft-windows-bootres_31bf3856ad364e35_6.1.7601.17514_none_9d42c69298905ee5\bootres.dll and all associated hardlinks.
SFCFix version 2.3.0.0 by niemiro has completed.
Finish time: 2014-07-20 01:12:57.381
Script hash:
I have run SFCFix multiple times and the report is always the same.
I've also attempted to upload my CBS.zip, but it is 27mb so I have linked it
here
