Network connection not working
nestre
Well-known member
Hi there (sorry for my English, I'm from Barcelona)
I have three computers. two with windows 10 (I'll call them "A" and "B") and the other (I'll call them "C") with Mac OSX.
"A" can see the shared folders of "B"
"B" can see the shared folders of "A" and "C"
"C" can see the shared folders of "A" and "B"
The problem is that "A" cannot see the shared folders of "C". Apparently both windows 10 have the network settings configured in the same way, but "B" (windows) can connect to "C" (mac) and "A" (windows) cannot. When I try to create a network drive from "A" \\192.168.1.6\"name" it stays with the clock for a long time and does not enter.
Control Panel\All Control Panel Items\Network and Sharing Center\Advanced sharing settings\ File sharing is on, Discovery is on, Password protected sharing is off
any help please?
Is there something on the Mac that defines "trusted machines"?
My guess is that the Mac (C) is not allowing A to see it, while it is allowing B to see it.
On the mac there is nothing special defined for "B" I have brought home a Mac from a friend "E", I have tried to connect from both PC's and the same thing keeps happening. "A" cannot connect to "E" and "B" can connect to "E" We have also tested with a "D" laptop with windows 10 and it can connect perfectly to mac "C". So it seems that there is something in "A" that does not allow connecting to mac's.
The host has not been modified, I have checked it with computer B and it is exactly the same
Please make sure share links are without sign in.
Open event viewer.
Save the application and system events to the desktop.
Clear all of the event logs.
Run the Sysnative log collector.
@zbook try the link to see if it works for you now
I do not know if I have understood you correctly, I have cleaned: Application and System in the Event Viewer.
and then I have run the SysnativeBSODCollectionApp application again But, the result is the same
Waiting for the SystemInfo all the time
Hello again. Since I've wanted to change the system to an HD SSD for a long time, I think now is the time to do it. But I'm not going to do it by cloning. I want to install windows from the beginning and then the programs.
I hope that this way the network problem is solved
I'll tell you about it!
Installed new windows in "A" and can perfectly connect with mac "C". thanks anyway for the help
