[SOLVED] Need SFCfix Script For "Cannot Repair-Missing Atl90.dll" Issue
DKW3
Contributor
San Diego, CA
Hi Niemiro,
I'm a composer and use my windows pc linked to a mac to compose instrumental music for media. Since I did a "Langa" in-place upgrade, my installation of Microsoft Visual C++ 2008 x64 Redistributable 9.0.30729.4148 has had corrupted assembly issues, and along with a few other program bugs, mainly, my Office 2010 programs like Word and Outlook keep configuring themselves every time I click to open them.
Believe me, from the reinstalling "Office" and the many updates 3 times, reinstalling "Visual", to "Chdsk", "reimage", the "rereg" & "Sec" cmds, to "update readiness", I've tried EVERY other suggested online fix possible to no avail, and short of doing a clean reinstall of my Windows 7 Ultimate sp1 64, I'm at the end of my rope.
My PC is a rebuilt customized PC from what used to be a Dell XPS 400, and in light of coming back from my 1 year Dell nightmare, I guess I should be grateful that it seems to be only ONE issue, but STILL.
Could you please help me via a customized sfcfix script? the text of my last CBS sfc scannow log is attached
Thanks.
DKW3
Hello, and welcome to Sysnative!
There are certainly a couple of small file corruptions visible in the CBS.log. I'm hoping that they're the only problem here. There is another possible situation which is Windows Installer backing store corruption - that's the worst case scenario, because it's not repairable. Even if I had the computer in front of me, I wouldn't be able to fix that. So here's to hoping it's not that.
Regardless though, please run SFCFix without any script file to start off with, as given here, and post the contents here: https://www.sysnative.com/forums/windows-update/4736-windows-update-forum-posting-instructions.html
It performs various checks and makes sure there's nothing nasty going on before we get started with the repair.
Richard
Hi Richard,
Thanks for the quick reply.
I've posted the text of sfcfix results file below the dotted line, and every listed failure seems to point to a "permissions" issue, of which I would hope there's either an easy suggested solution, or a customized script that you can do to address the issue.
If the worst-case scenario is a clean reinstall, I can grudgingly handle that, but if it's something "Physically" wrong like the Motherboard, then I'm in a heap of trouble. So, fingers and toes crossed here, and thanks again.
DKW3.
SFCFix version 2.4.2.1 by niemiro.
Start time: 2015-02-08 12:40:17.959
Microsoft Windows Vista Service Pack 1 - amd64
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-37_neutral_LDR (x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_0c75cecbd9cc99b7 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-27_neutral_LDR (x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_1404c6f3a5f49cc6 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-29_neutral_LDR (x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_1111071830e533b8 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.Trigger_1 (x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned component Package_3_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-15_neutral_LDR (x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_6b7da006d4ae6c79) on component watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-31_neutral_LDR (x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_cc2627af2c0b1ed9 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-33_neutral_LDR (x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_de46448b15cf7905 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-39_neutral_LDR (x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_51d7b64e0bafd284 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-41_neutral_LDR (x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_6b6725a2e2633f09 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-43_neutral_LDR (x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_b408da0c92bad89b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-45_neutral_LDR (x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_2a5001d3b964f661 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_8ef2a591cf854256.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2.3008923-47_neutral_LDR (x86_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_8ef2a591cf854256) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_8ef2a591cf854256 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_8ef2a591cf854256.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_8ef2a591cf854256 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-47_neutral_LDR (x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_2027e4b722ec3ffb with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-49_neutral_LDR (x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_5f7f027d88009a5d with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-20_neutral_LDR (x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_25c2e92ae9fd4e1c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_0ad1ef7bae837858 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_06d5b225b1129be8 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_d15876cef80bf015 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_3578942800dac9c9 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_31756b9403638519 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_8c6b49e1121ec7d8 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_2e2702638a0225d2 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_8e9d85d110a9c28a with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_8f8b6419100fafa7 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_f0705f6c1af5bd7d with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_ee0813e01c7afaad with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_a9cd4da836142f51 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_a8eb7e3c36a4bf75 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_a6979398381b2b91 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_605b391652f8bddd with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_621bedd851ccb408 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_1e2207286b4d94d9 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_1d5498a46bcf53e9 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_79896ca379a7884c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_d61f8fee8736c136 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_33fa10e1941baf5b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_91429ae2a14998f9 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_900e751ca20c3791 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_8df1c23ca358cacb with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_49d21a9abce9c9dd with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_4635a948bf31a5a5 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_a0da702bce1d900a with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_a71aa49bca17b37b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.2981580-110_neutral_LDR (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_a74f47b7c9f0c1d6) on component watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_a6f49f51ca281e9f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_fe5e71bedb12b611 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_0132dc82d93c6177 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_63f8fc5be2f66578 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_b8ef85c0f56e894d with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_12afa43804ee37f6 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-35_neutral_LDR (x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_b3139bbd9a02ccad with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-18_neutral_LDR (x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_d8bd0d891ef42789 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_f67764cf47994bea.
CORRUPT: Failed to repair orphaned component Package_1_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2.2855844-1_neutral_LDR (x86_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_f67764cf47994bea) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_f67764cf47994bea with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_f67764cf47994bea.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_f67764cf47994bea with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-directshow-dvdsupport_31bf3856ad364e35_0.0.0.0_none_77fc207f1c02cf92.
CORRUPT: Failed to repair orphaned component value name not identified (x86_microsoft-windows-directshow-dvdsupport_31bf3856ad364e35_0.0.0.0_none_77fc207f1c02cf92) on component watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_2_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0.2706045-5_neutral_LDR (wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_d2a73ed262cf72b0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_0d2d241a2c0cc674.
CORRUPT: Failed to repair orphaned component Package_3_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0.2706045-7_neutral_LDR (wow64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_0d2d241a2c0cc674) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_0d2d241a2c0cc674 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_0d2d241a2c0cc674.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_0d2d241a2c0cc674 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-59_neutral_LDR (wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_eeefa822e30778b0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-51_neutral_LDR (wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_b9af3b8c4ee6f030 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-53_neutral_LDR (wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_9d904e1f5711ea83 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-55_neutral_LDR (wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_d27624ea784d345b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-57_neutral_LDR (wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_e3a72ac43e45fe47 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-61_neutral_LDR (wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_ea33c5cf6f5ed405 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-63_neutral_LDR (wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_22138a92b68c81ce with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_9f9491f93e7a804a with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b.
CORRUPT: Failed to repair orphaned component value name not identified (wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_5_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-25_neutral_LDR (wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_230397dce2ae373b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_2_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0.2706045-5_neutral_LDR (amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-vbscript_31bf3856ad364e35_0.0.0.0_none_c85294802e6eb0b5 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_02d879c7f7ac0479.
CORRUPT: Failed to repair orphaned component Package_3_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0.2706045-7_neutral_LDR (amd64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_02d879c7f7ac0479) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_02d879c7f7ac0479 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_02d879c7f7ac0479.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-scripting-jscript_31bf3856ad364e35_0.0.0.0_none_02d879c7f7ac0479 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-oobe-machine-ui_31bf3856ad364e35_0.0.0.0_none_e253bf5ee2386636.
CORRUPT: Failed to repair orphaned component Package_1_for_KB2534111~31bf3856ad364e35~amd64~~6.1.1.0.2534111-1_neutral_LDR (amd64_microsoft-windows-oobe-machine-ui_31bf3856ad364e35_0.0.0.0_none_e253bf5ee2386636) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-oobe-machine-ui_31bf3856ad364e35_0.0.0.0_none_e253bf5ee2386636 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-oobe-machine-ui_31bf3856ad364e35_0.0.0.0_none_e253bf5ee2386636.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-oobe-machine-ui_31bf3856ad364e35_0.0.0.0_none_e253bf5ee2386636 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-37_neutral_LDR (amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieinstal_31bf3856ad364e35_0.0.0.0_none_68946a4f922a0aed with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-59_neutral_LDR (amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ieframe_31bf3856ad364e35_0.0.0.0_none_e49afdd0aea6b6b5 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-27_neutral_LDR (amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_0.0.0.0_none_702362775e520dfc with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-29_neutral_LDR (amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-vgx_31bf3856ad364e35_0.0.0.0_none_6d2fa29be942a4ee with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_3_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.Trigger_1 (amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_0.0.0.0_none_c79c3b8a8d0bddaf with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-31_neutral_LDR (amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-lowreg_31bf3856ad364e35_0.0.0.0_none_2844c332e468900f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-33_neutral_LDR (amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_0.0.0.0_none_3a64e00ece2cea3b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-51_neutral_LDR (amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_0.0.0.0_none_af5a913a1a862e35 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-39_neutral_LDR (amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-impexp-extexport_31bf3856ad364e35_0.0.0.0_none_adf651d1c40d43ba with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-41_neutral_LDR (amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieshims_31bf3856ad364e35_0.0.0.0_none_c785c1269ac0b03f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-43_neutral_LDR (amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ieproxy_31bf3856ad364e35_0.0.0.0_none_102775904b1849d1 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-45_neutral_LDR (amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-ielowutil_31bf3856ad364e35_0.0.0.0_none_866e9d5771c26797 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-53_neutral_LDR (amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_0.0.0.0_none_933ba3cd22b12888 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-55_neutral_LDR (amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlediting_31bf3856ad364e35_0.0.0.0_none_c8217a9843ec7260 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_eb11411587e2b38c.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2.3008923-47_neutral_LDR (amd64_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_eb11411587e2b38c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_eb11411587e2b38c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_eb11411587e2b38c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlconverter_31bf3856ad364e35_0.0.0.0_none_eb11411587e2b38c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-57_neutral_LDR (amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-htmlapplication_31bf3856ad364e35_0.0.0.0_none_d952807209e53c4c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-47_neutral_LDR (amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feedsbs_31bf3856ad364e35_0.0.0.0_none_7c46803adb49b131 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-61_neutral_LDR (amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_0.0.0.0_none_dfdf1b7d3afe120a with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-63_neutral_LDR (amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_0.0.0.0_none_17bee040822bbfd3 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-49_neutral_LDR (amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-ie-devtools_31bf3856ad364e35_0.0.0.0_none_bb9d9e01405e0b93 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-20_neutral_LDR (amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_0.0.0.0_none_81e184aea25abf52 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-tw_66f08aff66e0e98e with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_zh-cn_62f44da969700d1e with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_uk-ua_2d771252b069614b with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_tr-tr_91972fabb9383aff with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_th-th_8d940717bbc0f64f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sv-se_e889e564ca7c390e with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sr-..-cs_8a459de7425f9708 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sl-si_eabc2154c90733c0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_sk-sk_eba9ff9cc86d20dd with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ru-ru_4c8efaefd3532eb3 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ro-ro_4a26af63d4d86be3 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-pt_05ebe92bee71a087 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pt-br_050a19bfef0230ab with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_pl-pl_02b62f1bf0789cc7 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nl-nl_bc79d49a0b562f13 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_nb-no_be3a895c0a2a253e with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lv-lv_7a40a2ac23ab060f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_lt-lt_79733428242cc51f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ko-kr_d5a808273204f982 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ja-jp_323e2b723f94326c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_it-it_9018ac654c792091 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hu-hu_ed61366659a70a2f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_hr-hr_ec2d10a05a69a8c7 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_he-il_ea105dc05bb63c01 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fr-fr_a5f0b61e75473b13 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_fi-fi_a25444cc778f16db with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_et-ee_fcf90baf867b0140 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_es-es_0339401f827524b1 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_en-us_036de33b824e330c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_el-gr_03133ad582858fd5 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_de-de_5a7d0d4293702747 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_da-dk_5d5178069199d2ad with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_cs-cz_c01797df9b53d6ae with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_bg-bg_150e2144adcbfa83 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..timezones.resources_31bf3856ad364e35_0.0.0.0_ar-sa_6ece3fbbbd4ba92c with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2.Trigger_1 (amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_0.0.0.0_none_953fe7a70a19be4f with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-35_neutral_LDR (amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..nternetcontrolpanel_31bf3856ad364e35_0.0.0.0_none_0f32374152603de3 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_5_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-25_neutral_LDR (amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_0.0.0.0_none_18aeed8aae4d7540 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf) on component watchlist.
CORRUPT: Failed to repair orphaned component Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0.3003057-18_neutral_LDR (amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_0.0.0.0_none_34dba90cd75198bf with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_52960052fff6bd20.
CORRUPT: Failed to repair orphaned component Package_1_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2.2855844-1_neutral_LDR (amd64_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_52960052fff6bd20) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_52960052fff6bd20 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_52960052fff6bd20.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite_31bf3856ad364e35_0.0.0.0_none_52960052fff6bd20 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_0.0.0.0_none_84a29f7d11d6e288.
CORRUPT: Failed to repair orphaned component Package_1_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2.2855844-3_neutral_LDR (amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_0.0.0.0_none_84a29f7d11d6e288) on component watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_0.0.0.0_none_84a29f7d11d6e288 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_0.0.0.0_none_84a29f7d11d6e288.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_0.0.0.0_none_84a29f7d11d6e288 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-directshow-dvdsupport_31bf3856ad364e35_0.0.0.0_none_d41abc02d46040c8.
CORRUPT: Failed to repair orphaned component value name not identified (amd64_microsoft-windows-directshow-dvdsupport_31bf3856ad364e35_0.0.0.0_none_d41abc02d46040c8) on component watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3012176~31bf3856ad364e35~amd64~~6.1.1.2 (WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (WinPE-Scripting-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (WinPE-HTA-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Foundation~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Explorer~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-IE-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2855844_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2 (WinEmb-Graphics-Platform~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2709981_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2709981~31bf3856ad364e35~amd64~~6.1.2.0 (WinEmb-AV-Core~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045_SP1~31bf3856ad364e35~amd64~~6.1.1.0 (WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (WinEmb-AppSupport-Legacy~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_114_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_74_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_109_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_4_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_2_for_KB3012176~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3012176_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3012176~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_110_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_2_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045_SP1~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_6_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_6_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045_SP1~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_5_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_5_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_1_for_KB2709981~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2709981_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2709981~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_4_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_4_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_2_for_KB3012176~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3012176_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3012176~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_110_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_109_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_2_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045_SP1~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2706045~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_1_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2855844_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2855844~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_1_for_KB2534111~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2534111_SP1~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2534111~31bf3856ad364e35~amd64~~6.1.1.0 (Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3008923~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_3_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057_SP1~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB3003057~31bf3856ad364e35~amd64~~6.1.2.0 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_109_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~hr-HR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~he-IL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fr-FR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~fi-FI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~et-EE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~es-ES~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~en-US~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~el-GR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~de-DE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~da-DK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~cs-CZ~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~bg-BG~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_113_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_39_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-FailoverCluster-Core-WOW64-Package~31bf3856ad364e35~amd64~ar-SA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-TW~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-HK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~zh-CN~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~uk-UA~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~tr-TR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~th-TH~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sv-SE~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sr-LATN-CS~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sl-SI~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~sk-SK~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ru-RU~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ro-RO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-PT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pt-BR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~pl-PL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lv-LV~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~lt-LT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ko-KR~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~ja-JP~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~it-IT~0.0.0.0) on package watchlist.
WARNING: Failed to backup registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580_SP1~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
Failed to set registry key intermediary ownership for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
Failed to import registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0.
Failed to restore registry key security information for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0 with error code ERROR_ACCESS_DENIED.
CORRUPT: Failed to repair orphaned package Package_for_KB2981580~31bf3856ad364e35~amd64~~6.1.1.2 (Microsoft-Windows-EmbeddedFoundation-Base-LanguagePack-Package~31bf3856ad364e35~amd64~hu-HU~0.0.0.0) on package watchlist.
