Earlier, I had ran CrystalDiskInfo to check the status of ssd, indicate Green, However not as through as this. The report is below. thanks
Attribute:
Screenshot
Statistic:
Screenshot
smartctl 6.6 2017-11-05 r4594 [x86_64-w64-mingw32-w10-b18362] (sf-6.6-1)
Copyright (C) 2002-17, Bruce Allen, Christian Franke,
www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: SK hynix SC311 SATA 256GB
Serial Number: MI7CN05341030CN6Q
Firmware Version: 70000P10
User Capacity: 256,060,514,304 bytes [256 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: M.2
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Nov 02 23:23:30 2019 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 2300) seconds.
capabilities: (0x51) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 40) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 0
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 166 166 006 - 0
5 Reallocated_Sector_Ct -O--CK 253 253 036 - 0
9 Power_On_Hours -O--CK 095 095 000 - 4836
12 Power_Cycle_Count -O--CK 100 100 020 - 2477
100 Unknown_Attribute -O--CK 100 100 000 - 1965133
168 Unknown_Attribute -O--CK 098 098 000 - 41
169 Unknown_Attribute -O--CK 094 094 000 - 106
174 Unknown_Attribute ----CK 100 100 000 - 128
175 Program_Fail_Count_Chip -O--CK 253 253 000 - 0
176 Erase_Fail_Count_Chip -O--CK 253 253 000 - 0
177 Wear_Leveling_Count -O--CK 096 001 000 - 69
178 Used_Rsvd_Blk_Cnt_Chip -O--CK 253 253 000 - 0
179 Used_Rsvd_Blk_Cnt_Tot -O--CK 253 253 000 - 0
180 Unused_Rsvd_Blk_Cnt_Tot -O--CK 100 100 000 - 780
181 Program_Fail_Cnt_Total -O--CK 253 253 000 - 0
182 Erase_Fail_Count_Total -O--CK 253 253 000 - 0
184 End-to-End_Error -O--CK 253 253 000 - 0
187 Reported_Uncorrect -O--CK 253 253 000 - 0
188 Command_Timeout -O--CK 253 253 000 - 0
194 Temperature_Celsius -O---- 035 021 000 - 35 (Min/Max 21/52)
195 Hardware_ECC_Recovered -O--CK 253 253 000 - 0
196 Reallocated_Event_Count -O--CK 253 253 036 - 0
198 Offline_Uncorrectable -O--CK 253 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 253 253 000 - 0
204 Soft_ECC_Correction -OSR-- 001 001 000 - 22367
212 Unknown_Attribute -O--CK 100 100 000 - 42204
233 Media_Wearout_Indicator -O--CK 005 001 000 - 96
234 Unknown_Attribute -O--CK 100 100 000 - 36037636240
241 Total_LBAs_Written -O--CK 100 100 000 - 36058730295
242 Total_LBAs_Read -O--CK 100 100 000 - 64076270929
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 4 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 2 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL R/O 8 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (2 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 4836 -
# 2 Short offline Completed without error 00% 3714 -
# 3 Extended offline Completed without error 00% 3426 -
# 4 Short offline Completed without error 00% 3425 -
# 5 Short offline Completed without error 00% 3425 -
# 6 Short offline Aborted by host 90% 3267 -
# 7 Short offline Completed without error 00% 3196 -
# 8 Extended offline Aborted by host 70% 2673 -
# 9 Short offline Completed without error 00% 2673 -
#10 Short offline Completed without error 00% 2245 -
#11 Short offline Completed without error 00% 2137 -
#12 Short offline Completed without error 00% 2137 -
#13 Short offline Completed without error 00% 1151 -
#14 Extended offline Completed without error 00% 93 -
#15 Short offline Completed without error 00% 92 -
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 1 (0x0001)
SCT Support Level: 0
Device State: Active (0)
Current Temperature: 35 Celsius
Power Cycle Min/Max Temperature: 30/42 Celsius
Lifetime Min/Max Temperature: 21/54 Celsius
Under/Over Temperature Limit Count: 50/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: -20/80 Celsius
Min/Max Temperature Limit: -20/125 Celsius
Temperature History Size (Index): 192 (2)
Index Estimated Time Temperature Celsius
3 2019-11-02 20:12 ? -
... ..( 17 skipped). .. -
21 2019-11-02 20:30 ? -
22 2019-11-02 20:31 31 ************
23 2019-11-02 20:32 ? -
... ..( 43 skipped). .. -
67 2019-11-02 21:16 ? -
68 2019-11-02 21:17 31 ************
... ..( 4 skipped). .. ************
73 2019-11-02 21:22 31 ************
74 2019-11-02 21:23 32 *************
... ..( 18 skipped). .. *************
93 2019-11-02 21:42 32 *************
94 2019-11-02 21:43 33 **************
... ..( 11 skipped). .. **************
106 2019-11-02 21:55 33 **************
107 2019-11-02 21:56 ? -
108 2019-11-02 21:57 ? -
109 2019-11-02 21:58 38 *******************
110 2019-11-02 21:59 37 ******************
111 2019-11-02 22:00 37 ******************
112 2019-11-02 22:01 37 ******************
113 2019-11-02 22:02 36 *****************
114 2019-11-02 22:03 35 ****************
115 2019-11-02 22:04 35 ****************
116 2019-11-02 22:05 35 ****************
117 2019-11-02 22:06 34 ***************
118 2019-11-02 22:07 35 ****************
119 2019-11-02 22:08 35 ****************
120 2019-11-02 22:09 35 ****************
121 2019-11-02 22:10 34 ***************
122 2019-11-02 22:11 34 ***************
123 2019-11-02 22:12 34 ***************
124 2019-11-02 22:13 36 *****************
125 2019-11-02 22:14 35 ****************
... ..( 4 skipped). .. ****************
130 2019-11-02 22:19 35 ****************
131 2019-11-02 22:20 36 *****************
132 2019-11-02 22:21 36 *****************
133 2019-11-02 22:22 35 ****************
134 2019-11-02 22:23 35 ****************
135 2019-11-02 22:24 35 ****************
136 2019-11-02 22:25 36 *****************
137 2019-11-02 22:26 36 *****************
138 2019-11-02 22:27 35 ****************
... ..( 3 skipped). .. ****************
142 2019-11-02 22:31 35 ****************
143 2019-11-02 22:32 ? -
144 2019-11-02 22:33 ? -
145 2019-11-02 22:34 30 ***********
146 2019-11-02 22:35 30 ***********
147 2019-11-02 22:36 30 ***********
148 2019-11-02 22:37 31 ************
149 2019-11-02 22:38 30 ***********
150 2019-11-02 22:39 30 ***********
151 2019-11-02 22:40 31 ************
152 2019-11-02 22:41 32 *************
153 2019-11-02 22:42 32 *************
154 2019-11-02 22:43 32 *************
155 2019-11-02 22:44 33 **************
156 2019-11-02 22:45 36 *****************
157 2019-11-02 22:46 40 *********************
158 2019-11-02 22:47 37 ******************
159 2019-11-02 22:48 35 ****************
160 2019-11-02 22:49 38 *******************
161 2019-11-02 22:50 41 **********************
162 2019-11-02 22:51 37 ******************
163 2019-11-02 22:52 35 ****************
164 2019-11-02 22:53 39 ********************
165 2019-11-02 22:54 42 ***********************
166 2019-11-02 22:55 38 *******************
167 2019-11-02 22:56 36 *****************
168 2019-11-02 22:57 41 **********************
169 2019-11-02 22:58 40 *********************
170 2019-11-02 22:59 37 ******************
171 2019-11-02 23:00 36 *****************
172 2019-11-02 23:01 41 **********************
173 2019-11-02 23:02 39 ********************
174 2019-11-02 23:03 36 *****************
175 2019-11-02 23:04 38 *******************
176 2019-11-02 23:05 42 ***********************
177 2019-11-02 23:06 38 *******************
178 2019-11-02 23:07 36 *****************
179 2019-11-02 23:08 39 ********************
180 2019-11-02 23:09 42 ***********************
181 2019-11-02 23:10 37 ******************
182 2019-11-02 23:11 36 *****************
183 2019-11-02 23:12 40 *********************
184 2019-11-02 23:13 42 ***********************
185 2019-11-02 23:14 37 ******************
186 2019-11-02 23:15 36 *****************
187 2019-11-02 23:16 41 **********************
188 2019-11-02 23:17 41 **********************
189 2019-11-02 23:18 37 ******************
190 2019-11-02 23:19 36 *****************
191 2019-11-02 23:20 41 **********************
0 2019-11-02 23:21 39 ********************
1 2019-11-02 23:22 36 *****************
2 2019-11-02 23:23 36 *****************
SCT Error Recovery Control:
Read: 80 (8.0 seconds)
Write: 80 (8.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 2477 --- Lifetime Power-On Resets
0x01 0x010 4 4836 --- Power-on Hours
0x01 0x018 6 36058730295 --- Logical Sectors Written
0x01 0x020 6 369978117 --- Number of Write Commands
0x01 0x028 6 64076270929 --- Logical Sectors Read
0x01 0x030 6 585338370 --- Number of Read Commands
0x01 0x038 6 1572470598202 --- Date and Time TimeStamp
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 35 --- Current Temperature
0x05 0x010 1 35 --- Average Short Term Temperature
0x05 0x018 1 - --- Average Long Term Temperature
0x05 0x020 1 54 --- Highest Temperature
0x05 0x028 1 21 --- Lowest Temperature
0x05 0x030 1 - --- Highest Average Short Term Temperature
0x05 0x038 1 29 --- Lowest Average Short Term Temperature
0x05 0x040 1 - --- Highest Average Long Term Temperature
0x05 0x048 1 - --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 80 --- Specified Maximum Operating Temperature
0x05 0x060 4 278600 --- Time in Under-Temperature
0x05 0x068 1 -20 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 11385 --- Number of Hardware Resets
0x06 0x018 4 0 --- Number of Interface CRC Errors
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 4 --- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x000a 2 2 Device-to-host register FISes sent due to a COMRESET
