OS: Windows Server 2008 R2 Standard SP1 x64
Problem with KB4499164 and KB4054521
Error Code 80070490
System Update Readness Tool (KB947821) did not help
SFCFix did not find any problems
In c:\Windows\Logs\CBS\CBS.log I see this:
I did try to install KB4486459 (which is mensioned in CBS.log), but it shows not aplicable message:
Error Code 80070490
2019-06-05 11:29:32, Info CBS Plan: Package: Package_1148_for_KB4499164~31bf3856ad364e35~amd64~~6.1.1.8, Update: 4499164-3578_neutral_LDR, current: Install Pending, pending: Default, start: Installed, applicable: Installed, targeted: Installed, limit: Installed, selected: Default
2019-06-05 11:29:32, Info CBS Exec: Package: Package_1148_for_KB4499164~31bf3856ad364e35~amd64~~6.1.1.8 is already in the correct state, current: Installed, targeted: Installed
2019-06-05 11:29:32, Info CBS Exec: Skipping Package: Package_1148_for_KB4499164~31bf3856ad364e35~amd64~~6.1.1.8, Update: 4499164-3578_neutral_LDR because it is already in the correct state.
2019-06-05 11:29:32, Error CBS Failed to resolve package 'Package_40_for_KB4486459~31bf3856ad364e35~amd64~~6.1.1.0' [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Info CBS Failed to resolve package [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Info CBS Failed to get next package to re-evaluate [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Info CBS Failed to process component watch list. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Info CSI 0000000e@2019/6/5:08:29:32.383 CSI Transaction @0x339d70 destroyed
2019-06-05 11:29:32, Info CBS Perf: InstallUninstallChain complete.
2019-06-05 11:29:32, Info CBS Failed to execute execution chain. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Error CBS Failed to process single phase execution. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2019-06-05 11:29:32, Info CBS WER: Generating failure report for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8, status: 0x80070490, failure source: Execute, start state: Staged, target state: Installed, client id: WindowsUpdateAgent
2019-06-05 11:29:32, Info CBS Failed to query DisableWerReporting flag. Assuming not set... [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-05 11:29:32, Info CBS Failed to add %windir%\winsxs\pending.xml to WER report because it is missing. Continuing without it...
2019-06-05 11:29:32, Info CBS Failed to add %windir%\winsxs\pending.xml.bad to WER report because it is missing. Continuing without it...
2019-06-05 11:29:32, Info CBS Reboot mark refs: 0
