Hello,
i have serious problems with latency.
I am using windows 8 64 bit enterprise.
My setup:
motherboard - gigabyte, model - b75m-d2v, URL: GIGABYTE - Motherboard - Socket 1155 - GA-B75M-D2V (rev. 1.0)
gpu - geforce 780, model - GV-N780G5-3GD-B, URL: GIGABYTE - Graphics Card - NVIDIA - PCI Express Solution - GeForce 700 Series - GV-N780D5-3GD-B
ram - kingston 2x8GB, model - KHX1333C7AD3/4G, URL: http://www.kingston.com/datasheets/KHX1333C7AD3_4G.pdf
cpu - intel core i7 3770k, model - BX80637173770K, URL: ARK | Intel® Coreâ„¢ i7-3770K Processor (8M Cache, up to 3.90 GHz)
ssd - samsung evo 840 250gb, model - MZ-7TE250BW, URL: 250GB 2.5-inch SATA III Internal SSD Single Unit MZ-7TE250BW | Samsung 840 EVO
hdd - western digital 1tb, model - WD1002FAEX-00Y9A05.0
psu - cooler master real power 620, URL: http://www.coolermaster.com/service/support/model/RS-620-ASAA-A1/
I am using latencymon to measure latency:
CONCLUSION
Your system seems to have difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:03:30 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DWDWDWTT
Hardware: Gigabyte Technology Co., Ltd., B75M-D2V
CPU: GenuineIntel Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 8137 MB total
CPU SPEED
Reported CPU speed: 3492,0 MHz
Measured CPU speed: 2343,0 MHz (approx.)
Highest measured interrupt to process latency (µs): 1933,599592
Average measured interrupt to process latency (µs): 2,282253
Highest measured interrupt to DPC latency (µs): 1931,840175
Average measured interrupt to DPC latency (µs): 0,843368
REPORTED ISRs
Highest ISR routine execution time (µs): 107,008877
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,021424
Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,037463
ISR count (execution time <250 µs): 69373
REPORTED DPCs
Highest DPC routine execution time (µs): 1350,627434
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 353.06 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,103229
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0,409531
DPC count (execution time <250 µs): 1003664
DPC count (execution time 500-999 µs): 33
DPC count (execution time 1000-1999 µs): 3
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: csgo.exe
Total number of hard pagefaults 4979
Hard pagefault count of hardest hit process: 2764
Highest hard pagefault resolution time (µs): 341822,513173
Total time spent in hard pagefaults (%): 3,265072
Number of processes hit: 19
PER CPU DATA
CPU 0 Interrupt cycle time (s): 5,996992
CPU 0 ISR highest execution time (µs): 107,008877
CPU 0 ISR total execution time (s): 0,315111
CPU 0 ISR count: 69373
CPU 0 DPC highest execution time (µs): 1350,627434
CPU 0 DPC total execution time (s): 3,261499
CPU 0 DPC count: 982290
CPU 1 Interrupt cycle time (s): 0,675045
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 100,517468
CPU 1 DPC total execution time (s): 0,15670
CPU 1 DPC count: 14911
CPU 2 Interrupt cycle time (s): 0,387264
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 172,920389
CPU 2 DPC total execution time (s): 0,017129
CPU 2 DPC count: 4079
CPU 3 Interrupt cycle time (s): 0,320399
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 160,162658
CPU 3 DPC total execution time (s): 0,009338
CPU 3 DPC count: 2420
I tried to switch most of my cotrollers to msi mode:
Sata i had already, but i have to installed intel rapid storage technology and it switch it automaticaly to msi mode, but storport.sys didn't better latency and addiditionaly iastor.sys start to show in latmon and make more latency, even i read, that it is crap, after i unistalled and it switches back to ms sata ahci cotroller i could feel difference, with my mouse movement, it felt faster.
And what about usb i had here
Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26 latest version and same it refused to switch, to msi mode.
Now i have here microsoft standard enhanced pci to usb host controller, from 2006, because last controller dissapeared from my system after i blocked it in gpedit.msc, after i allowed all drivers again, it starts to show in device manager this...
So i start to search for driver for this and it took me to intel engine management, after i installed it microsoft driver from year 2006 standard enhanced pci to usb host controller still persist and i didn't update, dont know why.
Sorry it is tough for talk about it, for me, i am completely confused with drivers.
All i need fix somehow, someway usbport.sys, nvlddmkm.sys and ndis.sys.
I have intel gigabit ct desktop adapter i downloade latest drivers from https://downloadcenter.intel.com/download/21642/Network-Adapter-Driver-for-Windows-8- , which is from 06/02/2015 and in device manage it shows 19.6.2013
Ndis.sys i tried to fix by tuning nic, switching of interrupt moderation, iner frame spacing, flow control, or rss enable/disable, nothing had any impact off or on.
Also i tunned my neths int tcp show global setting:
here is my get-nettcpsetting
unfortunately windows cant switch to custom mode and it doesnt allow modify initial congestin windows and del ack tick timeouts, so default template is internet.
I explorer thousand sites and write to 100 forums and i wasn't able find anything usefull.
I can't play cs go, because i am ovewflowed with latency.
Sorry for ripped english.
If you had some genial ideas tell me, thanks much.
My setup:
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8137 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 1 ISR count: 0
CPU 2 ISR count: 0
CPU 3 ISR count: 0
