Hello,
I am at my wits end with my latest build. I built my machine back in October 2020. I got 2 months of use and 8 months of chasing my tail.
Here are the specs:
Operating System: Windows 10 Home build 19043 (64-bit)
CPU Type: AMD Ryzen 9 3900XT 12-Core
Motherboard: MAG X570 TOMAHAWK WIFI (MS-7C84)
Memory: 32GB G Skill F4-3600C18 - 16GTZN x2
Videocard: ASUS NVIDIA GeForce RTX 2070 SUPER
Hard Drive: WDC WD40EZRZ-00GXCB0 (4TB)
Every thing ran great until January. Then I started getting consistent BSOD. After a fair amount of troubleshooting with MSI they RMA'd my MB. Got it back then my PCIE-1 slot wouldn't recognize my video card. So I sent the MB back to MSI, they fixed it and sent it back. Again no dice. So they replaced the board with a new one. Got that one and again didn't work. At this point I am pretty sure it's the 2070 Super, though it worked fine on my neighbors machine. So I send it into ASUS and they inform me the warranty expired a month prior and that the best they could is sell me a reconditioned one for $500. So I did that. Got it back from Asus and still no dice. However, I was able to cram it into PCIE-3 by unplugging everything at the bottom of the MB and get into the BIOS. I switched the PCI-E1 lane configuration to 4x4 and now my GPU works in E1.
At this point I thought my issues were over. Apparently not. It was a nightmare getting windows installed. Essentially this was a fresh build as the HDD was brand new. It took the better part of the day before windows would finally complete the install without BSOD after BSOD after BSOD. Generally, Critical Process Died and Reference by Pointer.
Currently, I have everything installed, all drivers updated, and I am still getting consistent issues. I am also noticing that my internet connection is intermittent because when I open new screens I generally have to reload right away to get the window to open. Also my downloads are constantly failing. This is regardless whether I am using Microsoft Edge or Chrome. Also, it happens on all WIFI access points that I can connect to.
At this point I have no clue what's causing my issues. This rig worked flawless for several months. But now it's a disaster. The only things that haven't been swapped out since the onset of the issues is the RAM and the Processor. I have, however, taken the RAM out and tried it one stick at a time. The results were the same.
Here is a link to my dump files.
Dump
I am not really good at deciphering them but it seems like it's missing several of my crashes. But if someone could shed some light on my possible issues I would be greatly appreciative! Beers on me! Thanks
Here are the specs:
Dump
