[SOLVED] HELP Surface Book with SFC and DISM tests error
FLM
I have buy a Surface Book and a microsoft wireless display adapter. The connection between us its not stable, so i have talk to surface support, they have done SFC /scannow and DISM tests but they found errors in system that can't fix.
Surface suport ask me to make a factory reset, i have done, but SFC and DISM tests tell me the same think.
Please help me
I send you the CBS.zip file.
Thanks a lot
Hello FLM,
Please follow the instructions below:
SFCFix Script (.zip)
Warning: This fix is intended for use on this particular machine. Do not use this fix on any other machine; doing so may cause damage to your Operating System. If you are not the original poster and require assistance, please start your own topic.
  • Download View attachment SFCFix.zip and save this file to your Desktop.
  • Note: Ensure this file is named SFCFix.zip. Do not rename the file.
  • Close all open windows.
  • SFCFix.exe
    and SFCFix.zip
    should both be present on your Desktop.
  • Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
  • SFCFix will now process the script. Upon completion, a file (SFCFix.txt) will be created on your Desktop.
  • Copy the contents of the file and paste in your next reply.
SFC /Scannow
  • Press the Windows Key
    + r on your keyboard at the same time. Type Notepad and click OK.
  • Copy the three bold lines below and paste into the Notepad document:
    timeout /t 120 /nobreak
    copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\CBS.txt"
    del %0
  • Click Format. Ensure Wordwrap is unchecked.
  • Click File, Save As and name the file sfcscannow.bat.
  • Select All Files as the Save as type. Save the file to your Desktop.
  • Locate sfcscannow.bat
    on your Desktop. Right-click the file and click
    Run as administrator.
  • Upon completion, a file (CBS.txt) will be created on your Desktop. Attach this file in your next reply.
  • Note: If the file is too large to attach, upload to a service such as Dropbox, One Drive or SendSpace and provide a direct download link in your next reply.
Thanks for your help :)
Dropbox - CBS.tx
SFCFix version 2.4.9.2 by niemiro.
Start time: 2016-02-01 14:47:54.455
Microsoft Windows 10 Insider Slow, Build 10586 - amd64
Using .zip script file at C:\Users\Leandro FLM\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll
Successfully copied file C:\Users\Leandro FLM\AppData\Local\niemiro\Archive\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll to C:\WINDOWS\winsxs\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll.
Successfully restored ownership for C:\WINDOWS\winsxs\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll
Successfully restored permissions on C:\WINDOWS\winsxs\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll
SFCFix version 2.4.9.2 by niemiro has completed.
Finish time: 2016-02-01 14:47:54.692
Script hash: IkXLtZRwuzxcjM0NMtaXyEAskaSu7kbEIluIL8KozP8=
That's quite alright. :dsmile:
SFC is not reporting any issues:
2016-02-01 15:14:35, Info                  CSI    0000f251 [SR] Verify complete
2016-02-01 15:14:35, Info                  CSI    0000f252 [SR] Repairing 0 components
2016-02-01 15:14:35, Info                  CSI    0000f253 [SR] Beginning Verify and Repair transaction
2016-02-01 15:14:35, Info                  CSI    0000f254 [SR] Repair complete
Please run a fresh DISM scan:
DISM /RestoreHealth
    dism /online /cleanup-image /restorehealth
    del %0
  • Click File, Save As and name the file dism.bat.
  • Locate dism.bat
All is ok now i don't know if its a update or your manipulation, but all works now, many thanks
:lol:
Yes, SFC returned with no issues because of the file we replaced in Post #2. :dsmile:
You may wish to still consider running DISM so we can confirm there are no remaining issues.
DISM looks good. :dsmile:
Do you have any outstanding issues with your computer?
I don't understand why but when i connect to microsoft wireless display adapter after 2 minutes the connection stops. Do you know why?
Thanks
