kerr2000
- Sep 9, 2020
- 2
EVEN AFTER CLEAN INSTALLING WINDOWS I GET THE SAME RESULT USING LATENCY MON.
PLEASE DO HELP IF THERES A FIX.ITS SEEMS TO BE HDAUDBUS.SYS THATS CAUSING MOST OF THE PROBLEM.
CONCLUSION
LatencyMon has been analyzing your system for 0:10:35 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-SUFTI6C
OS version: Windows 10, 10.0, version 2004, build: 19041 (x64)
Hardware: Inspiron 5558, Dell Inc.
CPU: GenuineIntel Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
Logical processors: 4
Processor groups: 1
RAM: 8102 MB total
CPU SPEED
Reported CPU speed: 2195 MHz
Highest measured interrupt to process latency (µs): 254894.40
Average measured interrupt to process latency (µs): 54.232170
Highest measured interrupt to DPC latency (µs): 254885.80
Average measured interrupt to DPC latency (µs): 48.900564
REPORTED ISRs
Highest ISR routine execution time (µs): 21495.598178
Highest reported total ISR routine time (%): 0.023948
Total time spent in ISRs (%) 0.031484
ISR count (execution time <250 µs): 178280
REPORTED DPCs
Highest DPC routine execution time (µs): 6772.933941
Highest reported total DPC routine time (%): 0.069779
Total time spent in DPCs (%) 0.336320
DPC count (execution time <250 µs): 910163
DPC count (execution time 500-10000 µs): 2190
DPC count (execution time 1000-2000 µs): 113
DPC count (execution time 2000-4000 µs): 13
DPC count (execution time >=4000 µs): 4
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 1606
Hard pagefault count of hardest hit process: 265
Number of processes hit: 17
PER CPU DATA
CPU 0 Interrupt cycle time (s): 26.019324
CPU 0 ISR highest execution time (µs): 21495.598178
CPU 0 ISR total execution time (s): 0.799938
CPU 0 ISR count: 177955
CPU 0 DPC highest execution time (µs): 6772.933941
CPU 0 DPC total execution time (s): 7.264057
CPU 0 DPC count: 789884
CPU 1 Interrupt cycle time (s): 10.960197
CPU 1 ISR highest execution time (µs): 15.999089
CPU 1 ISR total execution time (s): 0.000893
CPU 1 ISR count: 328
CPU 1 DPC highest execution time (µs): 699.060592
CPU 1 DPC total execution time (s): 0.359142
CPU 1 DPC count: 38574
CPU 2 Interrupt cycle time (s): 11.716353
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 377.424601
CPU 2 DPC total execution time (s): 0.508175
CPU 2 DPC count: 46622
CPU 3 Interrupt cycle time (s): 5.499479
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 594.256948
CPU 3 DPC total execution time (s): 0.423336
CPU 3 DPC count: 37403
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8102 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
