[SOLVED] Help fixing Manifest issues.
TecGuy
North Carolina, USA
Hello, I have been trying to correct these manifest problems for the past month or so. I have been trying to avoid having to reinstall my Windows 7 and I came here hoping to find some assistance. My pc works fine with the current errors that SFC detects but I still wouldn't find having them fixed haha.
So any assistance would be greatly appreciated.
Thanks.
(Oh if you require the CheckSur log also, I have that too but I was unsure if i needed to attach it.)
Hi there TecGuy,
Please do attach the CheckSUR.log file, I'd like to take a look at it :)
Hi there TecGuy,
I tried the checksur the other day and i couldn't get it to finish, so its an incomplete log. but you can still get an idea of what we're working with. i might have to do the repair install but i'm just curious what y'all can do haha
Download SFCFix.zip from Sendspace.com - send big files the easy way
Once SFCFix has finished, run SURT again. Once it completes, attach CheckSUR.log with your reply.
 SFCFix version 3.0.0.0 by niemiro.Start time: 2016-12-12 12:27:46.260
Using .zip script file at C:\Users\Brandon\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_5c08d289a00c5de4
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_5c0676f9a00e9169
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_72d45ee78666ea32
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_6cb763a50706843d
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_6cb508150708b7c2
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_838565a8ed5ebd62
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_8382f002ed61108b
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_bac3d364a4c3ea89
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_ba2f64c78bae6989
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_fee01d41499c8a7b
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_fe4caeee308622d2
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_de4981805906d42a
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_ddbd0bb53febb519
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_ecd9053ace202b5b
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_ec4c8f6fb5050c4a
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_c669ada401dd550a
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_c6834cbe01c9855d
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_c5dc0dcae8c352bd
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_c5f6d6f2e8ae664c
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_d4f9315e76f6ac3b
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_d512d07876e2dc8e
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_d46b91855ddca9ee
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_d4865aad5dc7bd7d
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_e5c59e88fdeffb68
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_e5323035e4d993bf
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_36077453d1a24eea
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_3579d47ab8884c9d
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_1542c4557d4c2a10
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_152b3ab17d5e15a3
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_14b439146432f7a4
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_4fdef98414e81a4e
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_a3d5676fe0cf9e1f
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_1d02bb6fa92ed9b5
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_c1c770f6605a21ff
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_c13402a34743ba56
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_8ff30b0818c08683
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_8fad227618f5bada
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_8ffff80218b67b14
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_8f7e0818ff939e0b
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8f658f40ffa656a6
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_8f802ad8ff91a602
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_e0c764d21ae9d8d5
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_e07fd19d019a74a1
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_fcae77f5ba77fe97
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_fc688f63baad32ee
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_fcbb64efba6df328
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_fc397506a14b161f
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_fc20fc2ea15dceba
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_fc3b97c6a1491e16
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_c03ca3001653c1ef
Successfully took permissions for file or folder C:\Windows\winsxs\manifests
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_145b9bb28b9034de
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_145940228b926863
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_2b27281071eac12c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_250a2ccdf28a5b37
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_2507d13df28c8ebc
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_3bd82ed1d8e2945c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_3bd5b92bd8e4e785
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_c62e4218ee047e0e
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.23418_none_153208a8cc0efe06
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22436_none_151a7f04cc20e999
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22091_none_14d49672cc561df0
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.21738_none_151c9c12cc1efa1b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.18043_none_14830bbdb30e2246
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17932_none_148d033db306b9bc
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17625_none_149ace55b2fbf25b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.22457_none_366f8b668e482477
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.18264_none_35d81beb75355772
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_16e26ee85d215bbf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_164e004b440bdabf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_2bb2ca019d418cef
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_2b252a2884278aa2
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_5afeb8c501f9fbb1
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_5a6b4a71e8e39408
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.22172_none_86ab4a318a459fda
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.18010_none_86608c5a70f925bc
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_0a5f8ec22fd235a9
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smbminirdr_31bf3856ad364e35_6.1.7601.23418_none_de44df3b80d7377e
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smb20-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e98e67a1b97fa951
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-smb10-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e757fd8f7b2875e0
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_db665ed992448b73
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_458a4f31e0875853
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_9980bd1dac6edc24
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_12ae111d74ce17ba
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_feac5ef66f0db209
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23418_none_cae3d3a6e3dcdac3
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_cacc4a02e3eec656
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_ca38dbafcad85ead
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_b78a50482be77471
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_b772c6a42bf96004
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_b6df585112e2f85b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-netio-infrastructure_31bf3856ad364e35_6.1.7601.22457_none_b522b5a9e5288c86
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_bc91c7982155d6fe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_85b5ea59e44dd8f5
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_859e60b5e45fc488
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_85587823e494f8df
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_85ab4dafe455b919
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_85295dc6cb32dc10
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8510e4eecb4594ab
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_852b8086cb30e407
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_d672ba7fe68916da
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_d62b274acd39b2a6
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_f271574786055109
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_f259cda386173c9c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_f213e511864c70f3
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_f266ba9d860d312d
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_f1e4cab46cea5424
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_f1cc51dc6cfd0cbf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_f1e6ed746ce85c1b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_3a681d0411644560
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_39dba738f849264f
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_48f7a0be867d9c91
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_486b2af36d627d80
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_22884927ba3ac640
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_22a1e841ba26f693
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_21faa94ea120c3f3
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_22157276a10bd782
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_3117cce22f541d71
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_31316bfc2f404dc4
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_308a2d09163a1b24
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_30a4f63116252eb3
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23265_none_5494e851cc1aeba8
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23149_none_54ae876bcc071bfb
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.19061_none_54074878b300e95b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.18946_none_542211a0b2ebfcea
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23265_none_63246c0c413442d9
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23149_none_633e0b264120732c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.19061_none_6296cc33281a408c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.18946_none_62b1955b2805541b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.23418_none_283aa90bd5176a24
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.22436_none_28231f67d52955b7
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.18113_none_27ac1dcabbfe37b8
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_c419477eddb3bf90
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_d59aaf345cba3ec2
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_d519e1c143965059
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.23418_none_d30f395731d38e0e
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22436_none_d2f7afb331e579a1
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22091_none_d2b1c721321aadf8
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.21738_none_d2f9ccc131e38a23
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.18015_none_d282acc418b89129
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17932_none_d26a33ec18cb49c4
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17625_none_d277ff0418c08263
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_41e43a0cb64d6c9e
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_4150cbb99d3704f5
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_5c08d289a00c5de4\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_5c08d289a00c5de4\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_5c0676f9a00e9169\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_5c0676f9a00e9169\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_72d45ee78666ea32\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_72d45ee78666ea32\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_6cb763a50706843d\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_6cb763a50706843d\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_6cb508150708b7c2\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_6cb508150708b7c2\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_838565a8ed5ebd62\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_838565a8ed5ebd62\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_8382f002ed61108b\GdiPlus.dll to C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_8382f002ed61108b\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_bac3d364a4c3ea89\mswsock.dll to C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_bac3d364a4c3ea89\mswsock.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_ba2f64c78bae6989\mswsock.dll to C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_ba2f64c78bae6989\mswsock.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_fee01d41499c8a7b\tdh.dll to C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_fee01d41499c8a7b\tdh.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_fe4caeee308622d2\tdh.dll to C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_fe4caeee308622d2\tdh.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6\credssp.dll to C:\Windows\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6\credssp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6\TSpkg.dll to C:\Windows\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6\TSpkg.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520\ntkrnlpa.exe to C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520\ntkrnlpa.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520\ntoskrnl.exe to C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520\ntoskrnl.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77\ntkrnlpa.exe to C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77\ntkrnlpa.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77\ntoskrnl.exe to C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77\ntoskrnl.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_de4981805906d42a\d3d10warp.dll to C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_de4981805906d42a\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_ddbd0bb53febb519\d3d10warp.dll to C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_ddbd0bb53febb519\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_ecd9053ace202b5b\d3d10warp.dll to C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_ecd9053ace202b5b\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_ec4c8f6fb5050c4a\d3d10warp.dll to C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_ec4c8f6fb5050c4a\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_c669ada401dd550a\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_c669ada401dd550a\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_c6834cbe01c9855d\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_c6834cbe01c9855d\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_c5dc0dcae8c352bd\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_c5dc0dcae8c352bd\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_c5f6d6f2e8ae664c\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_c5f6d6f2e8ae664c\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_d4f9315e76f6ac3b\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_d4f9315e76f6ac3b\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_d512d07876e2dc8e\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_d512d07876e2dc8e\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_d46b91855ddca9ee\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_d46b91855ddca9ee\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_d4865aad5dc7bd7d\DWrite.dll to C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_d4865aad5dc7bd7d\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_e5c59e88fdeffb68\advapi32.dll to C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_e5c59e88fdeffb68\advapi32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_e5323035e4d993bf\advapi32.dll to C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_e5323035e4d993bf\advapi32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\acwow64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\instnm.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\ntvdm64.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\setup16.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\user.exe to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\wow32.dll to C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_36077453d1a24eea\user32.dll to C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_36077453d1a24eea\user32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_3579d47ab8884c9d\user32.dll to C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_3579d47ab8884c9d\user32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_1542c4557d4c2a10\apisetschema.dll to C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_1542c4557d4c2a10\apisetschema.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_152b3ab17d5e15a3\apisetschema.dll to C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_152b3ab17d5e15a3\apisetschema.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_14b439146432f7a4\apisetschema.dll to C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_14b439146432f7a4\apisetschema.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_4fdef98414e81a4e\kerberos.dll to C:\Windows\winsxs\wow64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_4fdef98414e81a4e\kerberos.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_a3d5676fe0cf9e1f\wdigest.dll to C:\Windows\winsxs\wow64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_a3d5676fe0cf9e1f\wdigest.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_1d02bb6fa92ed9b5\rpcrt4.dll to C:\Windows\winsxs\wow64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_1d02bb6fa92ed9b5\rpcrt4.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_c1c770f6605a21ff\ntdll.dll to C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_c1c770f6605a21ff\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_c13402a34743ba56\ntdll.dll to C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_c13402a34743ba56\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c\secur32.dll to C:\Windows\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c\secur32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c\sspicli.dll to C:\Windows\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c\sspicli.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_8ff30b0818c08683\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_8ff30b0818c08683\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_8fad227618f5bada\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_8fad227618f5bada\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_8ffff80218b67b14\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_8ffff80218b67b14\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_8f7e0818ff939e0b\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_8f7e0818ff939e0b\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8f658f40ffa656a6\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8f658f40ffa656a6\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_8f802ad8ff91a602\KernelBase.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_8f802ad8ff91a602\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_e0c764d21ae9d8d5\KernelBase.dll.mui to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_e0c764d21ae9d8d5\KernelBase.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_e07fd19d019a74a1\KernelBase.dll.mui to C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_e07fd19d019a74a1\KernelBase.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_fcae77f5ba77fe97\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_fcae77f5ba77fe97\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_fc688f63baad32ee\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_fc688f63baad32ee\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_fcbb64efba6df328\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_fcbb64efba6df328\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_fc397506a14b161f\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_fc397506a14b161f\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_fc20fc2ea15dceba\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_fc20fc2ea15dceba\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_fc3b97c6a1491e16\kernel32.dll to C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_fc3b97c6a1491e16\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\atmfd.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\atmfd.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\atmlib.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\atmlib.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\dciman32.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\dciman32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\fontsub.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\fontsub.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\lpk.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57\lpk.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\atmfd.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\atmfd.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\atmlib.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\atmlib.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\dciman32.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\dciman32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\fontsub.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\fontsub.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\lpk.dll to C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46\lpk.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\cfgmgr32.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\cfgmgr32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\devobj.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\devobj.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\devrtl.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\devrtl.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\drvinst.exe to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd\drvinst.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\cfgmgr32.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\cfgmgr32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\devobj.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\devobj.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\devrtl.dll to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\devrtl.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\drvinst.exe to C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254\drvinst.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_c03ca3001653c1ef\appidapi.dll to C:\Windows\winsxs\wow64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_c03ca3001653c1ef\appidapi.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_47bab533435572f66d87b5af8745953b_31bf3856ad364e35_7.1.7601.22787_none_c6ca2e13016ae76c.manifest to C:\Windows\winsxs\manifests\amd64_47bab533435572f66d87b5af8745953b_31bf3856ad364e35_7.1.7601.22787_none_c6ca2e13016ae76c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_727e4c0e5e33970764adf3bb2669c17b_31bf3856ad364e35_7.1.7601.18581_none_0dd5efbeb1c1ac6c.manifest to C:\Windows\winsxs\manifests\amd64_727e4c0e5e33970764adf3bb2669c17b_31bf3856ad364e35_7.1.7601.18581_none_0dd5efbeb1c1ac6c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_7b5bc9dd8cb67deff20b5667c051a02a_31bf3856ad364e35_7.1.7601.18581_none_907414435939d27c.manifest to C:\Windows\winsxs\manifests\amd64_7b5bc9dd8cb67deff20b5667c051a02a_31bf3856ad364e35_7.1.7601.18581_none_907414435939d27c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_7b993ef343e8df436ee6d1e28c0f1c6b_31bf3856ad364e35_7.1.7601.22787_none_a1371ed40ba8a85b.manifest to C:\Windows\winsxs\manifests\amd64_7b993ef343e8df436ee6d1e28c0f1c6b_31bf3856ad364e35_7.1.7601.22787_none_a1371ed40ba8a85b.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_956e6144de993e5032b58d5c417122f8_31bf3856ad364e35_7.1.7601.18581_none_e7070d473d4e91a5.manifest to C:\Windows\winsxs\manifests\amd64_956e6144de993e5032b58d5c417122f8_31bf3856ad364e35_7.1.7601.18581_none_e7070d473d4e91a5.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_9d82a8ea1cff3e244ab9dc35051413e7_31bf3856ad364e35_7.1.7601.18581_none_adc09d2a05fc44ff.manifest to C:\Windows\winsxs\manifests\amd64_9d82a8ea1cff3e244ab9dc35051413e7_31bf3856ad364e35_7.1.7601.18581_none_adc09d2a05fc44ff.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_adaf77abb4159f35b85a1171e8a5a368_31bf3856ad364e35_7.1.7601.22787_none_281f805b416d2358.manifest to C:\Windows\winsxs\manifests\amd64_adaf77abb4159f35b85a1171e8a5a368_31bf3856ad364e35_7.1.7601.22787_none_281f805b416d2358.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_b403c70b48e9c7cea9fab7f93c1addf3_31bf3856ad364e35_7.1.7601.18581_none_e3d085735b1e9497.manifest to C:\Windows\winsxs\manifests\amd64_b403c70b48e9c7cea9fab7f93c1addf3_31bf3856ad364e35_7.1.7601.18581_none_e3d085735b1e9497.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_b57c9e61c06718331fd078226ff6a8ec_31bf3856ad364e35_7.1.7601.22787_none_b3848d7fb4a3a6d7.manifest to C:\Windows\winsxs\manifests\amd64_b57c9e61c06718331fd078226ff6a8ec_31bf3856ad364e35_7.1.7601.22787_none_b3848d7fb4a3a6d7.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_f856f69e61ea16bacd0447d6c64242e0_31bf3856ad364e35_7.1.7601.22787_none_bd287bdce71308af.manifest to C:\Windows\winsxs\manifests\amd64_f856f69e61ea16bacd0447d6c64242e0_31bf3856ad364e35_7.1.7601.22787_none_bd287bdce71308af.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.22787_en-us_c4750fbf28f8576d.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.22787_en-us_c4750fbf28f8576d.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.22787_en-us_c3990c1941584cc4.manifest to C:\Windows\winsxs\manifests\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.22787_en-us_c3990c1941584cc4.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c.manifest to C:\Windows\winsxs\manifests\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37.manifest to C:\Windows\winsxs\manifests\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.22787_en-us_6856743b709ae637.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.22787_en-us_6856743b709ae637.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\manifests\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.22787_en-us_677a709588fadb8e.manifest to C:\Windows\winsxs\manifests\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.22787_en-us_677a709588fadb8e.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_145b9bb28b9034de\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_145b9bb28b9034de\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_145940228b926863\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_145940228b926863\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_2b27281071eac12c\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_2b27281071eac12c\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_250a2ccdf28a5b37\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_250a2ccdf28a5b37\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_2507d13df28c8ebc\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_2507d13df28c8ebc\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_3bd82ed1d8e2945c\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_3bd82ed1d8e2945c\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_3bd5b92bd8e4e785\GdiPlus.dll to C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_3bd5b92bd8e4e785\GdiPlus.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_c62e4218ee047e0e\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_c62e4218ee047e0e\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\ntvdm64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64cpu.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64cpu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64win.dll to C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79\wow64win.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.23418_none_153208a8cc0efe06\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.23418_none_153208a8cc0efe06\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22436_none_151a7f04cc20e999\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22436_none_151a7f04cc20e999\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22091_none_14d49672cc561df0\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22091_none_14d49672cc561df0\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.21738_none_151c9c12cc1efa1b\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.21738_none_151c9c12cc1efa1b\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.18043_none_14830bbdb30e2246\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.18043_none_14830bbdb30e2246\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17932_none_148d033db306b9bc\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17932_none_148d033db306b9bc\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17625_none_149ace55b2fbf25b\winsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17625_none_149ace55b2fbf25b\winsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.22457_none_366f8b668e482477\afd.sys to C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.22457_none_366f8b668e482477\afd.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.18264_none_35d81beb75355772\afd.sys to C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.18264_none_35d81beb75355772\afd.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d\win32k.sys to C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d\win32k.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0\win32k.sys to C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0\win32k.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530\win32k.sys to C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530\win32k.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf\win32k.sys to C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf\win32k.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_16e26ee85d215bbf\mswsock.dll to C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_16e26ee85d215bbf\mswsock.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_164e004b440bdabf\mswsock.dll to C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_164e004b440bdabf\mswsock.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_2bb2ca019d418cef\user32.dll to C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_2bb2ca019d418cef\user32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_2b252a2884278aa2\user32.dll to C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_2b252a2884278aa2\user32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_5afeb8c501f9fbb1\tdh.dll to C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_5afeb8c501f9fbb1\tdh.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_5a6b4a71e8e39408\tdh.dll to C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_5a6b4a71e8e39408\tdh.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27\FWPKCLNT.SYS to C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27\FWPKCLNT.SYS.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27\tcpip.sys to C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27\tcpip.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27\FWPKCLNT.SYS to C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27\FWPKCLNT.SYS.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27\tcpip.sys to C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27\tcpip.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.22172_none_86ab4a318a459fda\taskhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.22172_none_86ab4a318a459fda\taskhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.18010_none_86608c5a70f925bc\taskhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.18010_none_86608c5a70f925bc\taskhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815\apisetschema.dll to C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815\apisetschema.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815\smss.exe to C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815\smss.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8\apisetschema.dll to C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8\apisetschema.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8\smss.exe to C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8\smss.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_0a5f8ec22fd235a9\smss.exe to C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_0a5f8ec22fd235a9\smss.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smbminirdr_31bf3856ad364e35_6.1.7601.23418_none_de44df3b80d7377e\mrxsmb.sys to C:\Windows\winsxs\amd64_microsoft-windows-smbminirdr_31bf3856ad364e35_6.1.7601.23418_none_de44df3b80d7377e\mrxsmb.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smb20-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e98e67a1b97fa951\mrxsmb20.sys to C:\Windows\winsxs\amd64_microsoft-windows-smb20-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e98e67a1b97fa951\mrxsmb20.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-smb10-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e757fd8f7b2875e0\mrxsmb10.sys to C:\Windows\winsxs\amd64_microsoft-windows-smb10-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e757fd8f7b2875e0\mrxsmb10.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_db665ed992448b73\msv1_0.dll to C:\Windows\winsxs\amd64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_db665ed992448b73\msv1_0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_458a4f31e0875853\kerberos.dll to C:\Windows\winsxs\amd64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_458a4f31e0875853\kerberos.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_9980bd1dac6edc24\wdigest.dll to C:\Windows\winsxs\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_9980bd1dac6edc24\wdigest.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c\credssp.dll to C:\Windows\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c\credssp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c\TSpkg.dll to C:\Windows\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c\TSpkg.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_12ae111d74ce17ba\rpcrt4.dll to C:\Windows\winsxs\amd64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_12ae111d74ce17ba\rpcrt4.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_feac5ef66f0db209\rpchttp.dll to C:\Windows\winsxs\amd64_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_feac5ef66f0db209\rpchttp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23418_none_cae3d3a6e3dcdac3\ntoskrnl.exe to C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23418_none_cae3d3a6e3dcdac3\ntoskrnl.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_cacc4a02e3eec656\ntoskrnl.exe to C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_cacc4a02e3eec656\ntoskrnl.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_ca38dbafcad85ead\ntoskrnl.exe to C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_ca38dbafcad85ead\ntoskrnl.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_b78a50482be77471\ntdll.dll to C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_b78a50482be77471\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_b772c6a42bf96004\ntdll.dll to C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_b772c6a42bf96004\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_b6df585112e2f85b\ntdll.dll to C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_b6df585112e2f85b\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-netio-infrastructure_31bf3856ad364e35_6.1.7601.22457_none_b522b5a9e5288c86\netio.sys to C:\Windows\winsxs\amd64_microsoft-windows-netio-infrastructure_31bf3856ad364e35_6.1.7601.22457_none_b522b5a9e5288c86\netio.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_bc91c7982155d6fe\ncrypt.dll to C:\Windows\winsxs\amd64_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_bc91c7982155d6fe\ncrypt.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-console-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-datetime-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-debug-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-delayload-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-errorhandling-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-fibers-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-file-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-handle-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-heap-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-interlocked-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-io-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-libraryloader-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-localization-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-localization-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-localregistry-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-localregistry-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-memory-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-misc-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-misc-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-namedpipe-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-processenvironment-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-processthreads-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-profile-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-string-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-synch-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-sysinfo-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-threadpool-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-threadpool-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-util-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-xstate-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-security-base-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_85b5ea59e44dd8f5\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_85b5ea59e44dd8f5\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_859e60b5e45fc488\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_859e60b5e45fc488\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_85587823e494f8df\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_85587823e494f8df\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_85ab4dafe455b919\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_85ab4dafe455b919\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_85295dc6cb32dc10\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_85295dc6cb32dc10\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8510e4eecb4594ab\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8510e4eecb4594ab\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_852b8086cb30e407\KernelBase.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_852b8086cb30e407\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_d672ba7fe68916da\KernelBase.dll.mui to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_d672ba7fe68916da\KernelBase.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_d62b274acd39b2a6\KernelBase.dll.mui to C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_d62b274acd39b2a6\KernelBase.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_f271574786055109\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_f271574786055109\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_f259cda386173c9c\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_f259cda386173c9c\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_f213e511864c70f3\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_f213e511864c70f3\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_f266ba9d860d312d\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_f266ba9d860d312d\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_f1e4cab46cea5424\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_f1e4cab46cea5424\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_f1cc51dc6cfd0cbf\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_f1cc51dc6cfd0cbf\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_f1e6ed746ce85c1b\kernel32.dll to C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_f1e6ed746ce85c1b\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\atmfd.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\atmfd.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\atmlib.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\atmlib.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\dciman32.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\dciman32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\fontsub.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\fontsub.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\lpk.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c\lpk.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\atmfd.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\atmfd.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\atmlib.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\atmlib.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\dciman32.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\dciman32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\fontsub.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\fontsub.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\lpk.dll to C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b\lpk.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_3a681d0411644560\d3d10warp.dll to C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_3a681d0411644560\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_39dba738f849264f\d3d10warp.dll to C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_39dba738f849264f\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_48f7a0be867d9c91\d3d10warp.dll to C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_48f7a0be867d9c91\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_486b2af36d627d80\d3d10warp.dll to C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_486b2af36d627d80\d3d10warp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_22884927ba3ac640\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_22884927ba3ac640\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_22a1e841ba26f693\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_22a1e841ba26f693\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_21faa94ea120c3f3\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_21faa94ea120c3f3\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_22157276a10bd782\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_22157276a10bd782\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_3117cce22f541d71\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_3117cce22f541d71\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_31316bfc2f404dc4\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_31316bfc2f404dc4\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_308a2d09163a1b24\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_308a2d09163a1b24\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_30a4f63116252eb3\DWrite.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_30a4f63116252eb3\DWrite.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23265_none_5494e851cc1aeba8\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23265_none_5494e851cc1aeba8\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23149_none_54ae876bcc071bfb\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23149_none_54ae876bcc071bfb\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.19061_none_54074878b300e95b\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.19061_none_54074878b300e95b\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.18946_none_542211a0b2ebfcea\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.18946_none_542211a0b2ebfcea\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23265_none_63246c0c413442d9\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23265_none_63246c0c413442d9\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23149_none_633e0b264120732c\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23149_none_633e0b264120732c\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.19061_none_6296cc33281a408c\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.19061_none_6296cc33281a408c\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.18946_none_62b1955b2805541b\FntCache.dll to C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.18946_none_62b1955b2805541b\FntCache.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.23418_none_283aa90bd5176a24\csrsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.23418_none_283aa90bd5176a24\csrsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.22436_none_28231f67d52955b7\csrsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.22436_none_28231f67d52955b7\csrsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.18113_none_27ac1dcabbfe37b8\csrsrv.dll to C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.18113_none_27ac1dcabbfe37b8\csrsrv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_c419477eddb3bf90\cryptbase.dll to C:\Windows\winsxs\amd64_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_c419477eddb3bf90\cryptbase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_d59aaf345cba3ec2\umpnpmgr.dll to C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_d59aaf345cba3ec2\umpnpmgr.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_d519e1c143965059\umpnpmgr.dll to C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_d519e1c143965059\umpnpmgr.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.23418_none_d30f395731d38e0e\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.23418_none_d30f395731d38e0e\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22436_none_d2f7afb331e579a1\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22436_none_d2f7afb331e579a1\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22091_none_d2b1c721321aadf8\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22091_none_d2b1c721321aadf8\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.21738_none_d2f9ccc131e38a23\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.21738_none_d2f9ccc131e38a23\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.18015_none_d282acc418b89129\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.18015_none_d282acc418b89129\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17932_none_d26a33ec18cb49c4\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17932_none_d26a33ec18cb49c4\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17625_none_d277ff0418c08263\conhost.exe to C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17625_none_d277ff0418c08263\conhost.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appid-ppdlic.xrm-ms to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appid-ppdlic.xrm-ms.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appid.sys to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appid.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidapi.dll to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidapi.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidcertstorecheck.exe to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidcertstorecheck.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidpolicyconverter.exe to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidpolicyconverter.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidsvc.dll to C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4\appidsvc.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_41e43a0cb64d6c9e\advapi32.dll to C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_41e43a0cb64d6c9e\advapi32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_4150cbb99d3704f5\advapi32.dll to C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_4150cbb99d3704f5\advapi32.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_5c08d289a00c5de4
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_5c08d289a00c5de4
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_5c0676f9a00e9169
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_5c0676f9a00e9169
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_72d45ee78666ea32
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_72d45ee78666ea32
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_6cb763a50706843d
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_6cb763a50706843d
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_6cb508150708b7c2
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_6cb508150708b7c2
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_838565a8ed5ebd62
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_838565a8ed5ebd62
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_8382f002ed61108b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_8382f002ed61108b
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_bac3d364a4c3ea89
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_bac3d364a4c3ea89
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_ba2f64c78bae6989
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_ba2f64c78bae6989
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_fee01d41499c8a7b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_fee01d41499c8a7b
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_fe4caeee308622d2
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_fe4caeee308622d2
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_c64d07f218ec5bf6
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_6eadae7f2b915520
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_6e1a402c127aed77
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_0d2f3cd4f33e35f4
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_0ce95442f3736a4b
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_0d3c29cef3342a85
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_0cba39e5da114d7c
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_0ca1c10dda240617
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_0cbc5ca5da0f5573
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_de4981805906d42a
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_de4981805906d42a
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_ddbd0bb53febb519
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_ddbd0bb53febb519
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_ecd9053ace202b5b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_ecd9053ace202b5b
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_ec4c8f6fb5050c4a
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_ec4c8f6fb5050c4a
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_c669ada401dd550a
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_c669ada401dd550a
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_c6834cbe01c9855d
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_c6834cbe01c9855d
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_c5dc0dcae8c352bd
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_c5dc0dcae8c352bd
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_c5f6d6f2e8ae664c
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_c5f6d6f2e8ae664c
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_d4f9315e76f6ac3b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_d4f9315e76f6ac3b
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_d512d07876e2dc8e
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_d512d07876e2dc8e
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_d46b91855ddca9ee
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_d46b91855ddca9ee
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_d4865aad5dc7bd7d
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_d4865aad5dc7bd7d
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_e5c59e88fdeffb68
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_e5c59e88fdeffb68
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_e5323035e4d993bf
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_e5323035e4d993bf
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_d1165abe3b7ba7b2
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_d0d0722c3bb0dc09
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_d11877cc3b79b834
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_d082ec6b22654009
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_d088def7226177d5
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_d096aa0f2256b074
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_36077453d1a24eea
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_36077453d1a24eea
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_3579d47ab8884c9d
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_3579d47ab8884c9d
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_1542c4557d4c2a10
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_1542c4557d4c2a10
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_152b3ab17d5e15a3
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_152b3ab17d5e15a3
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_14b439146432f7a4
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_14b439146432f7a4
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_4fdef98414e81a4e
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_4fdef98414e81a4e
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_a3d5676fe0cf9e1f
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_a3d5676fe0cf9e1f
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_1d02bb6fa92ed9b5
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_1d02bb6fa92ed9b5
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_c1c770f6605a21ff
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_c1c770f6605a21ff
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_c13402a34743ba56
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_c13402a34743ba56
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-lsa_31bf3856ad364e35_6.1.7601.23418_none_0f52a71ac0e5c28c
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_8ff30b0818c08683
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_8ff30b0818c08683
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_8fad227618f5bada
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_8fad227618f5bada
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_8ffff80218b67b14
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_8ffff80218b67b14
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_8f7e0818ff939e0b
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_8f7e0818ff939e0b
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8f658f40ffa656a6
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8f658f40ffa656a6
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_8f802ad8ff91a602
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_8f802ad8ff91a602
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_e0c764d21ae9d8d5
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_e0c764d21ae9d8d5
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_e07fd19d019a74a1
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_e07fd19d019a74a1
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_fcae77f5ba77fe97
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_fcae77f5ba77fe97
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_fc688f63baad32ee
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_fc688f63baad32ee
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_fcbb64efba6df328
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_fcbb64efba6df328
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_fc397506a14b161f
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_fc397506a14b161f
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_fc20fc2ea15dceba
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_fc20fc2ea15dceba
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_fc3b97c6a1491e16
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_fc3b97c6a1491e16
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_12bbbfa4beb85d57
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_122f49d9a59d3e46
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_dfef5986911b00bd
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_df6e8c1377f71254
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_c03ca3001653c1ef
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_c03ca3001653c1ef
Successfully restored ownership for C:\Windows\winsxs\manifests
Successfully restored permissions on C:\Windows\winsxs\manifests
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_145b9bb28b9034de
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23265_none_145b9bb28b9034de
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_145940228b926863
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23149_none_145940228b926863
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_2b27281071eac12c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18946_none_2b27281071eac12c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_250a2ccdf28a5b37
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23265_none_250a2ccdf28a5b37
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_2507d13df28c8ebc
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.23149_none_2507d13df28c8ebc
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_3bd82ed1d8e2945c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.19061_none_3bd82ed1d8e2945c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_3bd5b92bd8e4e785
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.7601.18946_none_3bd5b92bd8e4e785
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_c6d93a100708fa24
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22436_none_c6c1b06c071ae5b7
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.22091_none_c67bc7da07501a0e
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.21738_none_c6c3cd7a0718f639
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_c62e4218ee047e0e
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.18247_none_c62e4218ee047e0e
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17932_none_c63434a4ee00b5da
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.17625_none_c641ffbcedf5ee79
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.23418_none_153208a8cc0efe06
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.23418_none_153208a8cc0efe06
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22436_none_151a7f04cc20e999
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22436_none_151a7f04cc20e999
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22091_none_14d49672cc561df0
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.22091_none_14d49672cc561df0
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.21738_none_151c9c12cc1efa1b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.21738_none_151c9c12cc1efa1b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.18043_none_14830bbdb30e2246
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.18043_none_14830bbdb30e2246
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17932_none_148d033db306b9bc
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17932_none_148d033db306b9bc
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17625_none_149ace55b2fbf25b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsrv_31bf3856ad364e35_6.1.7601.17625_none_149ace55b2fbf25b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.22457_none_366f8b668e482477
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.22457_none_366f8b668e482477
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.18264_none_35d81beb75355772
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-winsock-core_31bf3856ad364e35_6.1.7601.18264_none_35d81beb75355772
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_16e26ee85d215bbf
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.22444_none_16e26ee85d215bbf
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_164e004b440bdabf
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-w..-infrastructure-bsp_31bf3856ad364e35_6.1.7601.18254_none_164e004b440bdabf
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_2bb2ca019d418cef
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.23265_none_2bb2ca019d418cef
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_2b252a2884278aa2
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-user32_31bf3856ad364e35_6.1.7601.19061_none_2b252a2884278aa2
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_5afeb8c501f9fbb1
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.22436_none_5afeb8c501f9fbb1
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_5a6b4a71e8e39408
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-tracedatahelper_31bf3856ad364e35_6.1.7601.18247_none_5a6b4a71e8e39408
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.22444_none_11ad2a34963bde27
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-tcpip-binaries_31bf3856ad364e35_6.1.7601.18254_none_1118bb977d265d27
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.22172_none_86ab4a318a459fda
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.22172_none_86ab4a318a459fda
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.18010_none_86608c5a70f925bc
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-taskhost_31bf3856ad364e35_6.1.7601.18010_none_86608c5a70f925bc
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.23418_none_0aee1a0348eb6815
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.22436_none_0ad6905f48fd53a8
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_0a5f8ec22fd235a9
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smss_31bf3856ad364e35_6.1.7601.18113_none_0a5f8ec22fd235a9
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smbminirdr_31bf3856ad364e35_6.1.7601.23418_none_de44df3b80d7377e
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smbminirdr_31bf3856ad364e35_6.1.7601.23418_none_de44df3b80d7377e
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smb20-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e98e67a1b97fa951
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smb20-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e98e67a1b97fa951
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-smb10-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e757fd8f7b2875e0
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-smb10-minirdr_31bf3856ad364e35_6.1.7601.23418_none_e757fd8f7b2875e0
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_db665ed992448b73
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_db665ed992448b73
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_458a4f31e0875853
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-security-kerberos_31bf3856ad364e35_6.1.7601.23418_none_458a4f31e0875853
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_9980bd1dac6edc24
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23418_none_9980bd1dac6edc24
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-security-credssp_31bf3856ad364e35_6.1.7601.23418_none_226ba375d149cd2c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_12ae111d74ce17ba
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-rpc-local_31bf3856ad364e35_6.1.7601.23418_none_12ae111d74ce17ba
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_feac5ef66f0db209
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_feac5ef66f0db209
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23418_none_cae3d3a6e3dcdac3
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23418_none_cae3d3a6e3dcdac3
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_cacc4a02e3eec656
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.22436_none_cacc4a02e3eec656
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_ca38dbafcad85ead
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.18247_none_ca38dbafcad85ead
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_b78a50482be77471
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_b78a50482be77471
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_b772c6a42bf96004
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.22436_none_b772c6a42bf96004
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_b6df585112e2f85b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.18247_none_b6df585112e2f85b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-netio-infrastructure_31bf3856ad364e35_6.1.7601.22457_none_b522b5a9e5288c86
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-netio-infrastructure_31bf3856ad364e35_6.1.7601.22457_none_b522b5a9e5288c86
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_bc91c7982155d6fe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_bc91c7982155d6fe
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22436_none_694dd858ab9ba72a
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.22091_none_6907efc6abd0db81
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.21728_none_695ac552ab919bbb
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.18015_none_68d8d569926ebeb2
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17932_none_68c05c919281774d
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.1.7601.17617_none_68daf829926cc6a9
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_85b5ea59e44dd8f5
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_85b5ea59e44dd8f5
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_859e60b5e45fc488
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22436_none_859e60b5e45fc488
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_85587823e494f8df
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.22091_none_85587823e494f8df
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_85ab4dafe455b919
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.21728_none_85ab4dafe455b919
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_85295dc6cb32dc10
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.18015_none_85295dc6cb32dc10
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8510e4eecb4594ab
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17932_none_8510e4eecb4594ab
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_852b8086cb30e407
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.17617_none_852b8086cb30e407
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_d672ba7fe68916da
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.22091_en-us_d672ba7fe68916da
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_d62b274acd39b2a6
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernelbase.resources_31bf3856ad364e35_6.1.7601.17932_en-us_d62b274acd39b2a6
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_f271574786055109
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_f271574786055109
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_f259cda386173c9c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22436_none_f259cda386173c9c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_f213e511864c70f3
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.22091_none_f213e511864c70f3
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_f266ba9d860d312d
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.21728_none_f266ba9d860d312d
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_f1e4cab46cea5424
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.18015_none_f1e4cab46cea5424
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_f1cc51dc6cfd0cbf
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17932_none_f1cc51dc6cfd0cbf
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_f1e6ed746ce85c1b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.17617_none_f1e6ed746ce85c1b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.23149_none_086715528a579b5c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_6.1.7601.18946_none_07da9f87713c7c4b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_3a681d0411644560
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.23149_none_3a681d0411644560
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_39dba738f849264f
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_7.1.7601.18946_none_39dba738f849264f
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_48f7a0be867d9c91
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.23149_none_48f7a0be867d9c91
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_486b2af36d627d80
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directx-warp10_31bf3856ad364e35_6.1.7601.18946_none_486b2af36d627d80
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_22884927ba3ac640
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23265_none_22884927ba3ac640
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_22a1e841ba26f693
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.23149_none_22a1e841ba26f693
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_21faa94ea120c3f3
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.19061_none_21faa94ea120c3f3
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_22157276a10bd782
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_7.1.7601.18946_none_22157276a10bd782
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_3117cce22f541d71
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23265_none_3117cce22f541d71
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_31316bfc2f404dc4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.23149_none_31316bfc2f404dc4
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_308a2d09163a1b24
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.19061_none_308a2d09163a1b24
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_30a4f63116252eb3
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite_31bf3856ad364e35_6.1.7601.18946_none_30a4f63116252eb3
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23265_none_5494e851cc1aeba8
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23265_none_5494e851cc1aeba8
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23149_none_54ae876bcc071bfb
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.23149_none_54ae876bcc071bfb
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.19061_none_54074878b300e95b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.19061_none_54074878b300e95b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.18946_none_542211a0b2ebfcea
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_7.1.7601.18946_none_542211a0b2ebfcea
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23265_none_63246c0c413442d9
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23265_none_63246c0c413442d9
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23149_none_633e0b264120732c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.23149_none_633e0b264120732c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.19061_none_6296cc33281a408c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.19061_none_6296cc33281a408c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.18946_none_62b1955b2805541b
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-directwrite-fontcache_31bf3856ad364e35_6.1.7601.18946_none_62b1955b2805541b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.23418_none_283aa90bd5176a24
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.23418_none_283aa90bd5176a24
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.22436_none_28231f67d52955b7
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.22436_none_28231f67d52955b7
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.18113_none_27ac1dcabbfe37b8
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-csrsrv_31bf3856ad364e35_6.1.7601.18113_none_27ac1dcabbfe37b8
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_c419477eddb3bf90
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_c419477eddb3bf90
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_d59aaf345cba3ec2
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.21733_none_d59aaf345cba3ec2
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_d519e1c143965059
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-coreusermodepnp_31bf3856ad364e35_6.1.7601.17621_none_d519e1c143965059
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.23418_none_d30f395731d38e0e
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.23418_none_d30f395731d38e0e
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22436_none_d2f7afb331e579a1
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22436_none_d2f7afb331e579a1
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22091_none_d2b1c721321aadf8
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.22091_none_d2b1c721321aadf8
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.21738_none_d2f9ccc131e38a23
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.21738_none_d2f9ccc131e38a23
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.18015_none_d282acc418b89129
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.18015_none_d282acc418b89129
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17932_none_d26a33ec18cb49c4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17932_none_d26a33ec18cb49c4
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17625_none_d277ff0418c08263
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-consolehost_31bf3856ad364e35_6.1.7601.17625_none_d277ff0418c08263
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-appid_31bf3856ad364e35_6.1.7601.22436_none_b5e7f8ade1f2fff4
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_41e43a0cb64d6c9e
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.22436_none_41e43a0cb64d6c9e
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_4150cbb99d3704f5
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.18247_none_4150cbb99d3704f5
Currently storing 190 datablocks.
Finish time: 2016-12-12 12:34:38.517
Script hash: fFbMO8VCheocysYA4vrcFy4XDMWSp/ZsDIUrPzGZjr0=
Download SFCFix.zip from Sendspace.com - send big files the easy way
Once SFCFix has completed, run SURT again and attach CheckSUR.log and SFCFix.txt with your reply.
 SFCFix version 3.0.0.0 by niemiro.Start time: 2016-12-14 17:23:41.356
Using .zip script file at C:\Users\Brandon\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37
Successfully took permissions for file or folder C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c
Successfully took permissions for file or folder C:\Windows\winsxs\Manifests
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693\mstscax.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693\mstscax.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\aaclient.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\aaclient.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\mstscax.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\mstscax.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\tsgqec.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85\tsgqec.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\aaclient.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\aaclient.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\mstscax.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\mstscax.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\tsgqec.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a\tsgqec.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c\mstsc.exe.mui to C:\Windows\winsxs\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c\mstsc.exe.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37\mstsc.exe to C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37\mstsc.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c\mstsc.exe to C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c\mstsc.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_394a48371f62c18bd95bfc42e60d34c0_31bf3856ad364e35_6.1.7601.18673_none_17287ce80bd9c2f1.manifest to C:\Windows\winsxs\Manifests\amd64_394a48371f62c18bd95bfc42e60d34c0_31bf3856ad364e35_6.1.7601.18673_none_17287ce80bd9c2f1.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_ad53e4d446a71d1d5c90be30851c0585_31bf3856ad364e35_6.1.7601.22880_none_f38121b47cd0193a.manifest to C:\Windows\winsxs\Manifests\amd64_ad53e4d446a71d1d5c90be30851c0585_31bf3856ad364e35_6.1.7601.22880_none_f38121b47cd0193a.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_d7a5d6fb6403b65b030ce136d6c6934d_31bf3856ad364e35_6.1.7601.22880_none_bbe5c522cd8ca6d5.manifest to C:\Windows\winsxs\Manifests\amd64_d7a5d6fb6403b65b030ce136d6c6934d_31bf3856ad364e35_6.1.7601.22880_none_bbe5c522cd8ca6d5.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_f4c067d2ff3a9d94861438b58969945c_31bf3856ad364e35_6.1.7601.18673_none_f0134a5eda27c43b.manifest to C:\Windows\winsxs\Manifests\amd64_f4c067d2ff3a9d94861438b58969945c_31bf3856ad364e35_6.1.7601.18673_none_f0134a5eda27c43b.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.18673_none_0435732bb33bd01e.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.18673_none_0435732bb33bd01e.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.22880_none_04b14112cc643cfb.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.22880_none_04b14112cc643cfb.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-c..order-adm.resources_31bf3856ad364e35_6.1.7601.18673_en-us_46a2ac6c49be54ad.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-c..order-adm.resources_31bf3856ad364e35_6.1.7601.18673_en-us_46a2ac6c49be54ad.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\amd64_microsoft-windows-c..order-adm.resources_31bf3856ad364e35_6.1.7601.22880_en-us_471e7a5362e6c18a.manifest to C:\Windows\winsxs\Manifests\amd64_microsoft-windows-c..order-adm.resources_31bf3856ad364e35_6.1.7601.22880_en-us_471e7a5362e6c18a.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.18673_none_a816d7a7fade5ee8.manifest to C:\Windows\winsxs\Manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.18673_none_a816d7a7fade5ee8.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\Manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.22880_none_a892a58f1406cbc5.manifest to C:\Windows\winsxs\Manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.1.7601.22880_none_a892a58f1406cbc5.manifest.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9\mstscax.dll.mui to C:\Windows\winsxs\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9\mstscax.dll.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\aaclient.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\aaclient.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\mstscax.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\mstscax.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\tsgqec.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb\tsgqec.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\aaclient.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\aaclient.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\mstscax.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\mstscax.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\tsgqec.dll to C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0\tsgqec.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c\mstsc.exe to C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c\mstsc.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441\mstsc.exe to C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441\mstsc.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272\mstsc.exe.mui to C:\Windows\winsxs\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272\mstsc.exe.mui.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf\rdpcorets.dll to C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf\rdpcorets.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4\rdpcorets.dll to C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4\rdpcorets.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_66ead0286fe2a693
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_23a6c740c824be85
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_231726d3af0c898a
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_67c6d3ce5782b13c
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_a80852ef10524b37
Successfully restored ownership for C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c
Successfully restored permissions on C:\Windows\winsxs\wow64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_a778b281f73a163c
Successfully restored ownership for C:\Windows\winsxs\Manifests
Successfully restored permissions on C:\Windows\winsxs\Manifests
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..tivexcore.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3096bac284017c9
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.22787_none_7fc562c480822fbb
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.1.7601.18581_none_7f35c2576769fac0
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.22787_none_9db3a89cdbf1893c
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..minalservicesclient_31bf3856ad364e35_7.1.7601.18581_none_9d24082fc2d95441
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-t..cesclient.resources_31bf3856ad364e35_7.1.7601.18581_en-us_c3e56f520fe02272
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.22787_none_7f6585abc2a925cf
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-r..s-regkeys-component_31bf3856ad364e35_7.1.7601.18581_none_7ed5e53ea990f0d4
Trace::
Failed to trace component amd64_cfd23a1fa598d8a545e1caaa164ce31b_31bf3856ad364e35_6.1.7601.18783_none_234fe9088b0a8bde with return code -3.
Failed to trace component amd64_1a28fe414ca58128586df3603c0fd26e_31bf3856ad364e35_6.1.7601.18783_none_3f3f6a02fe4ded2a with return code -3.
Failed to trace component amd64_5418e77465bca5af16d03a8e56d75dc3_31bf3856ad364e35_6.1.7601.18783_none_0f399e230afaaa2a with return code -3.
Failed to trace component amd64_6d5ab785b7a3dca68f662fac740b646f_31bf3856ad364e35_6.1.7601.18783_none_7e78a1cceb79de7f with return code -3.
Failed to trace component amd64_d95a65e8bca8c20b83f25a49791ad445_31bf3856ad364e35_6.1.7601.18783_none_c5035c570ba85bd6 with return code -3.
Failed to trace component amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2 with return code -3.
Failed to trace component amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d with return code -3.
Failed to trace component amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285 with return code -3.
Failed to trace component amd64_microsoft-windows-c..at-appraiser-logger_31bf3856ad364e35_6.1.7601.18783_none_2d9d36a453c5ebf5 with return code -3.
Failed to trace component amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c with return code -3.
Currently storing 205 datablocks.
Finish time: 2016-12-14 17:28:22.790
Script hash: LROD4ZOmPY7/7f3uP4oMS9lRaIlQkqEcJ2XRuronRjY=
Yes, this is progress :)
I'll need to take a look at the components hive to trace those manifests.
Please manually upload the components hive by following these instructions:
Upload Components Hive
  1. Navigate to C:\Windows\System32\config
  2. Right-click on the current COMPONENTS file and select copy
  3. Right-click on your Desktop and select paste
  4. Right-click on the COMPONENTS file on your Desktop and select Send To -> Compressed (zipped) Folder
  5. Upload the zip from your Desktop to a file sharing service such as DropBox, OneDrive, SendSpace, etc. and include the link with your reply.
View attachment SFCFix.zip
Windows Update Manifest Replacement
  1. Please download the attached file, Packs.zip and save this to your Desktop.
  2. Right-click on the file and select Extract All...
  3. Tick the box labelled Show extracted files when complete then click Extract
  4. A window will open showing the folder Manifests
  5. Open the Manifests folder and copy the files into the following folder
    C:\Windows\Temp\CheckSur\Winsxs\Manifests
  6. Run the System Update Readiness Tool (SURT) again.
  7. When the SURT finishes installing, copy (Ctrl + C) and paste (Ctrl + V) the contents of the SURT log into your next post please:
    C:\Windows\Logs\CBS\CheckSUR.log
View attachment Packs.zip
 SFCFix version 3.0.0.0 by niemiro.Start time: 2016-12-19 22:34:35.682
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ceba968b8b3..7ba17f7ef06_31bf3856ad364e35_6.1.7601.23418_0b4fba10cbaf818a.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ceba968b8b3..7ba17f7ef06_31bf3856ad364e35_6.1.7601.23418_0b4fba10cbaf818a.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ceba968b8b3..7ba17f7ef06_31bf3856ad364e35_6.1.7601.23418_0b4fba10cbaf818a.
Currently storing 33 datablocks.
Finish time: 2016-12-19 22:34:37.036
Script hash: ylBs7Wm/2Ny5vPMffWTvqD8QgdbEJYIDfDjYOMwMYJI=
Something happened with the Checksur.log. I did the SURT and I looked at the log and saw the manifests got fixed. However after I restarted the computer, everything in my CBS folder was gone before I could copy the log.
Once SFCFix has completed, please run SURT again and attach CheckSUR.log with your reply.
 SFCFix version 3.0.0.0 by niemiro.Start time: 2016-12-21 10:16:42.650
Using .zip script file at C:\Users\Brandon\Downloads\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_a28dc372b6b040d3
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_60732c1468f865c8
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_67faabfb25564e5a
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-security-schannel_31bf3856ad364e35_6.1.7601.23418_none_8b1e6766b95d6117
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_e5bb092bc6a54d6e
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_c1defa9a6048366c
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_900a94ac18ae9af0
Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_fcc60199ba661304
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aeinv.mof
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aitstatic.exe
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l1-1-1.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l4-1-0.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l1-1-0.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l2-1-0.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-ole32-l1-1-1.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-user32-l1-1-1.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-version-l1-1-0.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.inf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\aeinv.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatResources.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat32.txt
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat64.txt
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude32.txt
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude64.txt
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\QueryAppBlock.exe
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.ini
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wicainventory.exe
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_a28dc372b6b040d3\rpchttp.dll to C:\Windows\WinSxS\x86_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_a28dc372b6b040d3\rpchttp.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_60732c1468f865c8\ncrypt.dll to C:\Windows\WinSxS\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_60732c1468f865c8\ncrypt.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_67faabfb25564e5a\cryptbase.dll to C:\Windows\WinSxS\x86_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_67faabfb25564e5a\cryptbase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\acwow64.dll to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\acwow64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\instnm.exe to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\instnm.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\ntvdm64.dll to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\ntvdm64.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\setup16.exe to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\setup16.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\user.exe to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\user.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\wow32.dll to C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f\wow32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-security-schannel_31bf3856ad364e35_6.1.7601.23418_none_8b1e6766b95d6117\schannel.dll to C:\Windows\WinSxS\wow64_microsoft-windows-security-schannel_31bf3856ad364e35_6.1.7601.23418_none_8b1e6766b95d6117\schannel.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_e5bb092bc6a54d6e\msv1_0.dll to C:\Windows\WinSxS\wow64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_e5bb092bc6a54d6e\msv1_0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_c1defa9a6048366c\ntdll.dll to C:\Windows\WinSxS\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_c1defa9a6048366c\ntdll.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_900a94ac18ae9af0\KernelBase.dll to C:\Windows\WinSxS\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_900a94ac18ae9af0\KernelBase.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_fcc60199ba661304\kernel32.dll to C:\Windows\WinSxS\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_fcc60199ba661304\kernel32.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\acmigration.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\acmigration.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aeinv.mof to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aeinv.mof.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aitstatic.exe to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aitstatic.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l1-1-1.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l1-1-1.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l4-1-0.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l4-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l1-1-0.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l2-1-0.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l2-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-ole32-l1-1-1.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-ole32-l1-1-1.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-user32-l1-1-1.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-user32-l1-1-1.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-version-l1-1-0.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-version-l1-1-0.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\appraiser.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\appraiser.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\appraiser.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\appraiser.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\compatprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\compatprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\devinv.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\devinv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\diagtrack.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\diagtrack.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\diagtrackrunner.exe to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\diagtrackrunner.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismapi.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismapi.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismcore.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismcore.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismcoreps.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismcoreps.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismprov.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\dismprov.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\ffuprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\ffuprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\folderprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\folderprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\frxmain.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\frxmain.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\hwcompat.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\hwcompat.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\hwexclude.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\hwexclude.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\imagingprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\imagingprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\invagent.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\invagent.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\logprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\logprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.inf to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.inf.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.sys to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.sys.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\vhdprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\vhdprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\wimprovider.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\wimprovider.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aeinv.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aeinv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aepdu.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aepdu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aepic.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285\aepic.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\drvmain32.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\drvmain32.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\drvmain64.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\drvmain64.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain32.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain32.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain32runtime.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain32runtime.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain64.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain64.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain64runtime.sdb to C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c\sysmain64runtime.sdb.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\aeinv.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\aeinv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatctrl.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatctrl.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatplugin.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatplugin.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatResources.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatResources.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\cosquery.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\cosquery.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\DevInv.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\DevInv.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\DVDPlaybackCompat.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\DVDPlaybackCompat.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\GadgetCompliance.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\GadgetCompliance.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\generaltel.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\generaltel.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat32.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat32.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat64.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat64.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude32.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude32.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude64.txt to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude64.txt.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\MediaCenterCompat.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\MediaCenterCompat.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\QueryAppBlock.exe to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\QueryAppBlock.exe.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\SBCompatPlugin.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\SBCompatPlugin.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\sdbapiu.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\sdbapiu.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\setupcompat.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\setupcompat.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\TouchCompat.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\TouchCompat.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wdscore.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wdscore.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.dll to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.dll.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.ini to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.ini.
Successfully copied file C:\Users\Brandon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wicainventory.exe to C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wicainventory.exe.
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_a28dc372b6b040d3
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-rpc-http_31bf3856ad364e35_6.1.7601.23418_none_a28dc372b6b040d3
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_60732c1468f865c8
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23418_none_60732c1468f865c8
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_67faabfb25564e5a
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-cryptbase_31bf3856ad364e35_6.1.7601.23418_none_67faabfb25564e5a
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23418_none_d12de4623b69bc1f
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-security-schannel_31bf3856ad364e35_6.1.7601.23418_none_8b1e6766b95d6117
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-security-schannel_31bf3856ad364e35_6.1.7601.23418_none_8b1e6766b95d6117
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_e5bb092bc6a54d6e
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-security-ntlm_31bf3856ad364e35_6.1.7601.23418_none_e5bb092bc6a54d6e
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_c1defa9a6048366c
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-ntdll_31bf3856ad364e35_6.1.7601.23418_none_c1defa9a6048366c
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_900a94ac18ae9af0
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-kernelbase_31bf3856ad364e35_6.1.7601.23418_none_900a94ac18ae9af0
Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_fcc60199ba661304
Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-kernel32_31bf3856ad364e35_6.1.7601.23418_none_fcc60199ba661304
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aeinv.mof
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aeinv.mof
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aitstatic.exe
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\aitstatic.exe
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l1-1-1.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l1-1-1.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l4-1-0.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-advapi32-l4-1-0.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l1-1-0.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l1-1-0.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l2-1-0.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-kernel32-l2-1-0.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-ole32-l1-1-1.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-ole32-l1-1-1.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-user32-l1-1-1.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-user32-l1-1-1.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-version-l1-1-0.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\Api-ms-win-downlevel-version-l1-1-0.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.inf
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.inf
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..xperience-inventory_31bf3856ad364e35_6.1.7601.18783_none_e822d2a9e5b05df2\nxquery.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.18783_none_cf4194e999e1d285
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..ence-telemetry-sdbs_31bf3856ad364e35_6.1.7601.18783_none_65fd219c60d6ea0c
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\aeinv.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\aeinv.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatResources.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\compatResources.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat32.txt
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat32.txt
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat64.txt
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwcompat64.txt
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude32.txt
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude32.txt
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude64.txt
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\hwexclude64.txt
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\QueryAppBlock.exe
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\QueryAppBlock.exe
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.ini
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wica.ini
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wicainventory.exe
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-a..de-compat-telemetry_31bf3856ad364e35_6.1.7601.18783_none_e5857da4102edc1d\wicainventory.exe
Currently storing 66 datablocks.
Finish time: 2016-12-21 10:16:57.733
Script hash: AsW83T5hlt5GMm/QkARsv22Nk+DzM+xlhb+PLnJ91FU=
Thank you so much, I appreciate the help.
Excellent, the SURT log is clear.
Let's verify with SFC.
SFC Scan
  1. Click on the Start
  4. This will create a file, cbs.txt on your Desktop. Please zip and attach this to your next post.
CORRUPT: C:\Windows\WinSxS\x86_netfx35cdf-csd_cdf_installer_31bf3856ad364e35_6.1.7601.23403_none_5af6bd41a34e2ed6\WFServicesReg.exe
CORRUPT: C:\Windows\WinSxS\x86_wcf-m_sm_cfg_ins_exe_31bf3856ad364e35_6.1.7601.23403_none_02bc010c947ea6ec\SMConfigInstaller.exe
CORRUPT: C:\Windows\WinSxS\x86_wcf-m_sm_evt_dll_vista_31bf3856ad364e35_6.1.7601.23403_none_7b04d5e10fba5d14\ServiceModelEvents.dll
CORRUPT: C:\Windows\WinSxS\x86_wcf-m_sm_ins_rc_dll_31bf3856ad364e35_6.1.7601.23403_none_cb96ea53c11d5fa7\ServiceModelInstallRC.dll
CORRUPT: C:\Windows\WinSxS\x86_wcf-m_svc_mon_sup_dll_31bf3856ad364e35_6.1.7601.23403_none_a878aa49c2f7275e\ServiceMonikerSupport.dll
CORRUPT: C:\Windows\WinSxS\amd64_infocard_b77a5c561934e089_6.1.7601.23403_none_416c0032da5b2c5b\infocard.exe
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-e..rding-adm.resources_31bf3856ad364e35_7.3.7601.1023_en-us_e44042ebe822e45b\EventForwarding.adml
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-inetres-adm_31bf3856ad364e35_11.2.9600.18537_none_d0dcb858ace8c2da\inetres.admx
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-inetres-adm.resources_31bf3856ad364e35_11.2.9600.18537_en-us_51eb407c9291503b\InetRes.adml
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_7.3.7601.1023_en-us_18cf15f2fcc2041a\WindowsRemoteManagement.adml
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-w..emotemanagement-adm_31bf3856ad364e35_7.3.7601.1023_none_62346fbed594d26d\WindowsRemoteManagement.admx
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-w..pdate-adm.resources_31bf3856ad364e35_7.6.7601.23453_en-us_96ebaa7897800f3e\WindowsUpdate.adml
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-windowsupdate-adm_31bf3856ad364e35_7.6.7601.23453_none_a451c34ee77cc779\WindowsUpdate.admx
CORRUPT: C:\Windows\WinSxS\amd64_microsoft-windows-winrs-adm.resources_31bf3856ad364e35_7.3.7601.1023_en-us_508e765c3022cee7\WindowsRemoteShell.adml
CORRUPT: C:\Windows\WinSxS\amd64_microsoft.transactions.bridge.dtc_b03f5f7f11d50a3a_6.1.7601.23403_none_65055d5154b75658\Microsoft.Transactions.Bridge.Dtc.dll
CORRUPT: C:\Windows\WinSxS\amd64_netfx35linq-datasvcutil_31bf3856ad364e35_6.1.7601.23403_none_ee101eacccac6856\DataSvcUtil.exe
CORRUPT: C:\Windows\WinSxS\amd64_netfx35cdf-csd_cdf_installer_31bf3856ad364e35_6.1.7601.23403_none_b71558c55baba00c\WFServicesReg.exe
CORRUPT: C:\Windows\WinSxS\amd64_wcf-servicemodelreg_b03f5f7f11d50a3a_6.1.7601.23403_none_2a2de23f34f6d04c\ServiceModelReg.exe
CORRUPT: C:\Windows\WinSxS\amd64_wcf-system.runtime.serialization.ref_b03f5f7f11d50a3a_6.1.7601.23403_none_424a33b08e8c1ddc\System.Runtime.Serialization.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-smdiagnostics_b03f5f7f11d50a3a_6.1.7601.23403_none_df1e6230da1533aa\SMdiagnostics.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-system.servicemodel.washosting_b03f5f7f11d50a3a_6.1.7601.23403_none_eb72a03960a2a03a\System.ServiceModel.WasHosting.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-m_svc_mon_sup_dll_31bf3856ad364e35_6.1.7601.23403_none_049745cd7b549894\ServiceMonikerSupport.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-system.servicemodel.ref_b03f5f7f11d50a3a_6.1.7601.23403_none_5ebc2cd733a1a85c\System.ServiceModel.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-m_sm_evt_dll_vista_31bf3856ad364e35_6.1.7601.23403_none_d7237164c817ce4a\ServiceModelEvents.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-smsvchost_b03f5f7f11d50a3a_6.1.7601.23403_none_b0f7bc4d24c6e892\SMSvcHost.exe
CORRUPT: C:\Windows\WinSxS\amd64_wcf-m_sm_ins_rc_dll_31bf3856ad364e35_6.1.7601.23403_none_27b585d7797ad0dd\ServiceModelInstallRC.dll
CORRUPT: C:\Windows\WinSxS\amd64_wcf-m_sm_cfg_ins_exe_31bf3856ad364e35_6.1.7601.23403_none_5eda9c904cdc1822\SMConfigInstaller.exe
CORRUPT: C:\Windows\WinSxS\msil_datasvcutil_b77a5c561934e089_6.1.7601.23403_none_d06f803cd3cc8fbd\DataSvcUtil.exe
CORRUPT: C:\Windows\WinSxS\msil_servicemodelreg_b03f5f7f11d50a3a_6.1.7601.23403_none_085a8c7fd251e7ba\ServiceModelReg.exe
CORRUPT: C:\Windows\WinSxS\msil_system.servicemodel.ref_b77a5c561934e089_6.1.7601.23403_none_29f3a1e0e8ff7f7c\System.ServiceModel.dll
CORRUPT: C:\Windows\WinSxS\msil_smdiagnostics_b77a5c561934e089_6.1.7601.23403_none_5c2023d3864db1a0\SMdiagnostics.dll
CORRUPT: C:\Windows\WinSxS\msil_system.runtime.serialization.ref_b77a5c561934e089_6.1.7601.23403_none_8fb095ea8e82a606\System.Runtime.Serialization.dll
CORRUPT: C:\Windows\WinSxS\msil_smsvchost_b03f5f7f11d50a3a_6.1.7601.23403_none_cfe7968f2abd3a58\SMSvcHost.exe
CORRUPT: C:\Windows\WinSxS\msil_system.servicemodel.washosting_b77a5c561934e089_6.1.7601.23403_none_7b9ce28bb7aa20a6\System.ServiceModel.WasHosting.dll
CORRUPT: C:\Windows\WinSxS\x86_infocard_b77a5c561934e089_6.1.7601.23403_none_89193709eed75561\infocard.exe
CORRUPT: C:\Windows\WinSxS\x86_microsoft.transactions.bridge.dtc_b03f5f7f11d50a3a_6.1.7601.23403_none_acb2942869337f5e\Microsoft.Transactions.Bridge.Dtc.dll
SFC Scan
