Hello,
Thank you accepting me in your forum
when i mahe an sfc Scanow Windows find errors it can solve...
I try with the DISM command but it says it s reparable but at the end xwhen i try to repair it failed again.
I use SFC FIX : same result
Windows don't find the necessary files to repair...
I get this log :
Start time: 2021-03-26 14:10:26.263
Microsoft Windows 10 Build 19041 - amd64
CBS & SFC total detected corruption count: 16
Finish time: 2021-03-26 14:24:35.284
I am not able to do more...
Can you help me to repair
I am not a developper abd have too limited knowledge togo further...
Thank's in advance
The full CBS Log is just here :
2021-03-24 11:46:59, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 11:46:59, Info CBS TI: Last boot time: 2021-03-24 11:35:03.500
2021-03-24 11:46:59, Info CBS Starting TrustedInstaller initialization.
2021-03-24 11:46:59, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 11:46:59, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 11:46:59, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 11:46:59, Info CBS Ending TrustedInstaller initialization.
2021-03-24 11:46:59, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 11:46:59, Info CBS TrustedInstaller service starts successfully.
2021-03-24 11:46:59, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 11:46:59, Info CBS Startup processing thread terminated normally
2021-03-24 11:46:59, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 11:46:59, Info CBS Starting TiWorker initialization.
2021-03-24 11:46:59, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 11:46:59, Info CBS Ending TiWorker initialization.
2021-03-24 11:46:59, Info CBS Starting the TiWorker main loop.
2021-03-24 11:46:59, Info CBS TiWorker starts successfully.
2021-03-24 11:46:59, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 11:46:59, Info CBS Universal Time is: 2021-03-24 10:46:59.609
2021-03-24 11:46:59, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 11:46:59, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 11:46:59, Info CSI 00000001@2021/3/24:10:46:59.609 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 11:46:59, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 11:46:59, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 11:46:59, Info CBS NonStart: Set pending store consistency check.
2021-03-24 11:46:59, Info CBS Offline image is read-only
2021-03-24 11:46:59, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\SOFTWARE'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\SYSTEM'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\SECURITY'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\SAM'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\COMPONENTS'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: DRIVERS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/DRIVERS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\DRIVERS'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\System32\config\DEFAULT'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/Users/Default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\Users\Default\ntuser.dat'.
2021-03-24 11:46:59, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\WINDOWS\system32\smi\store\Machine\schema.dat'.
2021-03-24 11:46:59, Info CSI 00000002 CSI Store 1441881782704 initialized
2021-03-24 11:46:59, Info CBS Session: 5484_716296 initialized by client SPP, external staging directory: (null), external registry directory: (null)
2021-03-24 11:46:59, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 11:47:00, Info CBS Package Format: PSFX
2021-03-24 11:47:00, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SOFTWARE
2021-03-24 11:47:00, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SYSTEM
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SECURITY
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/SAM
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/COMPONENTS
2021-03-24 11:47:00, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 11:47:00, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/DRIVERS
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/System32/config/DEFAULT
2021-03-24 11:47:00, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/Users/Default/ntuser.dat
2021-03-24 11:47:00, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy3/WINDOWS/system32/smi/store/Machine/schema.dat
2021-03-24 11:47:00, Info CSI 00000003 Direct SIL provider: Number of files opened: 4.
2021-03-24 11:47:10, Info CBS Offline image is read-only
2021-03-24 11:47:10, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\SOFTWARE'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\SYSTEM'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\SECURITY'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\SAM'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\COMPONENTS'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: DRIVERS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/DRIVERS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\DRIVERS'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\System32\config\DEFAULT'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/Users/Default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\Users\Default\ntuser.dat'.
2021-03-24 11:47:10, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy2\WINDOWS\system32\smi\store\Machine\schema.dat'.
2021-03-24 11:47:10, Info CSI 00000004 CSI Store 1441881784144 initialized
2021-03-24 11:47:10, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 11:47:10, Info CBS Session: 5484_727140 initialized by client SPP, external staging directory: (null), external registry directory: (null)
2021-03-24 11:47:10, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 11:47:10, Info CBS Package Format: PSFX
2021-03-24 11:47:10, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SOFTWARE
2021-03-24 11:47:10, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SYSTEM
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SECURITY
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/SAM
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/COMPONENTS
2021-03-24 11:47:10, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 11:47:10, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/DRIVERS
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/System32/config/DEFAULT
2021-03-24 11:47:10, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/Users/Default/ntuser.dat
2021-03-24 11:47:10, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy2/WINDOWS/system32/smi/store/Machine/schema.dat
2021-03-24 11:47:10, Info CSI 00000005 Direct SIL provider: Number of files opened: 4.
2021-03-24 11:49:11, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 11:49:11, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 11:49:11, Info CBS Execution Engine Finalize
2021-03-24 11:49:11, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 11:49:11, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 11:49:11, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 11:49:11, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 11:49:11, Info CBS Ending the TiWorker main loop.
2021-03-24 11:49:11, Info CBS Starting TiWorker finalization.
2021-03-24 11:49:11, Info CBS CBS Engine already deactivated
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 11:49:11, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 11:49:11, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 11:49:11, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 11:49:11, Info CBS Ending TiWorker finalization.
2021-03-24 11:49:11, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 11:49:11, Info CBS Starting TrustedInstaller finalization.
2021-03-24 11:49:11, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 11:49:11, Info CBS Ending TrustedInstaller finalization.
2021-03-24 12:54:48, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 12:54:48, Info CBS TI: Last boot time: 2021-03-24 11:35:03.500
2021-03-24 12:54:48, Info CBS Starting TrustedInstaller initialization.
2021-03-24 12:54:48, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 12:54:48, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 12:54:48, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 12:54:48, Info CBS Ending TrustedInstaller initialization.
2021-03-24 12:54:48, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 12:54:48, Info CBS TrustedInstaller service starts successfully.
2021-03-24 12:54:48, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 12:54:48, Info CBS Startup processing thread terminated normally
2021-03-24 12:54:48, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 12:54:48, Info CBS Starting TiWorker initialization.
2021-03-24 12:54:48, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 12:54:48, Info CBS Ending TiWorker initialization.
2021-03-24 12:54:48, Info CBS Starting the TiWorker main loop.
2021-03-24 12:54:48, Info CBS TiWorker starts successfully.
2021-03-24 12:54:48, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 12:54:48, Info CBS Universal Time is: 2021-03-24 11:54:48.285
2021-03-24 12:54:48, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 12:54:48, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 12:54:48, Info CSI 00000001@2021/3/24:11:54:48.301 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 12:54:48, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 12:54:48, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 12:54:48, Info CBS NonStart: Set pending store consistency check.
2021-03-24 12:54:48, Info CBS Session: 30875812_2105571303 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-24 12:54:48, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~amd64~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-24 12:54:48, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-24 12:54:48, Info CBS Failed to create open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-24 12:54:48, Info CBS Failed to OpenPackage using worker session [HRESULT = 0x800f0805]
2021-03-24 12:54:48, Info CBS Session: 30875812_2105571304 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-24 12:54:48, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~x86~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33D6CF13-224E-459B-AD4F-AF8C5E3CC469}, revision: 202
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Mapping_Package_for_KB3089226_af-ZA_amd64~31bf3856ad364e35~amd64~~10.0.10240.0, ApplicableState: 0, CurrentState:0
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{11DC1965-36D9-4985-8BC6-6DCB1526C10E}, revision: 200
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4580325~31bf3856ad364e35~amd64~~10.0.1.0, ApplicableState: 80, CurrentState:112
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{5F4C3660-7683-400D-8F04-A9878E50260C}, revision: 201
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Package_for_DotNetRollup~31bf3856ad364e35~amd64~~10.0.4341.2, ApplicableState: 112, CurrentState:112
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{7264A822-A992-438E-95EF-2EE8F7211AD0}, revision: 203
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4577586~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 112, CurrentState:112
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33238534-6440-4232-9A18-E7A602E51BE6}, revision: 201
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Package_for_KB3064238~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 0, CurrentState:0
2021-03-24 12:54:49, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{C7F1C3C6-EA84-4C63-ACDF-0C45AF060BD5}, revision: 204
2021-03-24 12:54:49, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4589212~31bf3856ad364e35~amd64~~10.0.2.4, ApplicableState: 112, CurrentState:112
2021-03-24 12:56:50, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 12:56:50, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 12:56:50, Info CBS Execution Engine Finalize
2021-03-24 12:56:50, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 12:56:50, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 12:56:50, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 12:56:50, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 12:56:50, Info CBS Ending the TiWorker main loop.
2021-03-24 12:56:50, Info CBS Starting TiWorker finalization.
2021-03-24 12:56:50, Info CBS CBS Engine already deactivated
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 12:56:50, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 12:56:50, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 12:56:50, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 12:56:50, Info CBS Ending TiWorker finalization.
2021-03-24 12:56:50, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 12:56:50, Info CBS Starting TrustedInstaller finalization.
2021-03-24 12:56:50, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 12:56:50, Info CBS Ending TrustedInstaller finalization.
2021-03-24 13:01:06, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 13:01:06, Info CBS TI: Last boot time: 2021-03-24 11:35:03.500
2021-03-24 13:01:06, Info CBS Starting TrustedInstaller initialization.
2021-03-24 13:01:06, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 13:01:06, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 13:01:06, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 13:01:06, Info CBS Ending TrustedInstaller initialization.
2021-03-24 13:01:06, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 13:01:06, Info CBS TrustedInstaller service starts successfully.
2021-03-24 13:01:06, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 13:01:06, Info CBS Startup processing thread terminated normally
2021-03-24 13:01:06, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 13:01:06, Info CBS Starting TiWorker initialization.
2021-03-24 13:01:06, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 13:01:06, Info CBS Ending TiWorker initialization.
2021-03-24 13:01:06, Info CBS Starting the TiWorker main loop.
2021-03-24 13:01:06, Info CBS TiWorker starts successfully.
2021-03-24 13:01:06, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 13:01:06, Info CBS Universal Time is: 2021-03-24 12:01:06.626
2021-03-24 13:01:06, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 13:01:06, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 13:01:06, Info CSI 00000001@2021/3/24:12:01:06.626 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 13:01:06, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 13:01:06, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 13:01:06, Info CBS NonStart: Set pending store consistency check.
2021-03-24 13:01:06, Info CBS Offline image is read-only
2021-03-24 13:01:06, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\SOFTWARE'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\SYSTEM'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\SECURITY'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\SAM'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\COMPONENTS'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: DRIVERS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/DRIVERS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\DRIVERS'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\System32\config\DEFAULT'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/Users/Default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\Users\Default\ntuser.dat'.
2021-03-24 13:01:06, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy19\WINDOWS\system32\smi\store\Machine\schema.dat'.
2021-03-24 13:01:06, Info CSI 00000002 CSI Store 1785612919456 initialized
2021-03-24 13:01:06, Info CBS Session: 4456_5163296 initialized by client SPP, external staging directory: (null), external registry directory: (null)
2021-03-24 13:01:06, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 13:01:07, Info CBS Package Format: PSFX
2021-03-24 13:01:07, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SOFTWARE
2021-03-24 13:01:07, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SYSTEM
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SECURITY
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/SAM
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/COMPONENTS
2021-03-24 13:01:07, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 13:01:07, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/DRIVERS
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/System32/config/DEFAULT
2021-03-24 13:01:07, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/Users/Default/ntuser.dat
2021-03-24 13:01:07, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy19/WINDOWS/system32/smi/store/Machine/schema.dat
2021-03-24 13:01:07, Info CSI 00000003 Direct SIL provider: Number of files opened: 4.
2021-03-24 13:03:07, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 13:03:07, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 13:03:07, Info CBS Execution Engine Finalize
2021-03-24 13:03:07, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 13:03:07, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 13:03:07, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 13:03:07, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 13:03:07, Info CBS Ending the TiWorker main loop.
2021-03-24 13:03:07, Info CBS Starting TiWorker finalization.
2021-03-24 13:03:07, Info CBS CBS Engine already deactivated
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 13:03:07, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 13:03:07, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 13:03:07, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 13:03:07, Info CBS Ending TiWorker finalization.
2021-03-24 13:03:07, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 13:03:07, Info CBS Starting TrustedInstaller finalization.
2021-03-24 13:03:07, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 13:03:07, Info CBS Ending TrustedInstaller finalization.
2021-03-24 13:35:19, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 13:35:19, Info CBS TI: Last boot time: 2021-03-24 11:35:03.500
2021-03-24 13:35:19, Info CBS Starting TrustedInstaller initialization.
2021-03-24 13:35:19, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 13:35:19, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 13:35:19, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 13:35:19, Info CBS Ending TrustedInstaller initialization.
2021-03-24 13:35:19, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 13:35:19, Info CBS TrustedInstaller service starts successfully.
2021-03-24 13:35:19, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 13:35:19, Info CBS Startup processing thread terminated normally
2021-03-24 13:35:19, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 13:35:19, Info CBS Starting TiWorker initialization.
2021-03-24 13:35:19, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 13:35:19, Info CBS Ending TiWorker initialization.
2021-03-24 13:35:19, Info CBS Starting the TiWorker main loop.
2021-03-24 13:35:19, Info CBS TiWorker starts successfully.
2021-03-24 13:35:19, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 13:35:19, Info CBS Universal Time is: 2021-03-24 12:35:19.018
2021-03-24 13:35:19, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 13:35:19, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 13:35:19, Info CSI 00000001@2021/3/24:12:35:19.018 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 13:35:19, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 13:35:19, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 13:35:19, Info CBS NonStart: Set pending store consistency check.
2021-03-24 13:35:19, Info CBS Session: 30875818_643093306 initialized by client LanguageSettings, external staging directory: (null), external registry directory: (null)
2021-03-24 13:35:19, Info CBS Session: 30875818_643093307 initialized by client LanguageSettings, external staging directory: (null), external registry directory: (null)
2021-03-24 13:35:19, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 13:35:19, Info CBS Package Format: PSFX
2021-03-24 13:35:19, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 13:35:19, Info CBS Session: 30875818_644967881 initialized by client LanguageSettings, external staging directory: (null), external registry directory: (null)
2021-03-24 13:35:19, Info CBS Session: 30875818_646686642 initialized by client LanguageSettings, external staging directory: (null), external registry directory: (null)
2021-03-24 13:37:19, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 13:37:19, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 13:37:19, Info CBS Execution Engine Finalize
2021-03-24 13:37:19, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 13:37:19, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 13:37:19, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 13:37:19, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 13:37:19, Info CBS Ending the TiWorker main loop.
2021-03-24 13:37:19, Info CBS Starting TiWorker finalization.
2021-03-24 13:37:19, Info CBS CBS Engine already deactivated
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 13:37:19, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 13:37:19, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 13:37:19, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 13:37:19, Info CBS Ending TiWorker finalization.
2021-03-24 13:37:19, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 13:37:19, Info CBS Starting TrustedInstaller finalization.
2021-03-24 13:37:19, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 13:37:19, Info CBS Ending TrustedInstaller finalization.
2021-03-24 14:19:15, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 14:19:15, Info CBS TI: Last boot time: 2021-03-24 11:35:03.500
2021-03-24 14:19:15, Info CBS Starting TrustedInstaller initialization.
2021-03-24 14:19:15, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 14:19:15, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 14:19:15, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 14:19:15, Info CBS Ending TrustedInstaller initialization.
2021-03-24 14:19:15, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 14:19:15, Info CBS TrustedInstaller service starts successfully.
2021-03-24 14:19:15, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 14:19:15, Info CBS Startup processing thread terminated normally
2021-03-24 14:19:15, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 14:19:15, Info CBS Starting TiWorker initialization.
2021-03-24 14:19:15, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 14:19:15, Info CBS Ending TiWorker initialization.
2021-03-24 14:19:15, Info CBS Starting the TiWorker main loop.
2021-03-24 14:19:15, Info CBS TiWorker starts successfully.
2021-03-24 14:19:15, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 14:19:15, Info CBS Universal Time is: 2021-03-24 13:19:15.767
2021-03-24 14:19:15, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 14:19:15, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 14:19:15, Info CSI 00000001@2021/3/24:13:19:15.767 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 14:19:15, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 14:19:15, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 14:19:15, Info CBS NonStart: Set pending store consistency check.
2021-03-24 14:19:15, Info CBS Offline image is read-only
2021-03-24 14:19:15, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\SOFTWARE'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\SYSTEM'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\SECURITY'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\SAM'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\COMPONENTS'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: DRIVERS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/DRIVERS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\DRIVERS'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\System32\config\DEFAULT'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/Users/Default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\Users\Default\ntuser.dat'.
2021-03-24 14:19:15, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\WINDOWS\system32\smi\store\Machine\schema.dat'.
2021-03-24 14:19:15, Info CSI 00000002 CSI Store 2101904610416 initialized
2021-03-24 14:19:15, Info CBS Session: 2420_9852437 initialized by client SPP, external staging directory: (null), external registry directory: (null)
2021-03-24 14:19:15, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 14:19:16, Info CBS Package Format: PSFX
2021-03-24 14:19:16, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SOFTWARE
2021-03-24 14:19:16, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SYSTEM
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SECURITY
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/SAM
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/COMPONENTS
2021-03-24 14:19:16, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 14:19:16, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/DRIVERS
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/System32/config/DEFAULT
2021-03-24 14:19:16, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/Users/Default/ntuser.dat
2021-03-24 14:19:16, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy22/WINDOWS/system32/smi/store/Machine/schema.dat
2021-03-24 14:19:16, Info CSI 00000003 Direct SIL provider: Number of files opened: 4.
2021-03-24 14:21:16, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 14:21:16, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 14:21:16, Info CBS Execution Engine Finalize
2021-03-24 14:21:16, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 14:21:16, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 14:21:16, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 14:21:16, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 14:21:16, Info CBS Ending the TiWorker main loop.
2021-03-24 14:21:16, Info CBS Starting TiWorker finalization.
2021-03-24 14:21:16, Info CBS CBS Engine already deactivated
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 14:21:16, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 14:21:16, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 14:21:16, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 14:21:16, Info CBS Ending TiWorker finalization.
2021-03-24 14:21:16, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 14:21:16, Info CBS Starting TrustedInstaller finalization.
2021-03-24 14:21:16, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 14:21:16, Info CBS Ending TrustedInstaller finalization.
2021-03-24 14:26:40, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-24 14:26:40, Info CBS TI: Last boot time: 2021-03-24 14:25:08.500
2021-03-24 14:26:40, Info CBS Starting TrustedInstaller initialization.
2021-03-24 14:26:40, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-24 14:26:40, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-24 14:26:40, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 14:26:40, Info CBS Ending TrustedInstaller initialization.
2021-03-24 14:26:40, Info CBS Starting the TrustedInstaller main loop.
2021-03-24 14:26:40, Info CBS TrustedInstaller service starts successfully.
2021-03-24 14:26:40, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-24 14:26:40, Info CBS Startup processing thread terminated normally
2021-03-24 14:26:40, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-24 14:26:40, Info CBS Starting TiWorker initialization.
2021-03-24 14:26:40, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-24 14:26:40, Info CBS Ending TiWorker initialization.
2021-03-24 14:26:40, Info CBS Starting the TiWorker main loop.
2021-03-24 14:26:40, Info CBS TiWorker starts successfully.
2021-03-24 14:26:40, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-24 14:26:40, Info CBS Universal Time is: 2021-03-24 13:26:40.214
2021-03-24 14:26:40, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-24 14:26:40, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-24 14:26:40, Info CSI 00000001@2021/3/24:13:26:40.230 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-24 14:26:40, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-24 14:26:40, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 14:26:40, Info CBS NonStart: Set pending store consistency check.
2021-03-24 14:26:40, Info CBS Offline image is read-only
2021-03-24 14:26:40, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\SOFTWARE'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\SYSTEM'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\SECURITY'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\SAM'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\COMPONENTS'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: DRIVERS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/DRIVERS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\DRIVERS'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\System32\config\DEFAULT'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/Users/Default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\Users\Default\ntuser.dat'.
2021-03-24 14:26:40, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy20\WINDOWS\system32\smi\store\Machine\schema.dat'.
2021-03-24 14:26:40, Info CSI 00000002 CSI Store 2027850012512 initialized
2021-03-24 14:26:40, Info CBS Session: 11696_91921 initialized by client SPP, external staging directory: (null), external registry directory: (null)
2021-03-24 14:26:40, Info CBS Appl:Feature On Demand package without explicit comparator, using GE on build version
2021-03-24 14:26:40, Info CBS Package Format: PSFX
2021-03-24 14:26:40, Info CBS Appl:LCU package and revision compare set to explicit
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SOFTWARE
2021-03-24 14:26:40, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SYSTEM
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SECURITY
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/SAM
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/COMPONENTS
2021-03-24 14:26:40, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2021-03-24 14:26:40, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/DRIVERS
2021-03-24 14:26:40, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/System32/config/DEFAULT
2021-03-24 14:26:41, Info CBS Force unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/Users/Default/ntuser.dat
2021-03-24 14:26:41, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy20/WINDOWS/system32/smi/store/Machine/schema.dat
2021-03-24 14:26:41, Info CSI 00000003 Direct SIL provider: Number of files opened: 4.
2021-03-24 14:28:41, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-03-24 14:28:41, Info CBS TiWorker signaled for shutdown, going to exit.
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: ExecutionEngineFinalize
2021-03-24 14:28:41, Info CBS Execution Engine Finalize
2021-03-24 14:28:41, Info CBS Deleting the contents of directory: \\?\C:\WINDOWS\CbsTemp
2021-03-24 14:28:41, Info CBS Deletion of: \\?\C:\WINDOWS\CbsTemp successful
2021-03-24 14:28:41, Info CBS Lock: Lock removed: TiWorkerClassFactory, level: 30, total lock:3
2021-03-24 14:28:41, Info CBS Lock: Lock removed: CCbsWorker, level: 5, total lock:2
2021-03-24 14:28:41, Info CBS Ending the TiWorker main loop.
2021-03-24 14:28:41, Info CBS Starting TiWorker finalization.
2021-03-24 14:28:41, Info CBS CBS Engine already deactivated
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: ComponentAnalyzerFinalize
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: PackageTrackerFinalize
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CoreResourcesUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: SessionManagerFinalize
2021-03-24 14:28:41, Info CBS Lock: Lock removed: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-24 14:28:41, Info CBS Lock: Lock removed: CCbsSessionManager, level: 11, total lock:9
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CapabilityManagerFinalize
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: PublicObjectMonitorFinalize
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: Enter vCoreInitializeLock
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: WcpUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: DrupUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CfgMgr32Unload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: DpxUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: SrUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CbsEsdUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: CbsEventUnregister
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: AppContainerUnload
2021-03-24 14:28:41, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2021-03-24 14:28:41, Info CBS Ending TiWorker finalization.
2021-03-24 14:28:41, Info CBS Ending the TrustedInstaller main loop.
2021-03-24 14:28:41, Info CBS Starting TrustedInstaller finalization.
2021-03-24 14:28:41, Info CBS Lock: Lock removed: WinlogonNotifyLock, level: 8, total lock:6
2021-03-24 14:28:41, Info CBS Ending TrustedInstaller finalization.
2021-03-26 12:28:47, Info CBS TI: --- Initializing Trusted Installer ---
2021-03-26 12:28:47, Info CBS TI: Last boot time: 2021-03-26 12:28:10.500
2021-03-26 12:28:47, Info CBS Starting TrustedInstaller initialization.
2021-03-26 12:28:47, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2021-03-26 12:28:47, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2021-03-26 12:28:47, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2021-03-26 12:28:47, Info CBS Ending TrustedInstaller initialization.
2021-03-26 12:28:47, Info CBS Starting the TrustedInstaller main loop.
2021-03-26 12:28:47, Info CBS TrustedInstaller service starts successfully.
2021-03-26 12:28:47, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-03-26 12:28:47, Info CBS Startup processing thread terminated normally
2021-03-26 12:28:47, Info CBS TI: Startup Processing completes, release startup processing lock.
2021-03-26 12:28:47, Info CBS Starting TiWorker initialization.
2021-03-26 12:28:47, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2021-03-26 12:28:47, Info CBS Ending TiWorker initialization.
2021-03-26 12:28:47, Info CBS Starting the TiWorker main loop.
2021-03-26 12:28:47, Info CBS TiWorker starts successfully.
2021-03-26 12:28:47, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2021-03-26 12:28:47, Info CBS Universal Time is: 2021-03-26 11:28:47.706
2021-03-26 12:28:47, Info CBS Loaded Servicing Stack v10.0.19041.860 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.860_none_e73d0c67262f5c28\cbscore.dll
2021-03-26 12:28:47, Info CBS Build: 19041.1.amd64fre.vb_release.191206-1406
2021-03-26 12:28:47, Info CSI 00000001@2021/3/26:11:28:47.722 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-26 12:28:47, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:9
2021-03-26 12:28:47, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:10
2021-03-26 12:28:47, Info CBS NonStart: Set pending store consistency check.
2021-03-26 12:28:47, Info CBS Session: 30876211_807914774 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-26 12:28:47, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~amd64~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:28:47, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:28:47, Info CBS Failed to create open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:28:47, Info CBS Failed to OpenPackage using worker session [HRESULT = 0x800f0805]
2021-03-26 12:28:47, Info CBS Session: 30876211_807968747 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-26 12:28:47, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~x86~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33D6CF13-224E-459B-AD4F-AF8C5E3CC469}, revision: 202
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Mapping_Package_for_KB3089226_af-ZA_amd64~31bf3856ad364e35~amd64~~10.0.10240.0, ApplicableState: 0, CurrentState:0
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{11DC1965-36D9-4985-8BC6-6DCB1526C10E}, revision: 200
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4580325~31bf3856ad364e35~amd64~~10.0.1.0, ApplicableState: 80, CurrentState:112
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{5F4C3660-7683-400D-8F04-A9878E50260C}, revision: 201
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Package_for_DotNetRollup~31bf3856ad364e35~amd64~~10.0.4341.2, ApplicableState: 112, CurrentState:112
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{7264A822-A992-438E-95EF-2EE8F7211AD0}, revision: 203
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4577586~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 112, CurrentState:112
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33238534-6440-4232-9A18-E7A602E51BE6}, revision: 201
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Package_for_KB3064238~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 0, CurrentState:0
2021-03-26 12:28:52, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{C7F1C3C6-EA84-4C63-ACDF-0C45AF060BD5}, revision: 204
2021-03-26 12:28:52, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4589212~31bf3856ad364e35~amd64~~10.0.2.4, ApplicableState: 112, CurrentState:112
2021-03-26 12:29:17, Info CBS Session: 30876211_1104632338 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-26 12:29:17, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~amd64~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:29:17, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:29:17, Info CBS Failed to create open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:29:17, Info CBS Failed to OpenPackage using worker session [HRESULT = 0x800f0805]
2021-03-26 12:29:17, Info CBS Session: 30876211_1104632339 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null)
2021-03-26 12:29:17, Info CBS InternalOpenPackage failed for Package_for_KB3025096~31bf3856ad364e35~x86~~6.4.1.0 [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33D6CF13-224E-459B-AD4F-AF8C5E3CC469}, revision: 202
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Mapping_Package_for_KB3089226_af-ZA_amd64~31bf3856ad364e35~amd64~~10.0.10240.0, ApplicableState: 0, CurrentState:0
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{11DC1965-36D9-4985-8BC6-6DCB1526C10E}, revision: 200
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4580325~31bf3856ad364e35~amd64~~10.0.1.0, ApplicableState: 80, CurrentState:112
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{5F4C3660-7683-400D-8F04-A9878E50260C}, revision: 201
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Package_for_DotNetRollup~31bf3856ad364e35~amd64~~10.0.4341.2, ApplicableState: 112, CurrentState:112
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{7264A822-A992-438E-95EF-2EE8F7211AD0}, revision: 203
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4577586~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 112, CurrentState:112
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{33238534-6440-4232-9A18-E7A602E51BE6}, revision: 201
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Package_for_KB3064238~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 0, CurrentState:0
2021-03-26 12:29:28, Info CBS WU creates the package, AppID:MoUpdateOrchestrator, UpdateID:{C7F1C3C6-EA84-4C63-ACDF-0C45AF060BD5}, revision: 204
2021-03-26 12:29:28, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4589212~31bf3856ad364e35~amd64~~10.0.2.4, ApplicableState: 112, CurrentState:112
2021-03-26 12:31:12, Info CBS TiWorker: Client requests SFP repair object.
2021-03-26 12:31:12, Info CSI 00000002@2021/3/26:11:31:12.038 WcpInitialize: wcp.dll version 10.0.19041.860 (WinBuild.160101.0800)
2021-03-26 12:31:12, Info CSI 00000003 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x4f4467def0
2021-03-26 12:31:12, Info CSI 00000004 Poqexec successfully registered in [l:12 ml:13]'SetupExecute'
2021-03-26 12:31:12, Info CSI 00000005 CSI Store 2279139595584 initialized
2021-03-26 12:31:13, Info CSI 00000006 [SR] Verifying 100 components
2021-03-26 12:31:13, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:13, Info CSI 00000008 [SR] Verify complete
2021-03-26 12:31:13, Info CSI 00000009 [SR] Verifying 100 components
2021-03-26 12:31:13, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:14, Info CSI 0000000b [SR] Verify complete
2021-03-26 12:31:14, Info CSI 0000000c [SR] Verifying 100 components
2021-03-26 12:31:14, Info CSI 0000000d [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:14, Info CSI 0000000e [SR] Verify complete
2021-03-26 12:31:14, Info CSI 0000000f [SR] Verifying 100 components
2021-03-26 12:31:14, Info CSI 00000010 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:14, Info CSI 00000011 [SR] Cannot verify component files for Avast.VC140.CRT, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:31:14, Info CSI 00000012 [SR] Cannot verify component files for Avast.VC140.MFC, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:31:14, Info CSI 00000013 [SR] Verify complete
2021-03-26 12:31:14, Error CSI 00000014@2021/3/26:11:31:14.773 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:31:14, Error CSI 00000015@2021/3/26:11:31:14.773 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:31:14, Info CBS Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:31:14, Info CBS Could not get file name for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:31:14, Info CBS Added C:\WINDOWS\Logs\CBS\CBS.log to WER report.
2021-03-26 12:31:14, Info CBS Added C:\WINDOWS\Logs\CBS\CbsPersist_20210324092635.cab to WER report.
2021-03-26 12:31:14, Info CBS Not able to add pending.xml to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2021-03-26 12:31:14, Info CBS Not able to add pending.xml.bad to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2021-03-26 12:31:14, Info CBS Not able to add poqexec.log to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2021-03-26 12:31:14, Info CBS Not able to add SCM.EVM to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2021-03-26 12:31:14, Error CSI 00000016@2021/3/26:11:31:14.882 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:31:14, Error CSI 00000017@2021/3/26:11:31:14.882 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:31:14, Info CSI 00000018 [SR] Verifying 100 components
2021-03-26 12:31:14, Info CSI 00000019 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:15, Info CSI 0000001a [SR] Verify complete
2021-03-26 12:31:15, Info CSI 0000001b [SR] Verifying 100 components
2021-03-26 12:31:15, Info CSI 0000001c [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:16, Info CSI 0000001d [SR] Verify complete
2021-03-26 12:31:16, Info CSI 0000001e [SR] Verifying 100 components
2021-03-26 12:31:16, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:16, Info CSI 00000020 [SR] Verify complete
2021-03-26 12:31:16, Info CSI 00000021 [SR] Verifying 100 components
2021-03-26 12:31:16, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:17, Info CSI 00000023 [SR] Verify complete
2021-03-26 12:31:17, Info CSI 00000024 [SR] Verifying 100 components
2021-03-26 12:31:17, Info CSI 00000025 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:19, Info CSI 00000026 [SR] Verify complete
2021-03-26 12:31:19, Info CSI 00000027 [SR] Verifying 100 components
2021-03-26 12:31:19, Info CSI 00000028 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:22, Info CSI 00000029 [SR] Verify complete
2021-03-26 12:31:22, Info CSI 0000002a [SR] Verifying 100 components
2021-03-26 12:31:22, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:26, Info CSI 0000002c [SR] Verify complete
2021-03-26 12:31:27, Info CSI 0000002d [SR] Verifying 100 components
2021-03-26 12:31:27, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:27, Info CSI 0000002f [SR] Verify complete
2021-03-26 12:31:28, Info CSI 00000030 [SR] Verifying 100 components
2021-03-26 12:31:28, Info CSI 00000031 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:28, Info CSI 00000032 [SR] Verify complete
2021-03-26 12:31:28, Info CSI 00000033 [SR] Verifying 100 components
2021-03-26 12:31:28, Info CSI 00000034 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:28, Info CSI 00000035 [SR] Verify complete
2021-03-26 12:31:28, Info CSI 00000036 [SR] Verifying 100 components
2021-03-26 12:31:28, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:30, Info CSI 00000038 CSIPERF - FilePI Queue 262ms
2021-03-26 12:31:30, Info CSI 00000039 [SR] Verify complete
2021-03-26 12:31:30, Info CSI 0000003a [SR] Verifying 100 components
2021-03-26 12:31:30, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:31, Info CSI 0000003c [SR] Verify complete
2021-03-26 12:31:31, Info CSI 0000003d [SR] Verifying 100 components
2021-03-26 12:31:31, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:31, Info CSI 0000003f [SR] Verify complete
2021-03-26 12:31:31, Info CSI 00000040 [SR] Verifying 100 components
2021-03-26 12:31:31, Info CSI 00000041 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:32, Info CSI 00000042 [SR] Verify complete
2021-03-26 12:31:32, Info CSI 00000043 [SR] Verifying 100 components
2021-03-26 12:31:32, Info CSI 00000044 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:33, Info CSI 00000045 CSIPERF - FilePI Queue 262ms
2021-03-26 12:31:33, Info CSI 00000046 [SR] Verify complete
2021-03-26 12:31:34, Info CSI 00000047 [SR] Verifying 100 components
2021-03-26 12:31:34, Info CSI 00000048 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:35, Info CSI 00000049 [SR] Verify complete
2021-03-26 12:31:35, Info CSI 0000004a [SR] Verifying 100 components
2021-03-26 12:31:35, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:36, Info CSI 0000004c [SR] Verify complete
2021-03-26 12:31:36, Info CSI 0000004d [SR] Verifying 100 components
2021-03-26 12:31:36, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:37, Info CSI 0000004f [SR] Verify complete
2021-03-26 12:31:37, Info CSI 00000050 [SR] Verifying 100 components
2021-03-26 12:31:37, Info CSI 00000051 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:38, Info CSI 00000052 [SR] Verify complete
2021-03-26 12:31:38, Info CSI 00000053 [SR] Verifying 100 components
2021-03-26 12:31:38, Info CSI 00000054 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:38, Info CSI 00000055 [SR] Verify complete
2021-03-26 12:31:38, Info CSI 00000056 [SR] Verifying 100 components
2021-03-26 12:31:38, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:39, Info CSI 00000058 CSIPERF - FilePI Queue 168ms
2021-03-26 12:31:39, Info CSI 00000059 [SR] Verify complete
2021-03-26 12:31:40, Info CSI 0000005a [SR] Verifying 100 components
2021-03-26 12:31:40, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:40, Info CSI 0000005c [SR] Verify complete
2021-03-26 12:31:40, Info CSI 0000005d [SR] Verifying 100 components
2021-03-26 12:31:40, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:41, Info CSI 0000005f [SR] Verify complete
2021-03-26 12:31:41, Info CSI 00000060 [SR] Verifying 100 components
2021-03-26 12:31:41, Info CSI 00000061 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:42, Info CSI 00000062 [SR] Verify complete
2021-03-26 12:31:42, Info CSI 00000063 [SR] Verifying 100 components
2021-03-26 12:31:42, Info CSI 00000064 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:43, Info CSI 00000065 CSIPERF - FilePI Queue 161ms
2021-03-26 12:31:43, Info CSI 00000066 [SR] Verify complete
2021-03-26 12:31:43, Info CSI 00000067 [SR] Verifying 100 components
2021-03-26 12:31:43, Info CSI 00000068 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:43, Info CSI 00000069 [SR] Verify complete
2021-03-26 12:31:43, Info CSI 0000006a [SR] Verifying 100 components
2021-03-26 12:31:43, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:44, Info CSI 0000006c [SR] Verify complete
2021-03-26 12:31:44, Info CSI 0000006d [SR] Verifying 100 components
2021-03-26 12:31:44, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:45, Info CSI 0000006f [SR] Verify complete
2021-03-26 12:31:45, Info CSI 00000070 [SR] Verifying 100 components
2021-03-26 12:31:45, Info CSI 00000071 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:45, Info CSI 00000072 [SR] Verify complete
2021-03-26 12:31:45, Info CSI 00000073 [SR] Verifying 100 components
2021-03-26 12:31:45, Info CSI 00000074 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:46, Info CSI 00000075 [SR] Verify complete
2021-03-26 12:31:46, Info CSI 00000076 [SR] Verifying 100 components
2021-03-26 12:31:46, Info CSI 00000077 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:47, Info CSI 00000078 [SR] Verify complete
2021-03-26 12:31:47, Info CSI 00000079 [SR] Verifying 100 components
2021-03-26 12:31:47, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:48, Info CSI 0000007b [SR] Verify complete
2021-03-26 12:31:48, Info CSI 0000007c [SR] Verifying 100 components
2021-03-26 12:31:48, Info CSI 0000007d [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:50, Info CSI 0000007e CSIPERF - FilePI Queue 175ms
2021-03-26 12:31:50, Info CSI 0000007f [SR] Verify complete
2021-03-26 12:31:50, Info CSI 00000080 [SR] Verifying 100 components
2021-03-26 12:31:50, Info CSI 00000081 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:50, Info CSI 00000082 [SR] Verify complete
2021-03-26 12:31:51, Info CSI 00000083 [SR] Verifying 100 components
2021-03-26 12:31:51, Info CSI 00000084 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:52, Info CSI 00000085 CSIPERF - FilePI Queue 107ms
2021-03-26 12:31:52, Info CSI 00000086 Warning: Overlap: Directory \??\C:\WINDOWS\System32\drivers\en-US\ is owned twice or has its security set twice
Original owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch amd64, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
New owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch amd64, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
2021-03-26 12:31:52, Info CSI 00000087 Warning: Overlap: Directory \??\C:\WINDOWS\System32\wbem\en-US\ is owned twice or has its security set twice
2021-03-26 12:31:52, Info CSI 00000088 Warning: Overlap: Directory \??\C:\WINDOWS\help\mui\0409\ is owned twice or has its security set twice
2021-03-26 12:31:52, Info CSI 00000089 [SR] Verify complete
2021-03-26 12:31:52, Info CSI 0000008a [SR] Verifying 100 components
2021-03-26 12:31:52, Info CSI 0000008b [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:54, Info CSI 0000008c [SR] Verify complete
2021-03-26 12:31:54, Info CSI 0000008d [SR] Verifying 100 components
2021-03-26 12:31:54, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:56, Info CSI 0000008f CSIPERF - FilePI Queue 183ms
2021-03-26 12:31:57, Info CSI 00000090 [SR] Verify complete
2021-03-26 12:31:57, Info CSI 00000091 [SR] Verifying 100 components
2021-03-26 12:31:57, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:57, Info CSI 00000093 [SR] Verify complete
2021-03-26 12:31:57, Info CSI 00000094 [SR] Verifying 100 components
2021-03-26 12:31:57, Info CSI 00000095 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:58, Info CSI 00000096 [SR] Verify complete
2021-03-26 12:31:58, Info CSI 00000097 [SR] Verifying 100 components
2021-03-26 12:31:58, Info CSI 00000098 [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:58, Info CSI 00000099 CSIPERF - FilePI Queue 153ms
2021-03-26 12:31:59, Info CSI 0000009a [SR] Verify complete
2021-03-26 12:31:59, Info CSI 0000009b [SR] Verifying 100 components
2021-03-26 12:31:59, Info CSI 0000009c [SR] Beginning Verify and Repair transaction
2021-03-26 12:31:59, Info CSI 0000009d [SR] Verify complete
2021-03-26 12:32:00, Info CSI 0000009e [SR] Verifying 100 components
2021-03-26 12:32:00, Info CSI 0000009f [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:00, Info CSI 000000a0 [SR] Verify complete
2021-03-26 12:32:00, Info CSI 000000a1 [SR] Verifying 100 components
2021-03-26 12:32:00, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:01, Info CSI 000000a3 [SR] Verify complete
2021-03-26 12:32:01, Info CSI 000000a4 [SR] Verifying 100 components
2021-03-26 12:32:01, Info CSI 000000a5 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:02, Info CSI 000000a6 CSIPERF - FilePI Queue 123ms
2021-03-26 12:32:02, Info CSI 000000a7 [SR] Verify complete
2021-03-26 12:32:02, Info CSI 000000a8 [SR] Verifying 100 components
2021-03-26 12:32:02, Info CSI 000000a9 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:04, Info CSI 000000aa CSIPERF - FilePI Queue 103ms
2021-03-26 12:32:04, Info CSI 000000ab CSIPERF - FilePI Queue 161ms
2021-03-26 12:32:04, Info CSI 000000ac [SR] Verify complete
2021-03-26 12:32:04, Info CSI 000000ad [SR] Verifying 100 components
2021-03-26 12:32:04, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:05, Info CSI 000000af [SR] Verify complete
2021-03-26 12:32:05, Info CSI 000000b0 [SR] Verifying 100 components
2021-03-26 12:32:05, Info CSI 000000b1 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:06, Info CSI 000000b2 [SR] Verify complete
2021-03-26 12:32:06, Info CSI 000000b3 [SR] Verifying 100 components
2021-03-26 12:32:06, Info CSI 000000b4 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:06, Info CSI 000000b5 [SR] Verify complete
2021-03-26 12:32:06, Info CSI 000000b6 [SR] Verifying 100 components
2021-03-26 12:32:06, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:07, Info CSI 000000b8 [SR] Verify complete
2021-03-26 12:32:07, Info CSI 000000b9 [SR] Verifying 100 components
2021-03-26 12:32:07, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:08, Info CSI 000000bb CSIPERF - FilePI Queue 245ms
2021-03-26 12:32:09, Info CSI 000000bc [SR] Verify complete
2021-03-26 12:32:09, Info CSI 000000bd [SR] Verifying 100 components
2021-03-26 12:32:09, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:10, Info CSI 000000bf [SR] Verify complete
2021-03-26 12:32:10, Info CSI 000000c0 [SR] Verifying 100 components
2021-03-26 12:32:10, Info CSI 000000c1 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:11, Info CSI 000000c2 CSIPERF - FilePI Queue 117ms
2021-03-26 12:32:11, Info CSI 000000c3 CSIPERF - FilePI Queue 200ms
2021-03-26 12:32:11, Info CSI 000000c4 [SR] Verify complete
2021-03-26 12:32:11, Info CSI 000000c5 [SR] Verifying 100 components
2021-03-26 12:32:11, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:13, Info CSI 000000c7 CSIPERF - FilePI Queue 241ms
2021-03-26 12:32:14, Info CSI 000000c8 CSIPERF - FilePI Queue 487ms
2021-03-26 12:32:14, Info CSI 000000c9 [SR] Verify complete
2021-03-26 12:32:14, Info CSI 000000ca [SR] Verifying 100 components
2021-03-26 12:32:14, Info CSI 000000cb [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:15, Info CSI 000000cc [SR] Verify complete
2021-03-26 12:32:15, Info CSI 000000cd [SR] Verifying 100 components
2021-03-26 12:32:15, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:16, Info CSI 000000cf CSIPERF - FilePI Queue 298ms
2021-03-26 12:32:16, Info CSI 000000d0 [SR] Verify complete
2021-03-26 12:32:16, Info CSI 000000d1 [SR] Verifying 100 components
2021-03-26 12:32:16, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:18, Info CSI 000000d3 CSIPERF - FilePI Queue 103ms
2021-03-26 12:32:18, Info CSI 000000d4 [SR] Verify complete
2021-03-26 12:32:18, Info CSI 000000d5 [SR] Verifying 100 components
2021-03-26 12:32:18, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:19, Info CSI 000000d7 [SR] Verify complete
2021-03-26 12:32:19, Info CSI 000000d8 [SR] Verifying 100 components
2021-03-26 12:32:19, Info CSI 000000d9 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:20, Info CSI 000000da [SR] Verify complete
2021-03-26 12:32:21, Info CSI 000000db [SR] Verifying 100 components
2021-03-26 12:32:21, Info CSI 000000dc [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:22, Info CSI 000000dd [SR] Verify complete
2021-03-26 12:32:22, Info CSI 000000de [SR] Verifying 100 components
2021-03-26 12:32:22, Info CSI 000000df [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:22, Info CSI 000000e0 [SR] Verify complete
2021-03-26 12:32:22, Info CSI 000000e1 [SR] Verifying 100 components
2021-03-26 12:32:22, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:23, Info CSI 000000e3 [SR] Verify complete
2021-03-26 12:32:23, Info CSI 000000e4 [SR] Verifying 100 components
2021-03-26 12:32:23, Info CSI 000000e5 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:24, Info CSI 000000e6 [SR] Verify complete
2021-03-26 12:32:24, Info CSI 000000e7 [SR] Verifying 100 components
2021-03-26 12:32:24, Info CSI 000000e8 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:25, Info CSI 000000e9 [SR] Verify complete
2021-03-26 12:32:25, Info CSI 000000ea [SR] Verifying 100 components
2021-03-26 12:32:25, Info CSI 000000eb [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:26, Info CSI 000000ec [SR] Verify complete
2021-03-26 12:32:26, Info CSI 000000ed [SR] Verifying 100 components
2021-03-26 12:32:26, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:26, Info CSI 000000ef [SR] Verify complete
2021-03-26 12:32:26, Info CSI 000000f0 [SR] Verifying 100 components
2021-03-26 12:32:26, Info CSI 000000f1 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:27, Info CSI 000000f2 [SR] Verify complete
2021-03-26 12:32:27, Info CSI 000000f3 [SR] Verifying 100 components
2021-03-26 12:32:27, Info CSI 000000f4 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:28, Info CSI 000000f5 [SR] Verify complete
2021-03-26 12:32:28, Info CSI 000000f6 [SR] Verifying 100 components
2021-03-26 12:32:28, Info CSI 000000f7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:29, Info CSI 000000f8 [SR] Verify complete
2021-03-26 12:32:29, Info CSI 000000f9 [SR] Verifying 100 components
2021-03-26 12:32:29, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:30, Info CSI 000000fb [SR] Verify complete
2021-03-26 12:32:30, Info CSI 000000fc [SR] Verifying 100 components
2021-03-26 12:32:30, Info CSI 000000fd [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:30, Info CSI 000000fe [SR] Verify complete
2021-03-26 12:32:31, Info CSI 000000ff [SR] Verifying 100 components
2021-03-26 12:32:31, Info CSI 00000100 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:31, Info CSI 00000101 [SR] Verify complete
2021-03-26 12:32:31, Info CSI 00000102 [SR] Verifying 100 components
2021-03-26 12:32:31, Info CSI 00000103 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:32, Info CSI 00000104 [SR] Verify complete
2021-03-26 12:32:32, Info CSI 00000105 [SR] Verifying 100 components
2021-03-26 12:32:32, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:34, Info CSI 00000107 [SR] Verify complete
2021-03-26 12:32:34, Info CSI 00000108 [SR] Verifying 100 components
2021-03-26 12:32:34, Info CSI 00000109 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:34, Info CSI 0000010a CSIPERF - FilePI Queue 114ms
2021-03-26 12:32:35, Info CSI 0000010b [SR] Verify complete
2021-03-26 12:32:35, Info CSI 0000010c [SR] Verifying 100 components
2021-03-26 12:32:35, Info CSI 0000010d [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:36, Info CSI 0000010e [SR] Verify complete
2021-03-26 12:32:36, Info CSI 0000010f [SR] Verifying 100 components
2021-03-26 12:32:36, Info CSI 00000110 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:37, Info CSI 00000111 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\ is owned twice or has its security set twice
Original owner: Microsoft-Windows-shell32, version 10.0.19041.844, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}
New owner: Microsoft-Windows-shell32, version 10.0.19041.844, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}
2021-03-26 12:32:37, Info CSI 00000112 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ is owned twice or has its security set twice
2021-03-26 12:32:37, Info CSI 00000113 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ is owned twice or has its security set twice
2021-03-26 12:32:37, Info CSI 00000114 CSIPERF - FilePI Queue 112ms
2021-03-26 12:32:37, Info CSI 00000115 CSIPERF - FilePI Queue 118ms
2021-03-26 12:32:37, Info CSI 00000116 [SR] Verify complete
2021-03-26 12:32:38, Info CSI 00000117 [SR] Verifying 100 components
2021-03-26 12:32:38, Info CSI 00000118 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:39, Info CSI 00000119 CSIPERF - FilePI Queue 363ms
2021-03-26 12:32:39, Info CSI 0000011a CSIPERF - FilePI Queue 108ms
2021-03-26 12:32:39, Info CSI 0000011b [SR] Verify complete
2021-03-26 12:32:39, Info CSI 0000011c [SR] Verifying 100 components
2021-03-26 12:32:39, Info CSI 0000011d [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:40, Info CSI 0000011e [SR] Verify complete
2021-03-26 12:32:40, Info CSI 0000011f [SR] Verifying 100 components
2021-03-26 12:32:40, Info CSI 00000120 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:41, Info CSI 00000121 CSIPERF - FilePI Queue 115ms
2021-03-26 12:32:41, Info CSI 00000122 CSIPERF - FilePI Queue 255ms
2021-03-26 12:32:42, Info CSI 00000123 [SR] Verify complete
2021-03-26 12:32:42, Info CSI 00000124 [SR] Verifying 100 components
2021-03-26 12:32:42, Info CSI 00000125 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:43, Info CSI 00000126 CSIPERF - FilePI Queue 234ms
2021-03-26 12:32:43, Info CSI 00000127 CSIPERF - FilePI Queue 268ms
2021-03-26 12:32:43, Info CSI 00000128 [SR] Verify complete
2021-03-26 12:32:43, Info CSI 00000129 [SR] Verifying 100 components
2021-03-26 12:32:43, Info CSI 0000012a [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:44, Info CSI 0000012b [SR] Verify complete
2021-03-26 12:32:44, Info CSI 0000012c [SR] Verifying 100 components
2021-03-26 12:32:44, Info CSI 0000012d [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:45, Info CSI 0000012e [SR] Verify complete
2021-03-26 12:32:45, Info CSI 0000012f [SR] Verifying 100 components
2021-03-26 12:32:45, Info CSI 00000130 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:46, Info CSI 00000131 [SR] Verify complete
2021-03-26 12:32:47, Info CSI 00000132 [SR] Verifying 100 components
2021-03-26 12:32:47, Info CSI 00000133 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:47, Info CSI 00000134 CSIPERF - FilePI Queue 140ms
2021-03-26 12:32:48, Info CSI 00000135 [SR] Verify complete
2021-03-26 12:32:48, Info CSI 00000136 [SR] Verifying 100 components
2021-03-26 12:32:48, Info CSI 00000137 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:48, Info CSI 00000138 [SR] Verify complete
2021-03-26 12:32:48, Info CSI 00000139 [SR] Verifying 100 components
2021-03-26 12:32:48, Info CSI 0000013a [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:49, Info CSI 0000013b [SR] Verify complete
2021-03-26 12:32:49, Info CSI 0000013c [SR] Verifying 100 components
2021-03-26 12:32:49, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:50, Info CSI 0000013e [SR] Verify complete
2021-03-26 12:32:50, Info CSI 0000013f [SR] Verifying 100 components
2021-03-26 12:32:50, Info CSI 00000140 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:51, Info CSI 00000141 CSIPERF - FilePI Queue 165ms
2021-03-26 12:32:51, Info CSI 00000142 [SR] Verify complete
2021-03-26 12:32:51, Info CSI 00000143 [SR] Verifying 100 components
2021-03-26 12:32:51, Info CSI 00000144 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:52, Info CSI 00000145 [SR] Verify complete
2021-03-26 12:32:52, Info CSI 00000146 [SR] Verifying 100 components
2021-03-26 12:32:52, Info CSI 00000147 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:53, Info CSI 00000148 CSIPERF - FilePI Queue 161ms
2021-03-26 12:32:53, Info CSI 00000149 [SR] Verify complete
2021-03-26 12:32:53, Info CSI 0000014a [SR] Verifying 100 components
2021-03-26 12:32:53, Info CSI 0000014b [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:54, Info CSI 0000014c [SR] Verify complete
2021-03-26 12:32:54, Info CSI 0000014d [SR] Verifying 100 components
2021-03-26 12:32:54, Info CSI 0000014e [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:55, Info CSI 0000014f CSIPERF - FilePI Queue 833ms
2021-03-26 12:32:55, Info CSI 00000150 [SR] Verify complete
2021-03-26 12:32:55, Info CSI 00000151 [SR] Verifying 100 components
2021-03-26 12:32:55, Info CSI 00000152 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:56, Info CSI 00000153 [SR] Verify complete
2021-03-26 12:32:56, Info CSI 00000154 [SR] Verifying 100 components
2021-03-26 12:32:56, Info CSI 00000155 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:57, Info CSI 00000156 [SR] Verify complete
2021-03-26 12:32:57, Info CSI 00000157 [SR] Verifying 100 components
2021-03-26 12:32:57, Info CSI 00000158 [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:57, Info CSI 00000159 [SR] Verify complete
2021-03-26 12:32:57, Info CSI 0000015a [SR] Verifying 100 components
2021-03-26 12:32:57, Info CSI 0000015b [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:58, Info CSI 0000015c [SR] Verify complete
2021-03-26 12:32:58, Info CSI 0000015d [SR] Verifying 100 components
2021-03-26 12:32:58, Info CSI 0000015e [SR] Beginning Verify and Repair transaction
2021-03-26 12:32:59, Info CSI 0000015f [SR] Verify complete
2021-03-26 12:32:59, Info CSI 00000160 [SR] Verifying 100 components
2021-03-26 12:32:59, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:01, Info CSI 00000162 [SR] Verify complete
2021-03-26 12:33:01, Info CSI 00000163 [SR] Verifying 100 components
2021-03-26 12:33:01, Info CSI 00000164 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:02, Info CSI 00000165 CSIPERF - FilePI Queue 172ms
2021-03-26 12:33:02, Info CSI 00000166 [SR] Verify complete
2021-03-26 12:33:02, Info CSI 00000167 [SR] Verifying 100 components
2021-03-26 12:33:02, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:03, Info CSI 00000169 [SR] Verify complete
2021-03-26 12:33:03, Info CSI 0000016a [SR] Verifying 100 components
2021-03-26 12:33:03, Info CSI 0000016b [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:03, Info CSI 0000016c [SR] Verify complete
2021-03-26 12:33:03, Info CSI 0000016d [SR] Verifying 100 components
2021-03-26 12:33:03, Info CSI 0000016e [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:03, Info CSI 0000016f [SR] Cannot verify component files for Policy.14.0.Avast.VC140.CRT, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:03, Info CSI 00000170 [SR] Cannot verify component files for Policy.14.0.Avast.VC140.MFC, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:04, Info CSI 00000171 [SR] Verify complete
2021-03-26 12:33:04, Error CSI 00000172@2021/3/26:11:33:04.414 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:04, Error CSI 00000173@2021/3/26:11:33:04.414 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:04, Info CBS Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:04, Info CBS Could not get file name for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:04, Error CSI 00000174@2021/3/26:11:33:04.414 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:04, Error CSI 00000175@2021/3/26:11:33:04.414 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:04, Info CSI 00000176 [SR] Verifying 100 components
2021-03-26 12:33:04, Info CSI 00000177 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:04, Info CSI 00000178 [SR] Verify complete
2021-03-26 12:33:05, Info CSI 00000179 [SR] Verifying 100 components
2021-03-26 12:33:05, Info CSI 0000017a [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:05, Info CSI 0000017b [SR] Verify complete
2021-03-26 12:33:05, Info CSI 0000017c [SR] Verifying 100 components
2021-03-26 12:33:05, Info CSI 0000017d [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:06, Info CSI 0000017e [SR] Verify complete
2021-03-26 12:33:06, Info CSI 0000017f [SR] Verifying 100 components
2021-03-26 12:33:06, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:07, Info CSI 00000181 [SR] Verify complete
2021-03-26 12:33:07, Info CSI 00000182 [SR] Verifying 100 components
2021-03-26 12:33:07, Info CSI 00000183 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:08, Info CSI 00000184 [SR] Verify complete
2021-03-26 12:33:08, Info CSI 00000185 [SR] Verifying 100 components
2021-03-26 12:33:08, Info CSI 00000186 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:08, Info CSI 00000187 CSIPERF - FilePI Queue 125ms
2021-03-26 12:33:09, Info CSI 00000188 CSIPERF - FilePI Queue 255ms
2021-03-26 12:33:09, Info CSI 00000189 [SR] Verify complete
2021-03-26 12:33:09, Info CSI 0000018a [SR] Verifying 100 components
2021-03-26 12:33:09, Info CSI 0000018b [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:10, Info CSI 0000018c [SR] Verify complete
2021-03-26 12:33:10, Info CSI 0000018d [SR] Verifying 100 components
2021-03-26 12:33:10, Info CSI 0000018e [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:12, Info CSI 0000018f CSIPERF - FilePI Queue 117ms
2021-03-26 12:33:12, Info CSI 00000190 [SR] Verify complete
2021-03-26 12:33:12, Info CSI 00000191 [SR] Verifying 100 components
2021-03-26 12:33:12, Info CSI 00000192 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:12, Info CSI 00000193 [SR] Verify complete
2021-03-26 12:33:12, Info CSI 00000194 [SR] Verifying 100 components
2021-03-26 12:33:12, Info CSI 00000195 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:13, Info CSI 00000196 [SR] Verify complete
2021-03-26 12:33:13, Info CSI 00000197 [SR] Verifying 100 components
2021-03-26 12:33:13, Info CSI 00000198 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:13, Info CSI 00000199 [SR] Verify complete
2021-03-26 12:33:13, Info CSI 0000019a [SR] Verifying 100 components
2021-03-26 12:33:13, Info CSI 0000019b [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:14, Info CSI 0000019c [SR] Verify complete
2021-03-26 12:33:14, Info CSI 0000019d [SR] Verifying 100 components
2021-03-26 12:33:14, Info CSI 0000019e [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:15, Info CSI 0000019f [SR] Verify complete
2021-03-26 12:33:15, Info CSI 000001a0 [SR] Verifying 100 components
2021-03-26 12:33:15, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:16, Info CSI 000001a2 [SR] Verify complete
2021-03-26 12:33:16, Info CSI 000001a3 [SR] Verifying 100 components
2021-03-26 12:33:16, Info CSI 000001a4 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:16, Info CSI 000001a5 [SR] Verify complete
2021-03-26 12:33:17, Info CSI 000001a6 [SR] Verifying 100 components
2021-03-26 12:33:17, Info CSI 000001a7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:17, Info CSI 000001a8 [SR] Verify complete
2021-03-26 12:33:17, Info CSI 000001a9 [SR] Verifying 100 components
2021-03-26 12:33:17, Info CSI 000001aa [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:18, Info CSI 000001ab [SR] Verify complete
2021-03-26 12:33:18, Info CSI 000001ac [SR] Verifying 100 components
2021-03-26 12:33:18, Info CSI 000001ad [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:19, Info CSI 000001ae [SR] Verify complete
2021-03-26 12:33:19, Info CSI 000001af [SR] Verifying 100 components
2021-03-26 12:33:19, Info CSI 000001b0 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:20, Info CSI 000001b1 [SR] Verify complete
2021-03-26 12:33:20, Info CSI 000001b2 [SR] Verifying 100 components
2021-03-26 12:33:20, Info CSI 000001b3 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:21, Info CSI 000001b4 [SR] Verify complete
2021-03-26 12:33:21, Info CSI 000001b5 [SR] Verifying 100 components
2021-03-26 12:33:21, Info CSI 000001b6 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:21, Info CSI 000001b7 Warning: Overlap: Directory \??\C:\WINDOWS\SysWOW64\drivers\en-US\ is owned twice or has its security set twice
Original owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch Host= amd64 Guest= x86, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
New owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch Host= amd64 Guest= x86, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
2021-03-26 12:33:21, Info CSI 000001b8 Warning: Overlap: Directory \??\C:\WINDOWS\SysWOW64\wbem\en-US\ is owned twice or has its security set twice
2021-03-26 12:33:21, Info CSI 000001b9 Warning: Overlap: Directory \??\C:\WINDOWS\help\mui\0409\ is owned twice or has its security set twice
2021-03-26 12:33:21, Info CSI 000001ba [SR] Verify complete
2021-03-26 12:33:21, Info CSI 000001bb [SR] Verifying 100 components
2021-03-26 12:33:21, Info CSI 000001bc [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:22, Info CSI 000001bd [SR] Verify complete
2021-03-26 12:33:22, Info CSI 000001be [SR] Verifying 100 components
2021-03-26 12:33:22, Info CSI 000001bf [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:23, Info CSI 000001c0 [SR] Verify complete
2021-03-26 12:33:23, Info CSI 000001c1 [SR] Verifying 100 components
2021-03-26 12:33:23, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:23, Info CSI 000001c3 [SR] Verify complete
2021-03-26 12:33:23, Info CSI 000001c4 [SR] Verifying 100 components
2021-03-26 12:33:23, Info CSI 000001c5 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:24, Info CSI 000001c6 [SR] Verify complete
2021-03-26 12:33:24, Info CSI 000001c7 [SR] Verifying 100 components
2021-03-26 12:33:24, Info CSI 000001c8 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:25, Info CSI 000001c9 CSIPERF - FilePI Queue 104ms
2021-03-26 12:33:25, Info CSI 000001ca CSIPERF - FilePI Queue 135ms
2021-03-26 12:33:25, Info CSI 000001cb [SR] Verify complete
2021-03-26 12:33:25, Info CSI 000001cc [SR] Verifying 100 components
2021-03-26 12:33:25, Info CSI 000001cd [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:26, Info CSI 000001ce [SR] Verify complete
2021-03-26 12:33:26, Info CSI 000001cf [SR] Verifying 100 components
2021-03-26 12:33:26, Info CSI 000001d0 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:27, Info CSI 000001d1 [SR] Verify complete
2021-03-26 12:33:27, Info CSI 000001d2 [SR] Verifying 100 components
2021-03-26 12:33:27, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:28, Info CSI 000001d4 CSIPERF - FilePI Queue 118ms
2021-03-26 12:33:28, Info CSI 000001d5 [SR] Verify complete
2021-03-26 12:33:28, Info CSI 000001d6 [SR] Verifying 100 components
2021-03-26 12:33:28, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:29, Info CSI 000001d8 [SR] Verify complete
2021-03-26 12:33:29, Info CSI 000001d9 [SR] Verifying 100 components
2021-03-26 12:33:29, Info CSI 000001da [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:30, Info CSI 000001db [SR] Verify complete
2021-03-26 12:33:30, Info CSI 000001dc [SR] Verifying 100 components
2021-03-26 12:33:30, Info CSI 000001dd [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:31, Info CSI 000001de CSIPERF - FilePI Queue 168ms
2021-03-26 12:33:31, Info CSI 000001df [SR] Verify complete
2021-03-26 12:33:31, Info CSI 000001e0 [SR] Verifying 100 components
2021-03-26 12:33:31, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:32, Info CSI 000001e2 [SR] Verify complete
2021-03-26 12:33:32, Info CSI 000001e3 [SR] Verifying 100 components
2021-03-26 12:33:32, Info CSI 000001e4 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:32, Info CSI 000001e5 [SR] Verify complete
2021-03-26 12:33:32, Info CSI 000001e6 [SR] Verifying 100 components
2021-03-26 12:33:32, Info CSI 000001e7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:33, Info CSI 000001e8 [SR] Verify complete
2021-03-26 12:33:33, Info CSI 000001e9 [SR] Verifying 100 components
2021-03-26 12:33:33, Info CSI 000001ea [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:34, Info CSI 000001eb [SR] Verify complete
2021-03-26 12:33:34, Info CSI 000001ec [SR] Verifying 100 components
2021-03-26 12:33:34, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:35, Info CSI 000001ee Warning: Overlap: Directory \??\C:\Program Files (x86)\ is owned twice or has its security set twice
Original owner: Microsoft-Windows-shell32, version 10.0.19041.844, arch Host= amd64 Guest= x86, nonSxS, pkt {l:8 b:31bf3856ad364e35}
New owner: Microsoft-Windows-shell32, version 10.0.19041.844, arch Host= amd64 Guest= x86, nonSxS, pkt {l:8 b:31bf3856ad364e35}
2021-03-26 12:33:35, Info CSI 000001ef Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\ is owned twice or has its security set twice
2021-03-26 12:33:35, Info CSI 000001f0 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ is owned twice or has its security set twice
2021-03-26 12:33:35, Info CSI 000001f1 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ is owned twice or has its security set twice
2021-03-26 12:33:35, Info CSI 000001f2 [SR] Verify complete
2021-03-26 12:33:35, Info CSI 000001f3 [SR] Verifying 100 components
2021-03-26 12:33:35, Info CSI 000001f4 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:36, Info CSI 000001f5 [SR] Verify complete
2021-03-26 12:33:36, Info CSI 000001f6 [SR] Verifying 100 components
2021-03-26 12:33:36, Info CSI 000001f7 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:37, Info CSI 000001f8 [SR] Verify complete
2021-03-26 12:33:37, Info CSI 000001f9 [SR] Verifying 100 components
2021-03-26 12:33:37, Info CSI 000001fa [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:38, Info CSI 000001fb [SR] Verify complete
2021-03-26 12:33:38, Info CSI 000001fc [SR] Verifying 100 components
2021-03-26 12:33:38, Info CSI 000001fd [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:39, Info CSI 000001fe [SR] Verify complete
2021-03-26 12:33:39, Info CSI 000001ff [SR] Verifying 100 components
2021-03-26 12:33:39, Info CSI 00000200 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:40, Info CSI 00000201 CSIPERF - FilePI Queue 158ms
2021-03-26 12:33:40, Info CSI 00000202 [SR] Verify complete
2021-03-26 12:33:40, Info CSI 00000203 [SR] Verifying 100 components
2021-03-26 12:33:40, Info CSI 00000204 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:41, Info CSI 00000205 [SR] Verify complete
2021-03-26 12:33:41, Info CSI 00000206 [SR] Verifying 100 components
2021-03-26 12:33:41, Info CSI 00000207 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:42, Info CSI 00000208 [SR] Verify complete
2021-03-26 12:33:42, Info CSI 00000209 [SR] Verifying 100 components
2021-03-26 12:33:42, Info CSI 0000020a [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:43, Info CSI 0000020b CSIPERF - FilePI Queue 263ms
2021-03-26 12:33:43, Info CSI 0000020c [SR] Verify complete
2021-03-26 12:33:43, Info CSI 0000020d [SR] Verifying 100 components
2021-03-26 12:33:43, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:44, Info CSI 0000020f [SR] Verify complete
2021-03-26 12:33:44, Info CSI 00000210 [SR] Verifying 100 components
2021-03-26 12:33:44, Info CSI 00000211 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:44, Info CSI 00000212 [SR] Cannot verify component files for Avast.VC140.CRT, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:44, Info CSI 00000213 [SR] Cannot verify component files for Avast.VC140.MFC, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:45, Info CSI 00000214 [SR] Verify complete
2021-03-26 12:33:45, Error CSI 00000215@2021/3/26:11:33:45.305 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:45, Error CSI 00000216@2021/3/26:11:33:45.305 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:45, Info CBS Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:45, Info CBS Could not get file name for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:45, Error CSI 00000217@2021/3/26:11:33:45.305 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:45, Error CSI 00000218@2021/3/26:11:33:45.305 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:45, Info CSI 00000219 [SR] Verifying 100 components
2021-03-26 12:33:45, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:46, Info CSI 0000021b [SR] Verify complete
2021-03-26 12:33:46, Info CSI 0000021c [SR] Verifying 100 components
2021-03-26 12:33:46, Info CSI 0000021d [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:47, Info CSI 0000021e [SR] Verify complete
2021-03-26 12:33:47, Info CSI 0000021f [SR] Verifying 100 components
2021-03-26 12:33:47, Info CSI 00000220 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:48, Info CSI 00000221 CSIPERF - FilePI Queue 229ms
2021-03-26 12:33:48, Info CSI 00000222 [SR] Verify complete
2021-03-26 12:33:48, Info CSI 00000223 [SR] Verifying 100 components
2021-03-26 12:33:48, Info CSI 00000224 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:49, Info CSI 00000225 CSIPERF - FilePI Queue 170ms
2021-03-26 12:33:49, Info CSI 00000226 [SR] Verify complete
2021-03-26 12:33:49, Info CSI 00000227 [SR] Verifying 100 components
2021-03-26 12:33:49, Info CSI 00000228 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:50, Info CSI 00000229 [SR] Verify complete
2021-03-26 12:33:50, Info CSI 0000022a [SR] Verifying 100 components
2021-03-26 12:33:50, Info CSI 0000022b [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:50, Info CSI 0000022c [SR] Verify complete
2021-03-26 12:33:50, Info CSI 0000022d [SR] Verifying 100 components
2021-03-26 12:33:50, Info CSI 0000022e [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:52, Info CSI 0000022f [SR] Verify complete
2021-03-26 12:33:52, Info CSI 00000230 [SR] Verifying 100 components
2021-03-26 12:33:52, Info CSI 00000231 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:53, Info CSI 00000232 [SR] Verify complete
2021-03-26 12:33:53, Info CSI 00000233 [SR] Verifying 100 components
2021-03-26 12:33:53, Info CSI 00000234 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:54, Info CSI 00000235 CSIPERF - FilePI Queue 155ms
2021-03-26 12:33:54, Info CSI 00000236 [SR] Verify complete
2021-03-26 12:33:54, Info CSI 00000237 [SR] Verifying 100 components
2021-03-26 12:33:54, Info CSI 00000238 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:54, Info CSI 00000239 [SR] Cannot verify component files for Policy.14.0.Avast.VC140.CRT, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:54, Info CSI 0000023a [SR] Cannot verify component files for Policy.14.0.Avast.VC140.MFC, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:55, Info CSI 0000023b CSIPERF - FilePI Queue 120ms
2021-03-26 12:33:55, Info CSI 0000023c [SR] Verify complete
2021-03-26 12:33:55, Error CSI 0000023d@2021/3/26:11:33:55.478 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:55, Error CSI 0000023e@2021/3/26:11:33:55.478 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:55, Info CBS Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:55, Info CBS Could not get file name for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:55, Error CSI 0000023f@2021/3/26:11:33:55.478 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:55, Error CSI 00000240@2021/3/26:11:33:55.478 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:55, Info CSI 00000241 [SR] Verifying 42 components
2021-03-26 12:33:55, Info CSI 00000242 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:55, Info CSI 00000243 CSIPERF - FilePI Queue 116ms
2021-03-26 12:33:56, Info CSI 00000244 [SR] Verify complete
2021-03-26 12:33:56, Info CSI 00000245 [SR] Repairing 8 components
2021-03-26 12:33:56, Info CSI 00000246 [SR] Beginning Verify and Repair transaction
2021-03-26 12:33:56, Info CSI 00000247 [SR] Cannot verify component files for Avast.VC140.CRT, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 00000248 [SR] Cannot verify component files for Avast.VC140.MFC, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 00000249 [SR] Cannot verify component files for Policy.14.0.Avast.VC140.MFC, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024a [SR] Cannot verify component files for Policy.14.0.Avast.VC140.CRT, version 14.0.28127.0, arch amd64, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024b [SR] Cannot verify component files for Avast.VC140.CRT, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024c [SR] Cannot verify component files for Avast.VC140.MFC, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:5]'win32', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024d [SR] Cannot verify component files for Policy.14.0.Avast.VC140.MFC, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024e [SR] Cannot verify component files for Policy.14.0.Avast.VC140.CRT, version 14.0.28127.0, arch x86, versionScope neutral, pkt {l:8 b:fcc99ee6193ebbca}, type [l:12]'win32-policy', manifest is damaged (false)
2021-03-26 12:33:56, Info CSI 0000024f [SR] Repair complete
2021-03-26 12:33:56, Error CSI 00000250@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000251@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Info CBS Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:56, Info CBS Could not get file name for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2021-03-26 12:33:56, Error CSI 00000252@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000253@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000254@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000255@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000256@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000257@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000258@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 00000259@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025a@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025b@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025c@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025d@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025e@2021/3/26:11:33:56.525 (F) Attempting to mark store corrupt with category [l:15 ml:16]'CorruptManifest'[gle=0x80004005]
2021-03-26 12:33:56, Error CSI 0000025f@2021/3/26:11:33:56.525 (F) onecore\base\wcp\componentstore\csd_core.cpp(584): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function CCSDirect::GetComponentManifest expression: (null)
[gle=0x80004005]
2021-03-26 12:33:56, Info CSI 00000260 [SR] Committing transaction
2021-03-26 12:33:56, Info CSI 00000261 Creating NT transaction (seq 1)
2021-03-26 12:33:56, Info CSI 00000262 Created NT transaction (seq 1) result 0x00000000, handle @0xba0
2021-03-26 12:33:56, Info CSI 00000263@2021/3/26:11:33:56.525 Beginning NT transaction commit...
2021-03-26 12:33:56, Info CSI 00000264@2021/3/26:11:33:56.525 CSI perf trace:
CSIPERF:TXCOMMIT;27
2021-03-26 12:33:56, Info CSI 00000265 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
