I frequently freeze and my audio cuts out from discord. It only happens with certain programs, like when playing Valorant or when I'm watching youtube. Happens even when the pc is idle, pretty much all the time. Not sure what is going on, need help its driving me nuts.
CONCLUSION
LatencyMon has been analyzing your system for 1:06:36 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-8TECI5U
OS version: Windows 10 , 10.0, build: 19042 (x64)
Hardware: 90JF00AMUS, LENOVO, 36E9
CPU: GenuineIntel Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Logical processors: 8
Processor groups: 1
RAM: 32714 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Highest measured interrupt to process latency (µs): 3923868.90
Average measured interrupt to process latency (µs): 8.910146
Highest measured interrupt to DPC latency (µs): 3923815.10
Average measured interrupt to DPC latency (µs): 6.543556
REPORTED ISRs
Highest ISR routine execution time (µs): 1487.098333
Highest reported total ISR routine time (%): 0.285155
Total time spent in ISRs (%) 0.287793
ISR count (execution time <250 µs): 3947392
ISR count (execution time 500-999 µs): 1147
ISR count (execution time 1000-1999 µs): 5
REPORTED DPCs
Highest DPC routine execution time (µs): 5708.557222
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 465.89 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.142389
Total time spent in DPCs (%) 0.309903
DPC count (execution time <250 µs): 10023527
DPC count (execution time 500-999 µs): 898
DPC count (execution time 1000-1999 µs): 23
DPC count (execution time 2000-3999 µs): 18
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: valorant.exe
Total number of hard pagefaults 3033
Hard pagefault count of hardest hit process: 885
Number of processes hit: 39
PER CPU DATA
CPU 0 Interrupt cycle time (s): 285.354862
CPU 0 ISR highest execution time (µs): 1487.098333
CPU 0 ISR total execution time (s): 91.744906
CPU 0 ISR count: 3726218
CPU 0 DPC highest execution time (µs): 5708.557222
CPU 0 DPC total execution time (s): 87.598090
CPU 0 DPC count: 8831076
CPU 1 Interrupt cycle time (s): 48.778335
CPU 1 ISR highest execution time (µs): 117.352222
CPU 1 ISR total execution time (s): 0.260663
CPU 1 ISR count: 222326
CPU 1 DPC highest execution time (µs): 1814.557222
CPU 1 DPC total execution time (s): 6.013558
CPU 1 DPC count: 358208
CPU 2 Interrupt cycle time (s): 18.137184
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 2257.610556
CPU 2 DPC total execution time (s): 0.251370
CPU 2 DPC count: 60425
CPU 3 Interrupt cycle time (s): 17.292737
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 786.965556
CPU 3 DPC total execution time (s): 0.232233
CPU 3 DPC count: 55117
CPU 4 Interrupt cycle time (s): 37.213818
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 2396.597222
CPU 4 DPC total execution time (s): 2.282723
CPU 4 DPC count: 388535
CPU 5 Interrupt cycle time (s): 22.717896
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 1875.630556
CPU 5 DPC total execution time (s): 0.766497
CPU 5 DPC count: 142881
CPU 6 Interrupt cycle time (s): 22.695232
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 871.087778
CPU 6 DPC total execution time (s): 1.336471
CPU 6 DPC count: 80970
CPU 7 Interrupt cycle time (s): 21.047929
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 1772.742222
CPU 7 DPC total execution time (s): 0.593162
CPU 7 DPC count: 107257
