Error 0xc000014c
Please run the following commands with only the NVMe connected and post the results:
bcdedit /enum
bootrec /scanos
bcdedit /enum>
Windows Boot Manager
identifier {bootmgr}
device partition=\Device\HarddiskVolume1
path \EFI\MICROSOFT\BOOT\BOOTMGFW.EFI
description Windows Boot Manager
locale en-us
inherit {globalsettings}
default {default}
resumeobject {087af714-cc5b-11ef-a37b-9590941426b7}
displayorder {default}
toolsdisplayorder {memdiag}
timeout 30
Windows Boot Loader
identifier {default}
device partition=C:
path \Windows\system32\winload.efi
description Windows 10
locale en-us
inherit {bootloadersettings}
isolatedcontext Yes
allowedinmemorysettings 0x15000075
osdevice partition=C:
systemroot \Windows
nx OptIn
bootmenupolicy Standard
bootrec /scanos>
Examining all disks for Windows installations.
Please wait, this process may take a while...
Successfully scanned Windows installations.
Total identified Windows installations: 0
This looks like if you have run these commands from Windows itself as it seems! This because the result of the Recovery Environment should be different.
So please let us know if you can boot normally now? If so we can start fixing the the remaining issues.
I executed it via Windows RE with only the hard drive experiencing boot issues connected.
Strange, since it reported "Total identified Windows installations: 0." In this case, wouldn't it mean it's not detecting Windows? Another thing, every time I repair the same system with scandisk, when I boot into Windows, it shows the blue screen attached (it only displays this message once, and it doesn't happen again on the next reboot). After this screen, the error message:
"Logon process initialization failed: Interactive logon process initialization has failed."
Hmm, then I can only recommend to backup al your important and personal data and reinstall Windows 10. I would also suggest to check the NVMe afterwards with a tool like SeaTools 5 or the manufacturer's toolkit. And to avoid such problems in the future - I would also make regular backups / system images and don't rely on Windows System Restore points because they can become broken as well.
I was thinking, this SSD was cloned from an old HD. I used it for a long time. If I try to copy the system32 files and also copy the boot partition, could it start normally?
Unfortunately, that won't work and may cause even more issues. So I would reinstall Windows 10 after making a backup.
