Onetimeuser3
- May 2, 2020
- 0
Hello. Over the last week there have been stutters and jumps in audio and frames on my PC. Wasn't sure what it was so I installed and ran LatMon.
The issue seams to be storport.sys
I've gone through various threads on it but none with answers to my problem. The issue can't be power, that hasn't been changed in ages, its not a new PC. I don't think I can disable RAID (suggested in one of the threads) as I need it to maintain a backup on my HDD's. I've had RAID working in the past with no issues to audio or frames.
mug there are any suggestions you can give I would be very grateful. Thank you.
Here are some screencaps of LatencyMon
View: https://imgur.com/a/4Mimfbe
CONCLUSION
_
LatencyMon has been analyzing your system for 0:03:20 (h
ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: PHOTOS3
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: Studio XPS 435T/9000, DELL Inc., 0X501H
CPU: GenuineIntel Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Logical processors: 8
Processor groups: 1
RAM: 24566 MB total
_
CPU SPEED
_
Reported CPU speed: 2660 MHz
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 24566 MB total
_
CPU SPEED
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 24566 MB total
_
CPU SPEED
_
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 24566 MB total
_
CPU SPEED
_
