Components hive failed load test and may be corrupt.
Nunosky
Hi.
My problems started when I tried to update Windows 10 with KB4134660 y KB4033631 and I received error 0x800703f1 for both of them. I tried to execute "Windows10UpgraderApp.exe" and the download and upgrade (from 15063 to 16299) process seemed to work fine but after reboot it shows that and error was found and it was necessary to return to previous version. I have retry this process several times but with same result.
Then I started to investigate this situation and finally I found that the "component store" was damaged:
PS C:\WINDOWS\system32> Dism /Online /Cleanup-Image /CheckHealth /english
Version: 10.0.15063.0
Image Version: 10.0.15063.0
The component store is repairable.
But it was repairable.
But when I tried to repair:
PS C:\WINDOWS\system32> Dism /Online /Cleanup-Image /RestoreHealth /english
[== 4.5% ]
Error: 1009
The configuration registry database is corrupt.
After this I was totally missed but I found this forum. I started to follow the "Windows Update Forum Posting Instructions" and found that sfc /scannow is reporting "Windows Resource Protection could not perform the requested operation". Then I downloaded sfcfix and this is the log output:
SFCFix version 3.0.1.0 by niemiro.
Start time: 2019-01-09 12:42:59.621
Microsoft Windows 10 Build 15063 - amd64
WARNING: Components hive failed load test and may be corrupt.
WARNING: Components hive failed final reload test with error code ERROR_BADDB and may be corrupt.
Hello and welcome!
Please do the following:
Retrieve Components Hive
