CBS & SFC Corruption Issue. Need Assistance
joe_rockstar
Gents,
I am on my HP Laptop which is running Windows 7 Ultimate SP1, No Hardware Issues, Windows Update Current, Running Microsoft Security Essentials with Malwarebytes Home Premium. I was doing my typical monthly maintenance and ran and SFC Scan and proceeded with running SFCFix as I typically do when the SFC Scan returns file corruptions that cannot not be resolved.
SFC Scan Log below:
Verification 100% complete.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log
SFCFix Log below:
Start time: 2022-05-14 14:31:25.720
FIXED: Corruption at C:\Windows\winsxs\x86_microsoft-windows-winre-recoverytools_31bf3856ad364e35_6.1.7601.17514_none_d7553e5fcf6b6373\boot.sdi has been successfully repaired from C:\Windows\winsxs\amd64_microsoft-windows-winre-recoverytools_31bf3856ad364e35_6.1.7600.16385_none_3142c61b8ada510f\boot.sdi.
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll
CBS & SFC total fixed corruption count: 1
Finish time: 2022-05-14 14:34:37.845
Attached is my CBS.log File.
Thanking you in advance for your expertise trouble shooting and help,
joe_rockstar
,|m|
PeterJ,
There was an error. I downloaded the file multiple times with the same message. See copied text below.
Thanks,
joe_rockstar
,|m|
Start time: 2022-05-14 19:40:36.531
Using .zip script file at C:\Users\LaPuglia\Desktop\SFCFix.zip [2]
Failed to extract zip archive. Failed to unzip in location 2 with error code 0x80004005.
Finish time: 2022-05-14 19:40:38.901
Script hash: 7vExrXFNFbA2obFNIK3kAm6pywzBRR18KetsOfi6VbU=
Click the Start button and in the search box, type Command Prompt
When you see Command Prompt on the list, right-click on it and select Run as administrator.
When command prompt opens, copy and paste the following commands into it, press enter after each.
CD C:\Users\LaPuglia\Desktop
SFCFix C:\Users\LaPuglia\Desktop\SFCFix.zip
Tell me if SFCFix runs fine or if it crashes again.
PeterJ,
There was an error. See copied text below.
Thanks,
joe_rockstar
,|m|
C:\Users\LaPuglia\Desktop>
C:\Users\LaPuglia\Desktop>SFCFix C:\Users\LaPuglia\Desktop\SFCFix.zip
Welcome to SFCFix by niemiro and sysnative.com.
Checking for updates . . .
No new update is available at this time.
ERROR: Zip file is corrupt or unreadable. This may be due to a bad download.
Please re-download the zip file, try again, and see if the problem persists. If
it does, let your helper know as it may be that the upload is corrupt, and that
is something that only your helper can fix.
Press any key to exit . . .
Failed to read script or malformed script.
Weird, I don't see a problem with the provided zipfile.
Have you installed some kind of zip/unzip program ?
Extract the zip file on your desktop manually.
The 2 files will be put in the folder "C:\Users\LaPuglia\Desktop\SFCFix"
PeterJ,
I have never had any issues like this. I use 7-zip on my laptop. With that being said, there were no errors this time. See the copied text below.
Start time: 2022-05-15 15:37:44.131
Using .txt script file at C:\Users\LaPuglia\Desktop\SFCFixScript.txt [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll
Successfully copied file C:\Users\LaPuglia\Desktop\SFCFix\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll to C:\Windows\winsxs\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-rasapi_31bf3856ad364e35_6.1.7601.24559_none_6fa201a4c7012984\rasapi32.dll
Finish time: 2022-05-15 15:37:44.831
Script hash: /Dvbu+r5JfVlrgQUR7OQGx+0OmC1iMiMQC+CoTc/JnY=
Thanks,
joe_rockstar
,|m|
I don't think 7-Zip cause the failing of previous fixes. The log now shows it went successful.
Run the command sfc /scannow in an elevated command prompt and report the result.
PeterJ,
I am still having issues. See below and attached CBS.log.
C:\Windows\system32>
Thanks,
joe_rockstar
,|m|
PeterJ,
Start time: 2022-05-18 17:52:35.583
FileScan::
[0: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pt-pt_1b9fe95ec500145d\diskmgt.CHM
Expected: 79CqZkKpVP1VIJueO3sDyraOcea3c1RSw2af7GlI8gg=
Expected: 6.1.7600.16385 Found: Version number not available.
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pt-pt_1b9fe95ec500145d.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~pt-PT~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0816\diskmgt.CHM]
[1: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_es-es_18ed405259039887\diskmgt.CHM
Expected: ajEHpuungTx2V/a/SBUlsT4KepQh9Agzhit3CmmPuhM=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_es-es_18ed405259039887.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~es-ES~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0C0A\diskmgt.CHM]
[2: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_nl-nl_d22dd4cce1e4a2e9\diskmgt.CHM
Expected: j2hh+KETYmZJcqsMUbRxHoFTM+rdS/jG1j2mi+01FVU=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_nl-nl_d22dd4cce1e4a2e9.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0413\diskmgt.CHM]
[3: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_hu-hu_0315369930357e05\diskmgt.CHM
Expected: +8ebdsrjggxCpdULesxUEpVusxfyosUcawwXsJCwOU0=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_hu-hu_0315369930357e05.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~hu-HU~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\040E\diskmgt.CHM]
[4: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ru-ru_6242fb22a9e1a289\diskmgt.CHM
Expected: vXxHWLXn5gwsKgbK7zJa4TS12Iy3Df8EvJVVezXjfSw=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ru-ru_6242fb22a9e1a289.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~ru-RU~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0419\diskmgt.CHM]
[5: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_fr-fr_bba4b6514bd5aee9\diskmgt.CHM
Expected: egUgOec0+xbs4rgj8Ap8r272tGqtYNgRQhV1UI/R9PE=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_fr-fr_bba4b6514bd5aee9.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~ar-SA~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\040C\diskmgt.CHM]
[6: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pl-pl_186a2f4ec707109d\diskmgt.CHM
Expected: Tx3vgTH+moFHU1ktJryDl5StPbPn0XtakCrXKg0EfUg=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pl-pl_186a2f4ec707109d.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~pl-PL~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0415\diskmgt.CHM]
[7: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_it-it_a5ccac9823079467\diskmgt.CHM
Expected: DM3oV36uNb0YwxvgHRrEB06k+7S+F0ke/NVyu89AY04=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_it-it_a5ccac9823079467.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~it-IT~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0410\diskmgt.CHM]
[8: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_cs-cz_d5cb981271e24a84\diskmgt.CHM
Expected: koSylRlOmaBR6fFSzT6xP6qd83i7CSNkIEIt+P5Bfr4=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_cs-cz_d5cb981271e24a84.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~cs-CZ~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0405\diskmgt.CHM]
[9: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_tr-tr_a74b2fde8fc6aed5\diskmgt.CHM
Expected: WPp8QGpa3aEFk6+fYj1TtbFWVwXwbJ6xYFFCtwmmoZI=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_tr-tr_a74b2fde8fc6aed5.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~tr-TR~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\041F\diskmgt.CHM]
[10: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_sv-se_fe3de597a10aace4\diskmgt.CHM
Expected: aJFLbvmo2JDJWKFBnGj/X4sj9u5pfVwEISbN0qaXPyk=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_sv-se_fe3de597a10aace4.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~sv-SE~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\041D\diskmgt.CHM]
[11: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ko-kr_eb5c085a08936d58\diskmgt.CHM
Expected: 7p7OZUdbxPsCbhqayDK3QS1dGjMJXqe22r6AU3rl9Tc=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ko-kr_eb5c085a08936d58.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~ko-KR~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0412\diskmgt.CHM]
[12: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_zh-cn_78a84ddc3ffe80f4\diskmgt.CHM
Expected: fF0Cc5vplXg8BL0u546ybzNTs3yJEuPlqCwC5Jhr/dU=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_zh-cn_78a84ddc3ffe80f4.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~zh-CN~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0804\diskmgt.CHM]
[13: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_zh-tw_7ca48b323d6f5d64\diskmgt.CHM
Expected: M5z2L7z8x6HMER9vG7AtLVbNgo/G3Cdvuljc97/aERw=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_zh-tw_7ca48b323d6f5d64.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~zh-HK~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0404\diskmgt.CHM]
[14: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_de-de_70310d7569fe9b1d\diskmgt.CHM
Expected: X44IqLXTgvKbp6d8K/Jj7HX03WMTgon4eGpmCiaSVno=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_de-de_70310d7569fe9b1d.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~de-DE~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0407\diskmgt.CHM]
[15: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ja-jp_47f22ba51622a642\diskmgt.CHM
Expected: 2xzZqKerj6IP49J1+FQ2ozYm3PyDqDiyKvZ3ajtqhwU=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_ja-jp_47f22ba51622a642.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~ja-JP~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0411\diskmgt.CHM]
[16: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pt-br_1abe19f2c590a481\diskmgt.CHM
Expected: ZU0cT5T/Zysn5NckId2ljdGaxHJhesG4yo2YGbue1Rg=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_pt-br_1abe19f2c590a481.
Microsoft-Windows-RemoteServerAdministrationTools-Package~31bf3856ad364e35~amd64~pt-BR~6.1.7601.17514.RemoteServerAdministrationTools-Roles-FileServices-Dfs
[C:\Windows\Help\mui\0416\diskmgt.CHM]
[17: 2] C:\Windows\winsxs\amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1921e36e58dca6e2\diskmgt.CHM
Expected: Q04+9HaiDEqXWqWfSz15C0O1lwvdzRKc8OPWAuf17T4=
Successfully traced component amd64_server-help-chm.diskmgt.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1921e36e58dca6e2.
[C:\Windows\Help\mui\0409\diskmgt.CHM]
[18: 1] C:\Windows\winsxs\amd64_server-help-chm.diskm_v.resources_31bf3856ad364e35_6.1.7600.16385_en-us_d76955a45e11858c\diskmgt.CHM
Expected: Nm0jwXDzPg7+0Wb/lPzZrxe6KthUAbkrG2QotxzpUV8=
Successfully traced component amd64_server-help-chm.diskm_v.resources_31bf3856ad364e35_6.1.7600.16385_en-us_d76955a45e11858c.
Server-Help-Package.ClientUltimate~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Server-Help-Package.ClientUltimate-Update
Finish time: 2022-05-18 17:54:01.789
Script hash: r10CVQb+nMpJWTY3ICqszRH2xNbpDv+K7bMdjlUyTpQ=
Thanks,
joe_rockstar
,|m|
Please do following:
  1. Click on the Start button and in the search box, type CMD
  2. When CMD is listed above, right-click on it and select Run as administrator
  3. When Command Prompt opens, copy and paste the following command into it, then press enter.
    fsutil hardlink create C:\Windows\Help\mui\0409\diskmgt.CHM C:\Windows\winsxs\amd64_server-help-chm.diskm_v.resources_31bf3856ad364e35_6.1.7600.16385_en-us_d76955a45e11858c\diskmgt.CHM
Take a screenshot of the Command Prompt. Read this on how to take a screenshot.
Upload the image file to a file-sharing site and post the downloadlink.
That went not successful. Please do following:
  3. When Command Prompt opens, copy and paste the following commands into it, press enter after each.
    del C:\Windows\Help\mui\0409\diskmgt.CHM
Reboot the machine.
Run the command sfc /scannow in an elevated commandprompt.
Provide a screenshot of the result.
PeterJ,
The SFC Scan was unable to repair everything and warrants a reboot. I am rebooting now and have attached the SFC Snip and CBS.log for your review.
Thanks,
joe_rockstar
,|m|
  • CBS.log
    CBS.log
PeterJ,
Per your direction see copied text below.
Start time: 2022-05-21 17:13:48.273
FileScan::
[0: 2] C:\Windows\winsxs\x86_microsoft-windows-imageres_31bf3856ad364e35_6.1.7600.16385_none_dc93f95659399ba8\imageres.dll
Expected: gnYNvd040qMcqvUdBl305+HQ8MInM6CvZTd26/e3lHA=
Successfully traced component x86_microsoft-windows-imageres_31bf3856ad364e35_6.1.7600.16385_none_dc93f95659399ba8.
Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery
[C:\Windows\SysWOW64\imageres.dll]
[1: 4] C:\Windows\winsxs\amd64_microsoft-windows-imageres_31bf3856ad364e35_6.1.7600.16385_none_38b294da11970cde\imageres.dll
Expected: ZRZb0TEFaBbwCdmH/Hishv/gw8OKJ+c/hzWGt/9NWc8=
Successfully traced component amd64_microsoft-windows-imageres_31bf3856ad364e35_6.1.7600.16385_none_38b294da11970cde.
[C:\Windows\System32\imageres.winaero.bak_195202295024]
[C:\Windows\System32\imageres.winaero.bak_11102021153639]
[C:\Windows\System32\imageres.dll]
Finish time: 2022-05-21 17:16:36.551
Script hash: hkLyEeR2Yw1xL6ymuO3iAh81g9puV13PFnOWeM/sH98=
Thanks,
joe_rockstar
,|m|
The log result looks normal.
Reboot the machine.
Copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
