JillHan
- Apr 18, 2025
- 29
Hi Sysnative,
I'm seeking advice on what I'm supposed to do with my built in microphone. So to speak every time I use it to record myself using camera or sound recorder. It doesn't record any sounds at all but instead I only hear a very low volume static noise after I play the recorded file.
I tried reinstalling the audio driver but doesn't seem to fix the issue. Also maxing out the volume of the input device on the settings but still to no avail it doesn't fix the issue.
On top of that not only the built in mic not picking up any sound. Also any external Mic that I used doesn't pick anything also.
Here are some information on my device for reference:
Microphone Realtek(R)Audio: Driver Version - 10.0.22621.1
Realtek Audio Console: Audio Driver Version - 6.0.9697.1
OS: Windows 11 23H2 build (22631.5189)
Thank you for your support.
