The logs displayed drive file system corruption.
If you can find some server downtime > run Chkdsk /r / v C:
Open administrative command prompt and type or copy and paste:
chkdsk /r /v
This may take hours to run so plan to run overnight.
C:\Windows\system32>chkdsk /r /v
Cannot lock current drive.
Type: Y
reboot
Use the information in this link to find the chkdsk report in the event viewer.
Copy and paste into notepad > save to desktop > post into the thread using a one drive, drop box, or google drive share link:
Read Chkdsk Log in Event Viewer in Windows 10 Windows 10 Performance Maintenance Tutorials
Event[34747]:
Log Name: System
Source: Ntfs
Date: 2021-01-14T23:34:25.407
Event ID: 55
Task: N/A
Level: Error
Opcode: Info
Keyword: N/A
User: S-1-5-18
User Name: NT AUTHORITY\SYSTEM
Computer: USDC1INFMSBK02P.apll.com
Description:
A corruption was discovered in the file system structure on volume C:.
A corruption was found in a file system index structure. The file reference number is 0x100000000637d. The name of the file is "\Windows\WinSxS\Temp\PendingRenames". The corrupted index attribute is ":$I30:$INDEX_ALLOCATION".
Event[8078]:
Log Name: Application
Source: Chkdsk
Date: 2021-01-14T23:34:25.000
Event ID: 26228
Task: N/A
Level: Information
Opcode: Info
Keyword: Classic
User: N/A
User Name: N/A
Description:
Chkdsk was executed in verify mode on a volume snapshot.
Checking file system on \Device\HarddiskVolume2
Insufficient storage available to create either the shadow copy storage file or other shadow copy data.
A snapshot error occured while scanning this drive. Run an offline scan and fix.
