Speccy Link: http://speccy.piriform.com/results/lcnm6GbWTfZN4CtuGSrACFi
Dropbox Trace/Speccy Link: tracespeccy upload
- I am currently having issues where audio will drop or a high pitched noise will happen while using DJ software (Rekordbox). Sometimes the software will freeze and audio will continue to play. I have noticed there have been CPU or Memory spikes. When I close the WIFI it helps a bit. It doesn't always happen but has been happening sporadically last 2 months. I've cleared hard drive space and contacted Pioneer who sent me here.
- OS ? Windows 10
- x64 (64bit)
- What was original installed OS on system: Windows 10
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? OEM
- Age of system? (hardware) 2 years
- Age of OS installation? 2years
- Have you re-installed the OS? No
- System Manufacturer? HP
- Laptop or Desktop? Laptop
- Exact model number (if laptop, check label on bottom) HP Pavilion Gaming Laptop 15 - dbk0xx
- CPU - Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz
- RAM (brand, EXACT model, what slots are you using?) 32gb stock
- Video Card - Intel UHD Graphics 630 (HP)\4095MB NVIDIA GeForce GTX 1650 (HP)
- Is driver verifier enabled or disabled?
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) windows defender
- Are you using proxy, vpn, ipfilters or similar software? no
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
- Are you currently under/overclocking? Are there overclocking software installed on your system? no and no
