MagikGimp
- Nov 19, 2021
- 12
This is only a recent problem. I have some suspicions-
http://speccy.piriform.com/results/FsPSrSB7J0MEKedCvREwlut
trace: trace (20-11-21 00.30).etl (files on my desktop are uploaded to Google Drive so I couldn't zip this before it was already uploaded unfortunately)
SysnativeFileCollectionApp: SysnativeFileCollectionApp (20-11-21).zip
- A recent hp printer install. It uses Scan to Computer technology which I suspect is constantly pinging out over wi-fi even though the process is disabled and my adaptor is off.
- I recently installed WSL (Linux integration) but then I have my doubts on this as it's now uninstalled (distro install failed and I realised I wasn't as interested as I thought) and shouldn't do anything until invoked anyway. I'm also of the opinion that Linux desktop can be buggy in general (server/pro stuff is good of course. Sorry if that irritated you).
- Recent Windows updates. Had both the October and November 'fixes'.
- Nvidia drivers. Have installed the latest drivers, two times, two different versions and have seen threads about a BSOD I had today (DPC_WATCHDOG_VIOLATION) that may have caused that.
- I still have at least one IDE drive on this machine. Years ago there was an issue with XP where you had to delete the drivers for the IDE interface and then Windows would reinstall them which would fix a similar problem to what I'm experiencing now. Is this still an issue? I find that hard to believe.
- Aging hardware in general. I've read that failing mobo chips can cause problems.
- P2P file transfer apps although I haven't changed anything regarding those for a while now and have only recently started having trouble.
- Problems also seem worse when I'm using my Bluetooth headset? It's been OK for a couple of months though. I recently updated the driver with a 3rd party app. I didn't update any other drivers.
- Write a brief description of your problem. See above.
- OS? Windows 10 Home x64 20H2 (10.0.19042.1348) OEM version (Windows 7 licence)
- Age of system? 10+ years.
- Age of OS installation? 9+ years. I had proof of this just the other day but I've forgotten which app was showing me this.
- Have you re-installed the OS? No. And I don't intend to.
- System specs? See Speccy output.
- Is driver verifier enabled or disabled? I forget. I do have 3rd party driver apps installed that may disable this feature if I remember correctly?
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Windows Security.
- Are you using proxy, vpn, ipfilters or similar software? No.
- Are you using Disk Image tools? Yes.
- Are you currently under/overclocking? Are there overclocking software installed on your system? No. Yes (inactive).
- Other? I have run LatencyMon which showed problems and mentioned wi-fi and to disable CPU throttling which I'm not doing because it hasn't been an issue before. I have been having BIOS messages about CPU fan errors every time I boot for months now though. Probably because I need to clean the cooler?
