Hi all,
I keep experiencing an issue with my PC, where the microphone input from my headset is frequently not detected. The issue occurs after the PC has gone into Sleep mode and been restarted, and then requires 3 restarts to fix each time. The headset itself is working fine, and has been tested on my laptop with no issues.
The headset has two 3.5mm jacks - one for audio, the other for microphone line in.
When plugged in:
1) Microphone starts as working (e.g. after previously restarting several times)
2) Computer goes into sleep mode - potentially multiple times.
3) Microphone is no longer detected by PC, and troubleshooting indicates that nothing is plugged into Line In.
When restarting - two things happen:
1) After restart, if the headset is plugged into the computer the audio settings do not open. Instead I get a loading screen when I try and open these. I can open the settings after unplugging the headset.
2) The microphone is not detected the first few times - repeatedly plugging / unplugging and running microphone troubleshooting does not fix this. Only restarting (usually 3 times) fixes this.
I've updated audio drivers to the latest from the Dell site, and I'm pretty baffled by what's happening. I feel like it's a driver issue, but I'm not sure how to fix it.
Appreciate any help with this!
