[SOLVED] Audio issues - pops and stutter, single incidence of BSOD
be4con
I've been suffering from audio issues for a while and just tolerating them but I suffered a BSOD the other week and thought it was probably about time I tackled the issue.
I've been running LatencyMon today and it's identified:
CONCLUSION
LatencyMon has been analyzing your system for  0:12:38  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        BERTHA_5
OS version:                                           Windows 7 Service Pack 1 , 6.1, build: 7601 (x64)
Hardware:                                             ASUSTeK Computer INC., M4A89GTD-PRO
CPU:                                                  AuthenticAMD AMD Phenom(tm) II X4 B55 Processor
Logical processors:                                   4
Processor groups:                                     1
RAM:                                                  16382 MB total
CPU SPEED
Reported CPU speed:                                   2508 MHz
Highest measured interrupt to process latency (µs):   51242.881969
Average measured interrupt to process latency (µs):   7.690992
Highest measured interrupt to DPC latency (µs):       51238.391420
Average measured interrupt to DPC latency (µs):       4.350270
 REPORTED ISRs
Highest ISR routine execution time (µs):              287.742823
Driver with highest ISR routine execution time:       ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Highest reported total ISR routine time (%):          0.033194
Driver with highest ISR total time:                   hal.dll - Hardware Abstraction Layer DLL, Microsoft Corporation
Total time spent in ISRs (%)                          0.074013
ISR count (execution time <250 µs):                   899055
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                3
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
Highest DPC routine execution time (µs):              51263.994418
Driver with highest DPC routine execution time:       ndis.sys - NDIS 6.20 driver, Microsoft Corporation
Highest reported total DPC routine time (%):          0.458949
Driver with highest DPC total execution time:         NETIO.SYS - Network I/O Subsystem, Microsoft Corporation
Total time spent in DPCs (%)                          1.144926
DPC count (execution time <250 µs):                   4337128
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                24869
DPC count (execution time 1000-1999 µs):              2330
DPC count (execution time 2000-3999 µs):              4
DPC count (execution time >=4000 µs):                 0
 REPORTED HARD PAGEFAULTS
Process with highest pagefault count:                 outlook.exe
Total number of hard pagefaults                       27041
Hard pagefault count of hardest hit process:          13362
Number of processes hit:                              13
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       36.732933
CPU 0 ISR highest execution time (µs):                218.300638
CPU 0 ISR total execution time (s):                   1.018378
CPU 0 ISR count:                                      688881
CPU 0 DPC highest execution time (µs):                51263.994418
CPU 0 DPC total execution time (s):                   19.264253
CPU 0 DPC count:                                      3719325
CPU 1 Interrupt cycle time (s):                       19.520155
CPU 1 ISR highest execution time (µs):                222.677831
CPU 1 ISR total execution time (s):                   0.022823
CPU 1 ISR count:                                      3568
CPU 1 DPC highest execution time (µs):                1633.526715
CPU 1 DPC total execution time (s):                   3.819939
CPU 1 DPC count:                                      57816
CPU 2 Interrupt cycle time (s):                       18.219967
CPU 2 ISR highest execution time (µs):                278.333333
CPU 2 ISR total execution time (s):                   0.100178
CPU 2 ISR count:                                      16482
CPU 2 DPC highest execution time (µs):                1613.968102
CPU 2 DPC total execution time (s):                   3.597926
CPU 2 DPC count:                                      99771
CPU 3 Interrupt cycle time (s):                       34.885880
CPU 3 ISR highest execution time (µs):                287.742823
CPU 3 ISR total execution time (s):                   1.104441
CPU 3 ISR count:                                      190127
CPU 3 DPC highest execution time (µs):                2003.291467
CPU 3 DPC total execution time (s):                   8.058878
CPU 3 DPC count:                                      487422
I've done a few troubleshooting maintenance tasks and they haven't helped so far:
dism /online /cleanup-image /scanhealth
Advanced disk cleanup
I could do with a hand trying to get to the bottom of this. I've got some basic windows knowledge, but it's better to consider me a trained monkey with respect to resolving this. Thanks!
Hi. . .
That is very odd.
Go to \windows\minidumps - copy the entire folder to Docs or Desktop; zip and attach to your next post.
Regards. . .
jcgriff2
