BorkenStock
- May 19, 2022
- 4
- Had this problem for awhile. Exactly the same as a lot of people on here. High latency DSP coming from storahci.sys (about 30,000) causing crackles and pops. Causes screen to freeze very minimally as well. Tried updating MOBO Drivers, Installing audio drivers, made sure IDE ATA/ATAPI were all Standard SATA AHCI (reverted to AMD, which wouldnt let PC launch, launched in safe mode and reinstalled), unplugging extra storage devices, disabling HTEP, disabling Dynamic Tick Timer, SFC Scannow, etc etc. I've done everything under the sun that I've been able to find on this issue. Only thing I've yet to try that I've seen is updating SATA firmware? I would do it but I don't know where to find the correct firmware (have Crucial P1 M.2 2280 1TB) and I also haven't downloaded RAID drivers for AMD, but I didn't think that was necessary/involved with this issue. It seems to get better with everything I do for just a little while, then boom it comes back full force. Any help would be greatly appreciated!!!
- OS Windows 10 Pro
- x64 (64bit)
- What was original installed OS on system: Windows 10 Pro
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Bought from retailer
- Age of system? (hardware) 2 years
- Age of OS installation? 1 month
- Have you re-installed the OS? Yes, last month
- System Manufacturer? Made myself
- Laptop or Desktop? Desktop
- Exact model number (if laptop, check label on bottom) N/A
- MotherBoard - (if NOT a laptop) X570 UD
- CPU - Ryzen 5 3600
- RAM (brand, EXACT model, what slots are you using?) Corsair Vengeance RGB Pro 2x8GB. A2 B2
- Video Card - Sapphire RX 5700 XT
- Power Supply - brand & wattage (if laptop, skip this one) ThermalTake Smart 700W
- Is driver verifier enabled or disabled? Never done anything with it so assume disabled
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)Kaspersky
- Are you using proxy, vpn, ipfilters or similar software? No
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) No
- Are you currently under/overclocking? Are there overclocking software installed on your system? XMP Ram 3600, no
