ohioisonfire
- Dec 12, 2020
- 12
Hello!
I have been having the worst time with this audio popping/crackling and I am here because I found you through a web search. I am very deep in the rabbit hole and I am hoping this is where it comes to a close. I will provide you as much detail as I can remember because I have been tosslin' with this cruel mistress for awhile now. I started noticing this a few months back.
My computer specs:
CPU: Intel i7 10700k @ 3.2GHz
RAM: G.Skill TridentZ RGB 16gb (4 x 8GB) 288 pin DDR4
Motherboard: Gigabyte Z490 Gaming X
GPU: Foundeds edition 2080 TI
SSD: Samsung EVO 970 m.2 SSD
Hardware:
Software(firmware??)
Contents of File
I also followed all the requirements prior to posting. Really hoping that someone can resolve this because it really bothers me
Resources:
Power Throttling Instructions Followed: Managing Power Throttling on Windows 10
[SOLVED] - High DPC latency and popping noises
I apologize if I am missing any details I would be happy to provide them. I just spent the last 10 hours coding so my brain is a little fried.
Thank you for taking the time to read this!
My computer specs:
Hardware:
- Tried multiple different speakers/headset, tested with other computers (no popping)
- Checked for anti-virus causing it
- LatencyMon
- Files attached, said it could be throttling, 1 or more DPC routines that belong to a driver running in your system, check for bios updates
- Disabled Throttling by;
- Task manager (details show column Power throttling)
- Power Settings (all have been set to performance)
- Registry
- Bios
- Bios updates:
- Bios currently running on most recent firmware
- "Disable all sound effects"
- I tried this and it did not prevent the issue. I am currently running an amp/dac setup and have an equalizer that relies on having that option enabled.
- I also ran all the steps up until where Windows Resource Protetection found Corrupt files but was unable to fix some of them
Contents of File
- Latencymon diagnostics results
- SFCdata
- SFCFix
- SFCFix-data
- The entire CBS file
Resources:
