[SOLVED] Applications not Installing Or Running Properly
Itachiness
Contributor
I'm not certain this is the correct place to post this, so if it isn't, please let me know where I should post this.
I'm having an issue with a couple of applications properly installing on this 2016 server that appear to relate to .net. It says I'm missing a component. I've tried reinstalling .net 4.8 and while I initially had trouble getting it reinstalled, I was able to get it done with the help of support in this forum.
Here is part of the description from the event log of one of the services not working properly when installing it:
Service cannot be started. System.IO.FileNotFoundException: Could not load file or assembly 'System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
File name: 'System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
There is a .NET Runtime error that happens at the same time:
og Name: Application
Source: .NET Runtime
Date: 1/27/2025 8:21:22 AM
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
Description:
Application: CagService.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at CentraStage.Cag.Core.Agent.CsConnection.WebPortOk()
at CentraStage.Cag.Core.Agent.CsConnection.MaintainConnection(System.Action`2<CentraStage.Cag.Core.Messaging.XmlRpcIncomingControlMessage,CentraStage.Cag.Core.Messaging.AddToOutgoingQueueDelegate>)
at CentraStage.Cag.Core.Agent.MainLoop+DelegateTask.Execute()
at CentraStage.Cag.Core.Agent.MainLoop.Loop()
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Hi @Itachiness,
Step 1. Download
Step 2. Reboot the server and run
ComponentsScanner again.
  • Right-click ComponentsScanner.exe and select "Run as administrator", click Yes on the UAC (User Account Control) prompt which appears.
  • Follow the on-screen instructions.
  • Once complete, a report will be saved to your desktop called ComponentsScanner.txt.
  • Post the logfile ComponentsScanner.txt as attachment into your next reply.
This looks good, do you still have issue with .NET applications?
I am still having an issue.
I attached new event logs. These are three events that are logged after launching the executable for the application.
The appliction "CagService.exe" is a part of Datto RMM as it seems, and the EventLog shows also:
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Fusion]
"EnableLog"=dword:00000001
I had the fusion logging enabled. I have some of those logs would you like me to upload them?
Please run the following command in an elevated prompt and copy paste the result in your next post.
reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Fusion" /s
The output shows:
    EnableLog    REG_DWORD    0x0
So please run the following commands in an elevated prompt and post the result.
reg add HKLM\SOFTWARE\Microsoft\Fusion /v EnableLog /t REG_DWORD /d 0x1 /f
reg query HKLM\SOFTWARE\Microsoft\Fusion
Please run the .NET application again and post the result now the "EnableLog" value is set to "0x1".
Please run the following script in an elevated PowerShell prompt, this will show some more information about the installed .NET versions in table style.
Get-ChildItem 'HKLM:\SOFTWARE\Microsoft\NET Framework Setup\NDP' -recurse |
Get-ItemProperty -name Version,Release -EA 0 |
Where { $_.PSChildName -match '^(?!S)\p{L}'} |
Select PSChildName, Version, Release
Try also the following;
Here is the output of the powershell script and I'll work on running that installer/repair option
I get this pop up when attempting to run the installer, I don't get any prompt for a repair option -
Download the
Microsoft .NET Framework Repair tool and save it to your Desktop.
  • Right-click on NetFxRepairTool.exe and select Run as Administrator.
  • Agree with the license terms "I have read and accept the license terms" and click Next.
  • After checking, the tool will indicate which problems need to be fixed.
  • Click on Next to continue, when this process is finished click Next.
  • The tool will now collect the log files... > when completed the following file is created: FixDotNet****.cab.
  • Click on Finish to close the tool.
  • Right-click on the file FixDotNet****.cab and choose Send to > Compressed (zipped) folder.
  • Attach the ZIP file in your next reply.
Please do the followwing:
1. Make a full backup (snapshot) of the server.
2. Run the following command to uninstall .NET 4.x
dism /online /disable-feature /FeatureName:netfx4 /all
3. Reboot the server and reinstall .NET 4.x
dism /online /enable-feature /featurename:netfx4 /all
4. You can also use the offline installer if needed! Download .NET Framework 4.8 Offline Installer
