What's new
[SOLVED] [8.1Upd3 x64] icrav03.rat & CNBJ2530.DPB corruption
jspsys
Well-known member
Hi, tank you very much.
But I still can not install the same windows updates, error code 800736B3. I think the problem is in the latest Framework version installed.
softwaremaniac
Moderator, BSOD Kernel Dump Expert, Windows Update Instructor
Staff member
Croatia
Aha, please upload the latest CBS.log (after the update has failed), so I can inspect it.
jspsys
Well-known member
Ok, thanks. Here there is the last cbs. I have done a new DISM after the windows update failed.
softwaremaniac
Staff member
Croatia
2. Open an elevated Command Prompt and run Windows Updates just like you have in the past.
softwaremaniac
Staff member
Croatia
I think I see the issue. Please upload your COMPONENTS hive for me once again.
softwaremaniac
Staff member
Croatia
Install Update with DISM
  1. Download the update MSU here:
    http://download.windowsupdate.com/d/msdownload/update/software/secu/2017/11/windows8.1-kb4054519-x64_ad78da956d88ae3cd98982c11730240668c0e93f.msu
    cd C:\temp
    expand windows8.1-kb4054519-x64_ad78da956d88ae3cd98982c11730240668c0e93f.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows8.1-kb4054519-x64.cab
    Restart Windows to complete this operation.
    Do you want to restart the computer now (Y/N)?
  9. Please paste (Ctrl+V) it into your next post, then zip and attach C:\Windows\Logs\CBS\CBS.log
jspsys
Well-known member
Hi, after the steps, the same error as usual.
Microsoft Windows [Versión 6.3.9600](c) 2013 Microsoft Corporation. Todos los derechos reservados.
C:\WINDOWS\system32>cd C: \ temp
El sistema no puede encontrar la ruta especificada.
C:\WINDOWS\system32>cd C:\temp
C:\temp>expand windows8.1-kb4054519-x64_ad78da956d88ae3cd98982c11730240668c0e93f
.msu -f:* C:\temp
Microsoft (R) Utilidad de expansión de archivos versión 6.3.9600.17415
Copyright (c) Microsoft Corporation. Todos los derechos reservados.
Agregar C:\temp\WSUSSCAN.cab a la cola de extracción
Agregar C:\temp\Windows8.1-KB4054519-x64.cab a la cola de extracción
Agregar C:\temp\Windows8.1-KB4054519-x64-pkgProperties.txt a la cola de extracci
ón
Agregar C:\temp\Windows8.1-KB4054519-x64.xml a la cola de extracción
Expandiendo archivos ....
Se completó la expansión de archivos ...
4 total de archivos.
C:\temp>DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows8.1-kb4054519-
x64.cab
Herramienta Administración y mantenimiento de imágenes de implementación
Versión: 6.3.9600.17031
Versión de imagen: 6.3.9600.17031
Procesando 1 de 1: Agregando paquete Package_for_RollupFix~31bf3856ad364e35~amd6
4~~9600.18874.1.4
[==========================100.0%========================= ]
Error: Package_for_RollupFix Error: 0x800736b3
Error: 14003
El ensamblado referido no está instalado en su sistema.
El archivo de registro de DISM se encuentra en C:\WINDOWS\Logs\DISM\dism.log
C:\temp>
Thank you veru much,
softwaremaniac
Staff member
Croatia
jspsys
Well-known member
Hi, here is the log
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-01-09 00:55:49.422
Using .txt script file at C:\Users\kas_l_000\Desktop\SFCFixScript.txt [0]
Finish time: 2018-01-09 00:55:49.438
Script hash: 49WIZHLaE8m5MaAxHBbyEeZP9WYalMk3kxxhyRAVvzE=
Thank you very much
softwaremaniac
Staff member
Croatia
Try updating now and provide CBS.log if it fails.
jspsys
Well-known member
Hi, the windows update failed again with the same error.
Here is the cbs.
Thank you very much.
BrianDrab
Administrator, Windows Update Instructor, Security Analyst
Staff member
Hi - softwaremaniac asked that I step in to assist as he will be unavailable for a little bit.
Please attempt to uninstall KB3172614 and let me know if it is successful.
jspsys
Well-known member
Hi, I have not got this update installed. It is in the queue of the 9 pending windows updates. I've tried to install some individually and it didn't work either. I think the problem is in the latest version of .NET Framework installed (4.5.2)
Thank you very much,
BrianDrab
Staff member
I've seen you mention a few times now that you think .NET Framework is the issue. Have you attempted to uninstall the .NET Framework 4.5.2?
jspsys
Well-known member
Hello, I have tried to uninstall Framework 4.5.2 but I do not get it. Do you have a guide to uninstall it?
Thank you.
BrianDrab
Staff member
