[SOLVED] [7SP1 x64] Monthly Quality Rollup failures - KB4041681, KB4054518, and KB4056894
Prestones
Contributor
I was out of town for a bit, and when I returned and fired up my desktop I had a number of Windows updates to slog through, as well as a number of program updates. I just found that KB4041681, KB4054518, and KB4056894 all failed to install, all with error code 800004005. I tried running Hotfix KB4054518 without any luck - the installs continue to fail. I turned off Windows update completely (no sense making the log jam any worse), and thought I'd better seek help from someone more capable.
FWIW, I'm using Window7 Pro SP1 x64 and Malwarebytes Pro AV. Checking the registry shows Malwarebytes has set the required registry entry for KB4056894.
Any clues would be greatly appreciated.
Re: Monthly Quality Rollup failures - KB4041681, KB4054518, and KB4056894
Thanks for the quick response!
Additional information:
SFC Scan -> Windows Resource Protection did not find any integrity violations
SURT/DISM Scan -> The System Update Readiness Tool (KB947821) hung while initializing and never recovered. I gave it several hours. Note in the screenshot above that it ran successfully twice earlier today.
For my next trick?
For my next trick?
After rebooting this morning, I retried the System Update Readiness Tool - and it ran to completion ("Installation complete")
I'll continue working through the posting instructions and post back here once again.
The SFCFix txt output file follows:
Start time: 2018-01-15 12:22:41.768
SURT total detected corruption count: 9
Finish time: 2018-01-15 12:49:21.434
CBS file link: Dropbox - CBS.zip
Thanks again, and apologies for not having seen and followed instructions earlier.
Interesting:
2. Attempt to run Windows Updates just like you have in the past.
3. Stop Process Monitor as soon as the update. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
The Process Monitor file was huge - thankfully it shrank considerably when zipped. Zip file containing both Dropbox - CBS + Logfile.zip
Hopefully I turned off Process Monitor at the right time - I waited until the message Installation Complete showed for KB4056894, and before rebooting. The installation failure typically occurs when I reboot to complete the installation.
Apologies - I'm attempting to operate above my pay grade in this thread, and my ignorance is showing. Have a look at Dropbox - setupapi.dev.log
Perhaps of futher interest is the fact that the installation failure always occurs late in the process when rebooting - when the "Please Wait" screen reaches 98% or more - then the system reverts.
Thanks for your efforts - and the update. I'll keep an eye out for your next comment.
Unfortunately, my system is older and has no Secure Boot in BIOS - let alone UEFI. The security settings consist of "Set Supervisor Password" and "Set User Password". Both are currently blank.
The BIOS Utility Setup is V 02.61 from American Megatrends, and the BIOS itself is version 2209 (Build: 9/21/10) - the most recent available for the motherboard (Asus P6T Deluxe).
A sad state of affairs, but there you have it.
Hard drive setup:
C: (handling program data) - 4 1.0TB drives in a RAID 1/0 configuration
D: (handling data files) - 4 1.5TB drives in a RAID 5 configuration
The arrays are handled by a RocketRAID 2680 card plugged into the motherboard, with an onboard BIOS V1.0 from HighPoint Technolgies
Hard Disk Sentinel reports the disks are all healthy, although there is one disk in D: I should consider replacing in the not-too-far-distant future.
Niemiro's code seems to be very adaptable. I'm hopeful it'll shed some light on the issue.
Start time: 2018-01-27 10:47:21.176
Using .txt script file at C:\Users\Dennis\Desktop\SFCFixScript.txt [0]
Trace::
Successfully traced component amd64_microsoft-windows-m..ents-mdac-ado15-dll_31bf3856ad364e35_6.1.7600.21227_none_68f23680a34301a2.
    Package_18_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.2698365-129_neutral_LDR3
Finish time: 2018-01-27 10:47:22.969
Script hash: 0nsn/1GY0USH6g3MYCjPmptrFOFnYIfJddsCTCAnqFk=
SFC Scan
