[SOLVED] 0x162: KERNEL_AUTO_BOOST_INVALID_LOCK_RELEASE. FIX: updated chipset driver and BIOS.
fantim
· OS - Windows 10
· x64 (64-bit)?
· What was the originally installed OS on the system? Was Windows 10
· Age of system (hardware):3 years
· Age of OS installation - have you re-installed the OS?
Processor AMD Ryzen 5 1600 Six-Core Processor, 3693 Mhz, 6 Core(s), 12 Logical Processor(s)
· Video Card Gtx Nvidia 1070
· MotherBoard - AB350M-Gaming 3-CF
· Power Supply - wattage 750W
System Manufacturer Gigabyte Technology Co., Ltd.
· Desktop
I runned every test i could i reinstalled windows like 3 times but the BSOD still appears...
I get this type of error on a daily basis, please help.
Hi fantim. 🖖
I didn't find your motherboard in gigabyte website.
What does that CF stand for, at the end of GA-AB350-Gaming 3-CF?
I found this: GA-AB350-Gaming 3 (rev. 1.x): is It the same?
If it is the same, have you already downloaded and installed the latest chipset driver from your motherboard support webpage?
Here: GA-AB350M-Gaming 3 (rev. 1.x) | Motherboard - GIGABYTE Global
And the latest software for your CPU? Here: https://www.amd.com/en/support/cpu/...d-ryzen-5-desktop-processors/amd-ryzen-5-1600
Hi fantim. 🖖
What that CF stand for, at the end of GA-AB350-Gaming 3-CF?
Yep that's the same motherboard, i will download the chipset driver for the motherboard. Thank you for your help!
I saw you have also got a full memory dump in c:\windows: copy/move it to your desktop, zip it and post it here.
In the meanwhile, run these commands and post their results here:
chkdsk c:
It isn't a public downloadable file and I'm not registered to dropbox... Maybe other helpers here aren't registered too, or maybe yes; you have probably the option to make it public; could you modify it?
MEMORY.zip maybe this works
EDIT: ah its the same... i will try with another app
EDIT2: MEMORY.zip this should work
Just my 2 cents - then I'll butt out and leave this to those already helping you...…..
1) BIOS dates from 2017 - strongly suggest updating it if an update is available.
2) Although the kernel memory dump blames ntoskrnl.exe (the kernel/core of the OS), it's likely not this. But instestingly, most of the 3rd party drivers mentioned in the dump are AMD CPU drivers. Gotta wonder if it's the CPU software or hardware?
Good!
Let's see if the chipset update worked.
If you still get the BSOD, update the BIOS.
Otherwise, it isn't necessary.
Read/apply the following only if you continue to get BSODs:
Good!
Read/apply the following only if you continue the get BSODs:
If I encounter another BSOD I will follow your instructions.
Thank you very much for your help! Have a good day!
I got a different BSOD...
Post the new minidump.
It's in c:\windos\minidump.
Copy that folder to your desktop.
Get the more recent dump and upload it here (or use a file sharing service on the web, like Google drive or OneDrive).
