06-23-2016, 12:35 PM #1
- Join Date
- Jun 2016
- Location
- Istanbul
- Posts
- 14
Graphic Problems after Miner Virus ?
Hello friends, i have problem about my graphics in games. I opened a thread in HERE. It's new and you can read it in 1 minutes. I want to ask you a question about it.
I had a miner virus before i reformatted my computer now its safe. I checked with some known malware softwares and nothing found but my graphics in games has shimmering effects, flickering shadows and anti aliasing problems after new installed OS (i done it 4-5 times). The problem is not about GPU cuz we changed it and problem still persist. I checked all internet about this issue and people changed nearly all parts of system but no solution found yet.
My question is " is it possible any kind of virus like rootkits hide in my hardware and ruin my graphics ? " or do you have any idea that can cause this.
Thanks for your helps.
Ad Bot
- Beep.
06-23-2016, 01:47 PM #2
Re: Graphic Problems after Miner Virus ?
Please download Malwarebytes Anti-Malware to your desktop.
- Double-click mbam-setup-2.X.X.XXXX.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to the following:
- Launch Malwarebytes Anti-Malware
- A 14 day trial of the Premium features is pre-selected. You may deselect this if you wish and it will not diminish the scanning and removal capabilities of the program.
- Click Finish.
- On the Dashboard, click the 'Update Now >>' link
- On the Settings tab > Detection and Protection subtab, Detection Options, tick the box 'Scan for rootkits'.
- Click on the Scan tab, then click on Scan Now >> . If an update is available, click the Update Now button.
- A Threat Scan will begin.
- With some infections, you may see this message box.
- 'Could not load DDA driver'
- Click 'Yes' to this message, to allow the driver to load after a restart.
- Allow the computer to restart. Continue with the rest of these instructions.
- When the scan is complete, click Apply Actions.
- Wait for the prompt to restart the computer to appear, then click on Yes.
How to get logs (Export log to save as txt):
- After the restart once you are back at your desktop, open MBAM once more.
- Click on the History tab > Application Logs.
- Double click on the scan log which shows the Date and time of the scan just performed.
- Click 'Export'.
- Click 'Text file (*.txt)'
- In the Save File dialog box which appears, click on Desktop.
- In the File name: box type a name for your scan log.
- A message box named 'File Saved' should appear stating "Your file has been successfully exported".
- Click Ok
- Copy/paste that saved log to your next reply.
06-24-2016, 03:24 AM #3
- Join Date
- Jun 2016
- Location
- Istanbul
- Posts
- 14
Hello, i did what you said to me. I think its clear.
Malwarebytes | Free Anti-Malware & Internet Security Software
Scan Date: 24.06.2016
Scan Time: 10:17
Logfile: scan.txt
Administrator: Yes
Version: 2.2.1.1043
Malware Database: v2016.06.23.06
Rootkit Database: v2016.05.27.01
License: Trial
Malware Protection: Enabled
Malicious Website Protection: Enabled
Self-protection: Disabled
OS: Windows 10
CPU: x64
File System: NTFS
User: Kraken
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 279634
Time Elapsed: 4 min, 1 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
(No malicious items detected)
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
06-24-2016, 11:33 AM #4
Yes, all clear. I didn't think that there was a rootkit but it didn't hurt to check.
06-26-2016, 04:59 PM #5
- Join Date
- Jun 2016
- Location
- Istanbul
- Posts
- 14
Thanks, at least we tried :)
Similar Threads
[SOLVED] W7 SP1 : Error 0x80070103 - WDDM graphic card update fails to install
By Just in forum Windows UpdateReplies: 10Last Post: 03-30-2016, 03:32 PM -
Best gaming graphic cards
By JMH in forum Gamers' RetreatReplies: 4Last Post: 06-07-2012, 08:38 PM -
When I say 'virus,' you know exactly what I mean
By JMH in forum News You Can UseReplies: 0Last Post: 05-11-2012, 05:24 AM
