02-28-2015, 01:08 PM #1
- Join Date
- Apr 2012
- Location
- far reaches of the galaxy, but you knew that...
- Posts
- 436
Migrating From a 2003 Domain to a 2008 r2 Domain
Stub - In 2013, I compiled all the info required to do this, includes a very important step that you must do, or Group Policy fails!!
(as you know, Microsoft is soon to abandon the venerable Windows Server 2003.)
hopefully, will post this tonight (Saturday, 2/28)
Ad Bot
- Beep.
03-02-2015, 01:00 AM #2
- Join Date
- Apr 2012
- Location
- Posts
- 436
Re: Migrating From a 2003 Domain to a 2008 r2 Domain
Greets, technophiles!
(originally posted 19 June 2012 - 09:13 PM)
here's some stuff in one place that i've not seen in one place anywhere else on
preparatory work before adding a 2008 r2 server as a domain controller
to a server 2003 domain controller environment.
(1)(a) you need to know which domain controller (DC) has the fsmo (schema master) - How to view and transfer FSMO roles in Windows Server 2003
run cmd as administrator
regsvr32 schmmgt.dll
ok
start, run, mmc
file, add snap in
active directory schema
the name of the server will be to the right of "active directory schema" in the title bar and in the menu on the left.
ps
don't screw around here. you can destroy your domain.
(1)(b ) you need to know which DC has the Infrastructure Operations Master role
start, administrative tools, active directory users and pooters
right click the domain name
operations masters
infrastructure tab
voila, the server name you seek!
(2) you need to run adprep twice -
If your existing server is 32bit, run adprep32, not adprep
If you run adprep on a 32bit machine, you will get this error message
The image file D:\adprep\adprep.exe is valid, but is for a machine type
other than the current machine.
adprep.exe is on the Server 2008 r2 install disk in [drive letter:]\support\adprep
(2)(a) Log on to the server that you found in (1)(a) the fsmo (schema master)
as someone that is a member of both the "Enterprise Admins Group" and "Schema Admins Group"
(2)( b )Run this command on the server that holds the schema master operations master (also known as flexible single master operations or FSMO) role.
adprep /forestprep
note: this will run for a long time (15 to 20 min)
when "the command has completed successfully" is displayed - it is >not< done!
about 50 rows of dots (............) appear, 1 at a time, that's a lot of dots...
when "adprep successfully updated the forest-wide information." is displayed
and, you are returned to the command prompt,
then the command has completed.
(2)( c )Log on to the server that you found in (1)( b ) the Infrastructure Operations Master
(2)(d) Then run this command on the server that holds the infrastructure operations master role.
adprep /domainprep /gpprep note: you should see these lines, and be returned to the command prompt (runs very quickly)
Running domainprep ...
Adprep successfully updated the domain-wide information.
Adprep successfully updated the Group Policy Object (GPO) information.
(3) Make sure replication is running well in your domain. run this command
(this domain has only 2 DCs.)
repadmin /replsum /bysrc /bydest /sort:delta
Note: You should see something like this, with 0 errors, if errors, fix it now
Replication Summary Start Time: 2012-06-19 20:17:38
Beginning data collection for replication summary, this may take awhile:
Source DC largest delta fails/total %% error
SERVER 01h:21m:17s 0 / 5 0
TAHITI 46m:12s 0 / 5 0
Destination DC largest delta fails/total %% error
TAHITI 01h:21m:17s 0 / 5 0
SERVER 46m:12s 0 / 5 0
(4) Fix you physical network adapter's ip configuration
Set all network adapters to static ip addresses for both ipv4 and ipv6
if you do not run ipv6 yet, unselect it from the network adapter properties
if you do not want to use all your physical adapters,
unselect ipv4 and ipv6 on that (those) adapters
Failing to do so will give you an error when you run dcpromo, which you can elect to bypass, but not a good idea
(5) add the server to your domain
r click "computer"
properties
in the "computer name, domain, and workgroup settings" area, click "change settings"
computer name tab
"to rename this..." click the "change button"
under "member of"
select "domain"
type in the name of the domain, authenticate as a domain admin, restart the server
and while not part of prepartory work,
when you are ready to promote the 2008 r2 server to become a domain controller
start, run, dcpromo
that will open a gui that steps you through the process.
(careful you don't create a new forest or domain if that is not your intention...)
one last thing!
if you have xp or 2003 in your new 2008 r2 domain, and you use Group Policies it is imparative that you go to microsoft.com and download 2 things -
1. the group policy client side extension
2. xml-lite
download it for the spefic platform, xp or server 2003, and 32 or 64 bit.
remember! both must be loaded on each and every xp and 2003 machine in your new 2008 r2 environment!!
Similar Threads
IE9 ---> IE10 Not Working through Domain controlled WU
By Dtere1 in forum Windows UpdateReplies: 2Last Post: 06-27-2014, 10:54 AM -
13 Companies Want .app Domain - Top Most Coveted New TLDs
By zigzag3143 in forum News You Can UseReplies: 0Last Post: 06-13-2012, 05:46 PM
