Apr 12, 2012 Replies: 1 LOW-LEVEL Hard Disk Drive (HDD) FORMAT Download KillDisk Freeware zip file; extract ISO - http://www.killdisk.com/downloadfree.htm(select - Download DOS boot disk ISO image - http://software.lsoft.net/boot-cd-iso.zip)Use ImgBurn to burn KillDisk ISO to CD (select "Mirror 7 - Provided by Imgburn") - http://www.imgburn.com/index.php?act=downloadImgBurn - My recommendation is to use either CD-R CDs or DVD-R DVDs for the burning of the Killdisk ISO onto the CD or DVD.Select "write image file to disk" - as shown in the screenshot below - KillDisk - Boot system with the KillDisk CD. You may have to change the BIOS "firing order" (select the option so that the DVD/CD device boots before the hard drive); Select "Active KillDisk Free" -Select partition to format; repeat for all partitions - Back To Main Page 2009 - 2016 J.C. Griffith, Microsoft MVP Windows Expert - Consumer https://www.sysnative.com/jcgriff2/tutorials/killdisk_imgburn.html Last edited: Nov 2, 2019 Click to expand...
jcgriff2 Co-Founder / AdminBSOD Instructor/ExpertMicrosoft MVP (Ret.) Staff member Joined Feb 19, 2012 Posts 21,542 Location New Jersey Shore Jul 18, 2017 #2 Windows Setup: Installing using the MBR or GPT partition style Windows Setup: Installing using the MBR or GPT partition style
