bassfisher6522 Sysnative Staff Staff member Joined Jul 22, 2012 Posts 345 Mar 17, 2014 #1 I recently updated FF 27.1 to beta 28 to test the metro version of FF. No problems so far...although the metro version development is being dropped, it was a bit quirky to get used to. So I went back to version 27. I just re-downloaded it and ran it with out uninstalling FF. This is where all the issues started. At first my got this error..... So I went through my PC with every scan I have....then went through the registry and completely uninstalled anything related to Mozillia. I then ran Ccleaner registry cleaning tool. So far so good, then rebooted, re-installed FF and now I get this error.... The only way I can use FF is right clicking the icon on the desktop and select run as administrator.....What the H$#% can I do to resolve this issue.
P pepegot1 New member Joined Apr 30, 2014 Posts 3 Location Florida May 3, 2014 #2 Why did you not backup your profile with Mozbackup. It saves a lot of headaches. Backing up the computer to an image file is also wise. Work smart - not hard!
Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,022 Location Upstate, NY May 3, 2014 #3 Even though not developed by Mozilla, MozBackup is recommended in Mozilla KB articles (here for example, MozBackup - MozillaZine Knowledge Base). MozBackup is available at MozBackup - Backup tool for Firefox and Thunderbird.
blueelvis BSOD Kernel Dump Senior Analyst Joined Apr 14, 2014 Posts 970 Location India Jun 3, 2014 #4 I don't think it is a good idea to run any kind of registry cleaning softwares.
