Page 4 of 4 First 1234
  1. #61
    AceInfinity's Avatar
    Join Date
    Feb 2012
    Canada
    Re: What's the best Antivirus?
    Quote Originally Posted by Will Watts View Post
    Unless you've seen something I haven't, ESET and MSE have the lowest number of false positives out of any of the AV programs tested.
    Lowest? Specifically ESET I'm surprised at... Where are you getting this information? ESET was rated #1 for false positives from the last reports I've seen.
    Automation Programmer
    Microsoft MVP [2012 - 2018]
    • Ad Bot
      advertising
      Beep.
  2. #62
    Will Watts's Avatar
    Join Date
    Mar 2012
    %tmp%
    • specs System Specs
      • Manufacturer:
        Alienware M15x
      • Model Number:
        M15x
      • CPU:
        i5 520 M @ 2.40GHz
      • Memory:
        8GB
      • Graphics:
        ATI Radeon HD 5800
      • Hard Drives:
        720GB 7200 rpm
      • Operating System:
        Windows 8 + Ubuntu
    AV-Comparatives False Alarm Test » AV-Comparatives
    MSE had 0 false alarms, ESET had 4, Kaspersky 5, Trend Micro 7, Avira 10, Avast 11, McAfee 12, AVg with 36. By far the worst was Webroot, with 210 false alarms.
    Has Sysnative Forums helped you? Please consider donating to help support the forum.
  3. #63
    Join Date
    Feb 2012
    Canada
    I was looking at this: AV-Comparatives - Independent Tests of Anti-Virus Software - Real World Protection Test Overview
    It's been a while since I looked at any AVC reports but then ESET has dramatically improved since the last I seen. Just last year they were reported to be #1 for false alarms. It's hard to see the comparisons being made here, I don't fully trust any of these reports to be honest. I only use them as a guideline because I don't have time to test them in full myself. Various AV's work in different ways, so depending on the malware being tested or files in general, it may favor one or another AV for better results. This also has to do with the configuration of that AV during the test, and again, all AV's can be configured in different ways.
    Cool. I still am not a fan of ESET, but they improved. I would still choose Norton (symantec) or BitDefender over AVG or ESET though. MSE is always nice though, I wouldn't compare it to anything else because it's good in many other ways that other's aren't.
  4. #64
    Triple Helix's Avatar
    Join Date
    Feb 2013
    Ontario, Canada
      • Manufacturer:
        Alienware
      • Model Number:
        Alienware 17R5 2018
      • Motherboard:
        Alienware
      • CPU:
        Intel Core i9-8950HK 2.9GHz up to 5GHz
      • Memory:
        32GB of 2666Mhz G.SKILL Ripjaws DDR4
      • Graphics:
        NVIDIA GeForce GTX 1080 OC with 8GB GDDR5X
      • Sound Card:
        Impressive audio is powered by Klipsch and Creative SoundBlaster Pro Studio Software
      • Hard Drives:
        Samsung 960 Pro NVMe 512GB x 2
      • Disk Drives:
        ASUS USB 3.0 Blu-ray Writer Model BW-12D1S-U
      • Power Supply:
        Alienware 330W AC Adapter
      • Case:
        Laptop
      • Cooling:
        Copper Heat Pipes with Fans
      • Display:
        17.3 inch UHD (3840 x 2160) Laptop Display
      • Operating System:
        Windows 10 Pro x64
    Well I use Webroot SecureAnywhere 2013 Complete and I Beta tested from the beginning early 2011 as I was a Prevx user and Webroot acquired Prevx in Nov 2010 and WSA is based on Prevx Full Cloud Technology I have not seen a FP in over a year as they keep tweaking the Heuristics and Behavioural Analysis in the Cloud there's nothing lighter 3 to 6MB of RAM 725kb client download with 5 to 6MB on the Disk if you have WSA-Complete as it has a Webroot re-branded lastpast password management toolbar and Back Up & Sync and scans in minutes mine scans in 30 seconds as it only scans where possible threats can hide no need to scan the whole system but you can if wanted it's strength is on execution I would like to invite anyone to give WSA a 2 week trial and it will speak for itself IMHO. AntiVirus Free Trial - Free Malware Scan | Webroot Here is a video if WSA misses a virus: What Happens if Webroot "Misses" a Virus? - Webroot Community
    Best Regards,
    Daniel
    What's the best Antivirus?-capture21-06-2013-9-22-11-pm-jpg
    AceInfinity says thanks for this.
    Triple Helix
    Microsoft® Windows Insider MVP - Windows Security
  5. #65
    Join Date
    Feb 2012
    Canada
    Quote Originally Posted by Triple Helix View Post
    Best Regards,
    Daniel
    It's a cool concept, but how well it works remains unseen just by that one video; that C++ code is very bad, and this is why I don't have full trust in that AV yet without having done further research about WebRoot. That is a high level function call, not a low level keyboard hook for starters. And there may even be a way to bypass that firewall feature as well from disallowing certain information to be sent out. Depending on the methods being used there, one may try to encrypt the data to have it sent, and maybe inject it into an already running process to carry out the action to make it less suspicious; IE or Firefox for instance. The only hope there would be that webroot detects this activity and stops it before it's executed.
    Okay, in sum though, viruses are hardly that simple anymore, they are much more complex. That kind of C++ code may have been used for a REAL keylogger in which was undetected some years ago, but I could write a program to prevent that compiled C++ binary from doing any harm to a person's PC and perhaps many beginner programmers as well to put things into perspective.
    If this WebRoot allows things to be sent that it deems are okay, over HTTP(S) then their programmers are making the assumption that the keys that were possibly recorded by the protected programs (by configuration), don't reveal the original text. The very first rule in programming for security is that you never make assumptions.
    For instance, I wouldn't let a known criminal into my house even if I thought he couldn't do any harm because his gun was taken away or he doesn't have a gun, I would make sure I never let him into my house in the first place. In relation to WebRoot here, allowing this "criminal" into the house, he could still steal stuff, even if our initial worry was solved (not to be harmed), among many other things. And because he doesn't have a gun still doesn't make him dangerous. Thus it's better to stop at the source (the front door to the house in this case), than to assume, and possibly find out the hard way later. By not allowing this criminal into your house, you're automatically protecting yourself against many other bad situations as possibilities. This is the way all good AV's work.
    To me, the false positives rating given to WebRoot from that report however, tells me that WebRoot has ineffective, or inefficient ways of checking a file for a malicious signature. So although it uses other methods (that may work, I don't know), it's lacking in other areas.
    BEFORE, I eliminate the possibility of WebRoot being a good AV though, I may, or would like to test for myself for my own curiosity though to see how effective it is on detection and prevention. So I'm not saying it's a bad AV, but it still has yet to be proven that it is good. This is 100% speculation, but remains to be proven or disproven.
    Triple Helix says thanks for this.
  6. #66
    Join Date
    Feb 2013
    Ontario, Canada
      • Manufacturer:
        Alienware
      • Model Number:
        Alienware 17R5 2018
      • Motherboard:
        Alienware
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
        Laptop
      • Cooling:
      • Display:
      • Operating System:
        Windows 10 Pro x64
    That's all I ask give it a try, also the Cloud consists of 50+ of Terabytes of information in it's Intelligence Network "A new malware protection approach is desperately needed." Real-Time Malware Protection ? Webroot Intelligence Network | Webroot®
    And let us know here is the Online Help File: https://detail.webrootanywhere.com/a...?n=OpeningPage
    TIA,
    Daniel
    Triple Helix
  7. #67
    saint_satin_stain's Avatar
    Join Date
    Jul 2013
    Huntsville, Alabama
    Age
    75
    The best three now: Webroot, BitDefender, and Norton. I use, along with family, Webroot SecureAnywhere Complete; it progects several family desktops and smart phones and tablets. Read the PCMag.com reviews.
    saint satin stain
    Responsible for what I say,
    not for what you understand.
  8. #68
    Deek's Avatar
    Join Date
    Apr 2013
    Sacramento, Ca
    I prefer Avast right now...but it changes over time...always keep Malwarebytes Free and Eset online scanner around as well. One scanner will not do it all.
    Come on, give me a hard one! I can fix anything ;-)
  9. #69
    Deek's Avatar
    Join Date
    Apr 2013
    Sacramento, Ca
    Quote Originally Posted by AceInfinity View Post
    You missed the "False Postive" part from Will Watts...Eset seems to do better at picking up Java related issue better then anything....Malwarebytes seems best for PUP's and Malware, and Avast is the least troublesome as long as you do a custom install and get rid of all the junk they package with it.
  10. #70
    Deek's Avatar
    Join Date
    Apr 2013
    Sacramento, Ca
    FYI, a new record was just achieved over here....Malwarebytes dected 75,674 items on a client PC....That shatters the prevfcious record of 37,000ish items
  11. #71
    Corrine's Avatar
    Join Date
    Feb 2012
    Upstate, NY
    Quote Originally Posted by Deek View Post
    ...Avast is the least troublesome as long as you do a custom install and get rid of all the junk they package with it.
    As long as you don't need help from the Avast forums -- still down: avast! blog » AVAST forum offline due to attack
    If you or someone at your company use Twitter, they love seeing records like that. https://twitter.com/Malwarebytes
  12. #72
    Will Watts's Avatar
    Join Date
    Mar 2012
    %tmp%
      • Manufacturer:
        Alienware M15x
      • Model Number:
        M15x
      • CPU:
        i5 520 M @ 2.40GHz
      • Memory:
        8GB
      • Graphics:
        ATI Radeon HD 5800
      • Hard Drives:
        720GB 7200 rpm
      • Operating System:
        Windows 8 + Ubuntu
    I've been finding myself more and more frustrated with some of the MBAM detections, especially some of the website blocking. That feature finds itself fairly regularly disabled at this point. Not sure why, possibly just been unlucky with false positives, but it's frustrating having to work out why a program has stopped working only to realise it was MBAM.
  13. #73
    Corrine's Avatar
    Join Date
    Feb 2012
    Upstate, NY
    Malwarebytes has a forum to report False Positives -- both website and file detections.
Similar Threads
  1. 13 Best Free Antivirus Programs
    By JMH in forum Security News
    Last Post: 04-19-2013, 06:57 PM
  2. [SOLVED] Driver IRQL not less or equal Windows 7 - CA Antivirus
    By RibDigger870 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-02-2013, 02:04 PM
  3. Antivirus on Windows 8: Looking at Your Options
    By JMH in forum Microsoft News
    Last Post: 07-26-2012, 01:01 AM
  4. Replies: 2
    Last Post: 06-27-2012, 06:17 PM
  5. Does Malwarebytes replace antivirus software?
    By JMH in forum News You Can Use
    Last Post: 05-14-2012, 08:27 PM
Log in
Log in
