Hello everyone,
I hope all of you had a Happy Christmas and may I wish you all a Happy New Year.
I have five hard drives on my PC. One (the C drive) is an SSD.
I find that both the C drive and my D drive (a 2Tb conventional HDD) are marked as system drives.
This was not a particular problem until today I came to do a Windows Image Backup.
Windows insists (quite rightly I am sure) in wanting to backup both the C and D drives as they are marked as system drives, but the backup drive does not have the space to accommodate both so I thought I would un-mark the D drive (which has only one partition) as a system drive. Easier said than done! After some deliberation, I decided that the thing to do was to make the partition on the D drive "inactive" and to see what result that had.
Much to my surprise (and grief) having done so I found that the PC would not boot up saying that there was no MBR!
Fortunately, using the Windows 10 repair disk, I was able to undo the change that I had made and make the D drive "active" again.
The thing is why didn't the PC boot from the C drive which is marked as the Boot drive and contains the operating system? The PC normally boots up in 43 secs which I presume indicates that it is booting from the SSD.
I don't know if making the D drive's single partition inactive, made it invisible to the PC. I am still faced with the problem that the D drive is marked as a system drive. Can I make it a "non-system drive and if so what would be the consequences as the PC appears to be relying on the D drive to boot up?
Thanks for any help,
Regards,
Jim
