Page 2 of 2 First 12
  1. #21
    Join Date
    May 2015
    Kent, SE England
    Re: Two System disks (and how can I have only one!)
    Ok, Thanks I have the D drive backed up in a system image so presumably if I tried to restore from there it will simply restore the MBR as well. So, I guess I will need to make a file back up from the current D drive then wipe it and then restore the files etc.
    I should also be able to, if I wish, phyisically remove the D rive and then repair the MBR on the SSD C drive.
    Is this correct,
    Thanks & regards
    Jim
    • Ad Bot
      advertising
      Beep.
  2. #22
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Yes if you disconnect the drive that's another way to repair the MBR but remember if you put iit back Windows will probaboy try to boot from it again which
    is why I want you to "zero" it out.
  3. #23
    Join Date
    May 2015
    Kent, SE England
    If I make the c drive number one in the boot priority, the PC will not boot and so I should then be able to effect a MBR rebuild/repair to the C drive using my windows repair disk. This should save me having to disconnect anything! If it doesn't work I will remove the D drive.
    I have already copied all the D folders that I need to another drive.
    If the repair to the c drive is successful and the PC boots up, I will wipe/reformat the D drive and then reload it from the back up I have made.
    Hopefully, that will do the trick!
    Thanks & Regards
    Jim
  4. #24
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Yes that should work remember to use:
    Restore, Fix, Repair Master Boot Record (MBR) in Windows
    Please use a low level format like suggested to format the "D" drive though so you take everything off it.
  5. #25
    Join Date
    May 2015
    Kent, SE England
    Much obliged. I will let you know how I get on.
    Thanks again & Regards
    Jim
  6. #26
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Take your time....
  7. #27
    Join Date
    May 2015
    Kent, SE England
    It seems that everything is getting back to normal:
    It wasn't quite as easy as I thought as I do not have a windows 10 installation disk - I upgraded from 8.1 online via an .iso file (which, I suppose I could have used to burn an installation disk!) However I had generated a Windows "10" repair disk.
    The options I was given when, after making the D drive inactive, I booted from the repair disk, were not quite what I expected. For example there was no mention of Windows 10 rather references to windows 7 and 8.1, my previous O/Ss.
    Fortunately I had done some research and had some instructions for tackling the problem in various ways.
    What I did was to get into the command prompt and use the command: Bootrec /RebuildBcd
    I then rebooted the PC and, much to my disgust, it would not boot from the C drive! So I reinserted the repair disk and, much to my surprise, on going to "Startup Repair" it then recognised that my o/s was Windows 10 and allowed me to boot from the C drive without any further problems.
    The PC took about 6 hours to completely wipe the D drive and I am currently restoring all the data that I had backed up yesterday to it. I have every reason to believe that all will be ok when completed.
    The problem with the repair disk may have been that it was generated with the system when the MBR was wrongly on the D drive, which had previously housed Windows 7 and Windows 8.1. In any event I shall generate a new Startup/Repair disk.
    I am very grateful for the help received.
    Kindest Regards
    Jim
  8. #28
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Glad to help and glad you got it sorted. But you do not need a Windows 7 disk to install it simply use the Media Creator too (most recent is Fall Creator Update) at this site to install Windows 10 and the key should not be necessary as the bios saves the coa from earlier installs. Use "Download Tool Now" to make the disk.
    Download Windows 10
  9. #29
    Join Date
    May 2015
    Kent, SE England
    Thanks Rich-M,
    Just to check that if I click on the Fall Creators executable file, from your link, this will upgrade my W10 o/s to the latest version.
    Thanks,
    Jim
  10. #30
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Yes that is correct.
  11. #31
    Join Date
    May 2015
    Kent, SE England
    Thank you :-)
  12. #32
    Rich-M's Avatar
    Join Date
    Jun 2012
    NE Pa, USA
    Glad to help.
Similar Threads
  1. Windows System Restore - Restore your System (Windows 10, 8.1, 8, 7 & Vista)
    By jcgriff2 in forum Windows 7 | Windows Vista Tutorials
    Last Post: 08-18-2018, 12:29 AM
  2. Replies: 2
  3. 8 Floppy Disks - Mortal Kombat Music
    By AceInfinity in forum The Lounge
    Last Post: 04-18-2015, 02:17 PM
  4. Replies: 5
    Last Post: 07-03-2013, 06:11 AM
Log in
Log in
