1. #1
    Corrine's Avatar
    Join Date
    Feb 2012
    Upstate, NY
    Adobe Flash Player Out-of-Band Critical Security Update
    Adobe has released Version 27.0.0.170 of Adobe Flash Player for Microsoft Windows, Macintosh, Chrome and Linux.
    The critical update addresses a report that an exploit for CVE-2017-11292 exists in the wild, and is being used in limited, targeted attacks against users running Windows.
    Update:
    *Important Note: Downloading the update from the Adobe Flash Player Download Center link includes a pre-checked option to install unnecessary extras, such as McAfee Scan Plus or Google Drive. If you use the download center, uncheck any unnecessary extras that you do not want. They are not needed for the Flash Player update.
    • Ad Bot
      advertising
      Beep.
  2. #2
    Digerati's Avatar
    Join Date
    Aug 2012
    Nebraska, USA
    • specs System Specs
      • Manufacturer:
        BrightWorks Systems
      • Model Number:
        BWS-6 E-IV
      • Motherboard:
        Gigabyte GA-Z170-HD3
      • CPU:
        Intel Core i5-6600 Skylake Pushed to 3.9GHz
      • Memory:
        2 X 8GB Corsair Vengeance DDR4 3000
      • Graphics:
        EVGA GeForce GTX 1050TI 04G-P4-6251-KR, 4GB GDDR5
      • Sound Card:
        Integrated
      • Disk Drives:
        Samsung 850 Pro 256GB SSD, 850 EVO 250GB SSD, Blu-ray R/W
      • Power Supply:
        EVGA Supernova 550W Gold
      • Case:
        Fractal Design Define R4 Mid Tower w/Window
      • Cooling:
        2 x 140mm case fans, OEM CPU Cooler
      • Display:
        2 x Samsung S24E650BW 24 inch WS
      • Operating System:
        Windows 10 Pro 64-Bit
    Re: Adobe Flash Player Out-of-Band Critical Security Update
    "Out-of-band"? lol
    Sorry, but with the constant stream of new vulnerabilities and subsequent patches regularly being discovered and released for their products, "out-of-band" seems like an ironic misnomer.
    Bill (AFE7Ret)
    Freedom is NOT Free!
    MS MVP Windows and Devices for IT, 2007 - 2018
    Heat is the bane of all electronics!
  3. #3
    Corrine's Avatar
    Join Date
    Feb 2012
    Upstate, NY
    Microsoft released the Adobe Flash Player 27.0.0.170 Update: ADV170018 | October Flash Security Update.
  4. #4
    Corrine's Avatar
    Join Date
    Feb 2012
    Upstate, NY
    Another Flash Player update has been released, although the update does not include any security fixes. Rather, it is to correct an important functional fix impacting Flex content. If impacted, it is recommend the update be installed. For those who have the option to 'Allow Adobe to install updates', the update will be automatic. Otherwise, use the links in the initial post in this thread. The released Version is 27.0.0.183 of Adobe Flash Player for Microsoft Windows, Macintosh, Chrome and Linux.
    jcgriff2 says thanks for this.
Similar Threads
  1. Adobe Flash Player Out-of-Band Critical Security Update
    By Corrine in forum General Help & Information
    Last Post: 10-27-2016, 02:45 PM
  2. Critical Out-of-Band Adobe Flash Player Update
    Last Post: 04-07-2016, 09:43 AM
  3. Another Out-of-Band Critical Security Update for Adobe Flash Player & AIR
    Last Post: 07-08-2015, 11:19 AM
  4. Out-of-Band Critical Adobe Flash Player Update
    Last Post: 06-23-2015, 02:52 PM
  5. Adobe Flash Player Out of Band Critical Security Update
    Last Post: 11-25-2014, 04:07 PM
Log in
Log in
