1. #1
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
    • specs System Specs
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
        12GB DDR3L SDRAM (2 DIMM)
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    IE Removal for Troubleshooting Purposes
    How do I remove Internet Explorer 8 from Windows as a troubleshooting step?
    - Windows 7/ Server 2008 R2
    - Vista / Server 2008
    - XP / Server 2003
    http://support.microsoft.com/kb/957700
    How do I install or uninstall Internet Explorer 9?
    - Vista SP2/ Server 2008 SP2
    http://windows.microsoft.com/en-US/w...net-explorer-9
    satrow says thanks for this.
    https://www.sysnative.com/
    Thank You!
    Microsoft MVP 2009-2015
    • Ad Bot
      advertising
      Beep.
  2. #2
    Re: IE Removal for Troubleshooting Purposes
    Note these only remove the entry points and some of the "chrome" (UI) binaries and supporting registry trail. Useful if you're suspecting an IE chrome binary or registry trail issue, but if you're tshooting connectivity or actual browsing/rendering issues, this will do nothing. Just FYI.
    MCTS Windows Internals, MCITP Server 2008 EA, MCTS MDT/BDD, MCSE/MCSA Server 2003, Server 2012, Windows 8
  3. #3
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Thank you for the clarification, Carl.
    Thank You!
Similar Threads
  1. Event ID 41 troubleshooting
    By usasma in forum BSOD Kernel Dump Analysis Debugging Information
    Last Post: 04-12-2013, 11:55 AM
  2. [C#] Set Up Project For Testing Purposes
    By AceInfinity in forum Programming
    Last Post: 08-11-2012, 09:14 PM
  3. Troubleshooting Memory Leaks With Just a Dump.
    By JMH in forum BSOD, Crashes, Kernel Debugging
    Last Post: 04-26-2012, 10:31 PM
Log in
Log in
