1. #1
    SNMP Folder
    In several PCs in the network I have found a snmp folder in the directory c:\windows\system32\WEBM. All the clients are Windows XP SP3 profesional. Until I know this folder isnīt installed by default with Windows XP and we don't use snmp. Why are these folders there? Is necessary to install something to have these folders?. These folders are empty.
    Best regards.
    • Ad Bot
      advertising
      Beep.
  2. #2
    x BlueRobot's Avatar
    Join Date
    May 2013
    Minkowski Space
    Re: SNMP Folder
    I would personally keep the files there, they aren't doing any harm, I think they installed default with Windows XP especially since your using the Professional edition.
    About SNMP (Windows)
    Machines Can Think
    We don't make mistakes; we just have happy accidents.
  3. #3
    Join Date
    May 2013
    Minkowski Space
    Re: SNMP Folder
    Have you checked if the files are hidden?
    Machines Can Think
  4. #4
    Re: SNMP Folder
    Hi x BlueRobot,
    Thanks for your answer. I have checked and the folder is empty. I think that this folder is not installed by default because I havenīt seen this in new Windows xp sp3 installations with all the critical and security updates.
    Best Regards.
  5. #5
    Join Date
    May 2013
    Minkowski Space
    Re: SNMP Folder
    Were they Professional editions or Home Editions?
    Machines Can Think
  6. #6
    Re: SNMP Folder
    Best regards
Similar Threads
  1. BSOD Report (with zipped folder)
    By Y2Krisis in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-05-2014, 01:08 AM
  2. [VBScript] AppData Folder Removal Example
    By AoN in forum Programming
    Last Post: 04-21-2013, 01:28 AM
  3. Leftovers in the SysnativeBSODApps folder
    By usasma in forum BSOD Processing Apps Download | Info + Discussion
    Last Post: 03-22-2013, 02:44 PM
  4. WHAT IS IN MY RECOVERY FOLDER IN THE ROOT FOLDER?
    By karlsnooks in forum Windows 8 | Windows RT
    Last Post: 10-20-2012, 05:23 PM
Log in
Log in
