1. #1
    Alienware 17 X R5 - New System - BSOD Problems -
    Hello everyone,
    A friend of mine recommended you guys as a last resource of help in finding the trigger of my BSOD errors.
    The system is still under warranty but I am scared about the lack of knowledge of dell tech support from Eastern Europe ( no offence to anyone ), had problems with other system and took 2 and half months to fix.
    If this will result to be a hardware problem I will go the dell service way but I hope from the bottom of my soul that the final result will be software / drivers related.
    The system is giving random BSOD's since day 3, after I installed couple of random software + windows updates.
    - Imagined I did something wrong, went for a full restore using the recovery hidden partition from dell, same problem.
    - Imagined is OS related, installed windows 7, same problems.
    - Re-installed windows 8, windows 8.1, again 7 and so on, same problem.
    After following guidance from my friends forum I updated the bios to the latest version and also the mSATA firmware.
    MemTest was passed, left it running until the message with "press ESC to exit" appeared ( no errors found ), did all the scan for errors on the drive procedures.
    Did all the hardware test from both windows and bios tools provided by dell ( no errors found ).
    Without the video drivers the system appears to be a little more stable.
    I am willing to do all the necessary steps required to detect the problem, even if it takes a clean install of the OS ( I am used to it ).
     OS - Vista/ Windows 7, Windows 8 ? - Windows 8
    и x86 (32-bit) or x64 ? - X64
    и What was original installed OS on system? - Yes
    и Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? - OEM ( came with system )
    и Age of system (hardware) - 2 months
    и Age of OS installation - have you re-installed the OS? - 4 days
    и CPU - Intel i7 4900MQ
    и Video Card - 1x Intel HD 4600 + 1x Nvidia GTX 780M
    и MotherBoard - Alienware 068R5X
    и Power Supply - brand & wattage (if laptop, skip this one)
    и System Manufacturer - Dell
    и Exact model number (if laptop, check label on bottom) - Alienware 17x R5
    I am using the system right now without the video, killer lan, free fall sensor, and keyboard lights drivers.
    I am afraid that installing either of them will result in BSOD.
    Some of the symptoms:
    I get random BSOD errors, in some cases ( with all the drivers installed ) the nVidia video card is no where to be found, not available in device manager, the nvidia control panel no longer in task bar, acts like the card was physically removed from the system. Rebooting the system does not help, to make the video card show up again, power of and on is needed, this only occurs when all drivers are installed.
    The BSOD are random, most of them while the system is idle. I get 80% of BSOD if I simply browse youtube with no background apps running.
    Requested files:
    files.zip
    • Ad Bot
      advertising
      Beep.
  2. #2
    Wrench97's Avatar
    Join Date
    Feb 2012
    S.E. Pennsylvania
    Re: Alienware 17 X R5 - New System - BSOD Problems -
    8 different named causes out of 13 dump files usually means hardware.
    I do see a couple older VMware drivers on the system you could try updating the vmware install or uninstalling it> VMware Support & Downloads for Desktop, Application & Data Center Virtualization | United States
    VMNET.SYS Sun Jul 8 03:58:34 2012
    What version of memtest did you run Memtest86+ or another?
    D/L Memtest+ run it for at least 6 passes with 32gig of ram that will probably take at least a day.
    2013 Nov 22 05:41:18 AM     98-dbug   Sysnative  BSOD scripts
                             TOTAL DUMP FILES PROCESSED THIS RUN:  13
                             TOTAL DUMP FILES PROCESSED  TO DATE:  549
    Debug session time: Thu Nov 21 19:18:55.513 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112113-7281-01.dmp]
    Built by: 9200.16628.amd64fre.win8_gdr.130531-1504
    System Uptime: 0 days 2:50:57.291
    Probably caused by : ntkrnlmp.exe ( nt!KiExecuteAllDpcs+259 )
    BugCheck A, {fffff880032daa46, 2, 0, fffff80396ea1d69}
    BugCheck Info: IRQL_NOT_LESS_OR_EQUAL (a)
    Bugcheck code 0000000A
    Arguments:
    Arg1: fffff880032daa46, memory referenced
    Arg2: 0000000000000002, IRQL
    Arg3: 0000000000000000, bitfield :
    	bit 0 : value 0 = read operation, 1 = write operation
    	bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
    Arg4: fffff80396ea1d69, address which referenced memory
    BUGCHECK_STR:  AV
    DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
    PROCESS_NAME:  vmware-vmx.exe
    FAILURE_BUCKET_ID:  AV_nt!KiExecuteAllDpcs
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    BiosReleaseDate = 09/11/2013
    SystemManufacturer = Alienware
    SystemProductName = Alienware 17
    ееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееееее``
    Debug session time: Thu Nov 21 16:25:48.071 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112113-9843-01.dmp]
    System Uptime: 0 days 0:26:51.843
    Probably caused by : ntkrnlmp.exe ( nt!KiFatalExceptionHandler+22 )
    BugCheck 1E, {ffffffffc0000005, 0, 8, 0}
    BugCheck Info: KMODE_EXCEPTION_NOT_HANDLED (1e)
    Bugcheck code 0000001E
    Arguments:
    Arg1: ffffffffc0000005, The exception code that was not handled
    Arg2: 0000000000000000, The address that the exception occurred at
    Arg3: 0000000000000008, Parameter 0 of the exception
    Arg4: 0000000000000000, Parameter 1 of the exception
    BUGCHECK_STR:  0x1E
    PROCESS_NAME:  System
    FAILURE_BUCKET_ID:  0x1E_nt!KiFatalExceptionHandler
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Thu Nov 21 15:54:56.283 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112113-11156-01.dmp]
    System Uptime: 0 days 3:18:42.047
    Probably caused by : ntkrnlmp.exe ( nt!IopXxxControlFile+9c8 )
    BugCheck 50, {fffff8802265a940, 0, fffff8012f430a6a, 2}
    BugCheck Info: PAGE_FAULT_IN_NONPAGED_AREA (50)
    Bugcheck code 00000050
    Arguments:
    Arg1: fffff8802265a940, memory referenced.
    Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
    Arg3: fffff8012f430a6a, If non-zero, the instruction address which referenced the bad memory
    	address.
    Arg4: 0000000000000002, (reserved)
    BUGCHECK_STR:  AV
    PROCESS_NAME:  KillerService.
    FAILURE_BUCKET_ID:  AV_nt!IopXxxControlFile
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Thu Nov 21 12:35:54.619 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112113-11578-01.dmp]
    System Uptime: 0 days 1:23:57.396
    Probably caused by : ntkrnlmp.exe ( nt!IopAllocateIrpPrivate+2c )
    BugCheck 3B, {c0000005, fffff803fd50ea7c, fffff8801b052e30, 0}
    BugCheck Info: SYSTEM_SERVICE_EXCEPTION (3b)
    Bugcheck code 0000003B
    Arguments:
    Arg1: 00000000c0000005, Exception code that caused the bugcheck
    Arg2: fffff803fd50ea7c, Address of the instruction which caused the bugcheck
    Arg3: fffff8801b052e30, Address of the context record for the exception that caused the bugcheck
    Arg4: 0000000000000000, zero.
    BUGCHECK_STR:  0x3B
    PROCESS_NAME:  vmnat.exe
    FAILURE_BUCKET_ID:  0x3B_nt!IopAllocateIrpPrivate
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Thu Nov 21 11:11:34.577 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112113-11234-01.dmp]
    System Uptime: 0 days 14:46:17.497
    Probably caused by : ntkrnlmp.exe ( nt!_report_gsfailure+25 )
    BugCheck F7, {20024d998d8, 2a1a4c2b7570, ffffd5e5b3d48a8f, 0}
    BugCheck Info: DRIVER_OVERRAN_STACK_BUFFER (f7)
    Bugcheck code 000000f7
    Arguments:
    Arg1: 0000020024d998d8, Actual security check cookie from the stack
    Arg2: 00002a1a4c2b7570, Expected security check cookie
    Arg3: ffffd5e5b3d48a8f, Complement of the expected security check cookie
    BUGCHECK_STR:  0xF7
    DEFAULT_BUCKET_ID:  GS_FALSE_POSITIVE_MISSING_GSFRAME
    FAILURE_BUCKET_ID:  0xF7_MISSING_GSFRAME_nt!_report_gsfailure
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Wed Nov 20 16:56:39.428 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\112013-7546-01.dmp]
    Built by: 9200.16581.amd64fre.win8_gdr.130410-1505
    System Uptime: 0 days 1:31:03.212
    Probably caused by : ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )
    BugCheck 139, {3, fffff8801c4fb840, fffff8801c4fb798, 0}
    BugCheck Info: KERNEL_SECURITY_CHECK_FAILURE (139)
    Bugcheck code 00000139
    Arguments:
    Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
    Arg2: fffff8801c4fb840, Address of the trap frame for the exception that caused the bugcheck
    Arg3: fffff8801c4fb798, Address of the exception record for the exception that caused the bugcheck
    Arg4: 0000000000000000, Reserved
    BUGCHECK_STR:  0x139
    DEFAULT_BUCKET_ID:  LIST_ENTRY_CORRUPT
    PROCESS_NAME:  chrome.exe
    FAILURE_BUCKET_ID:  0x139_3_nt!KiFastFailDispatch
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 15:37:06.597 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-6843-01.dmp]
    Built by: 9200.16384.amd64fre.win8_rtm.120725-1247
    System Uptime: 0 days 0:10:27.375
    Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+13c00 )
    BugCheck 133, {1, 780, 0, 0}
    BugCheck Info: DPC_WATCHDOG_VIOLATION (133)
    Bugcheck code 00000133
    Arguments:
    Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    	DISPATCH_LEVEL or above. The offending component can usually be
    	identified with a stack trace.
    Arg2: 0000000000000780, The watchdog period.
    BUGCHECK_STR:  0x133
    FAILURE_BUCKET_ID:  0x133_ISR_nt!_??_::FNODOBFM::_string_
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 13:00:01.494 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-5250-01.dmp]
    System Uptime: 0 days 1:06:53.273
    BugCheck 139, {3, fffff880009b96d0, fffff880009b9628, 0}
    Arguments:
    Arg2: fffff880009b96d0, Address of the trap frame for the exception that caused the bugcheck
    Arg3: fffff880009b9628, Address of the exception record for the exception that caused the bugcheck
    BUGCHECK_STR:  0x139
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 11:52:49.751 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-7390-01.dmp]
    System Uptime: 0 days 1:35:49.531
    Probably caused by : ntkrnlmp.exe ( nt!KeUpdateTimeAssist+f2 )
    BugCheck 3D, {fffff88003071e50, 0, 0, fffff8005a12b371}
    BugCheck Info: INTERRUPT_EXCEPTION_NOT_HANDLED (3d)
    Bugcheck code 0000003D
    Arguments:
    Arg1: fffff88003071e50
    Arg4: fffff8005a12b371
    BUGCHECK_STR:  0x3D
    FAILURE_BUCKET_ID:  0x3D_nt!KeUpdateTimeAssist
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 10:16:42.063 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-7218-01.dmp]
    System Uptime: 0 days 0:42:53.680
    Probably caused by : ntkrnlmp.exe ( nt!KiDeferredReadyThread+62 )
    BugCheck 1E, {ffffffffc000001d, fffff802308a65b2, fffff88002e8df00, 2}
    Arguments:
    Arg1: ffffffffc000001d, The exception code that was not handled
    Arg2: fffff802308a65b2, The address that the exception occurred at
    Arg3: fffff88002e8df00, Parameter 0 of the exception
    Arg4: 0000000000000002, Parameter 1 of the exception
    BUGCHECK_STR:  0x1E_c000001d
    FAILURE_BUCKET_ID:  0x1E_c000001d_BAD_IP_nt!KiDeferredReadyThread
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 09:12:12.340 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-9515-01.dmp]
    System Uptime: 0 days 5:37:18.106
    *** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
    BugCheck 139, {3, fffff8801a2aaed0, fffff8801a2aae28, 0}
    Arguments:
    Arg2: fffff8801a2aaed0, Address of the trap frame for the exception that caused the bugcheck
    Arg3: fffff8801a2aae28, Address of the exception record for the exception that caused the bugcheck
    BUGCHECK_STR:  0x139
    PROCESS_NAME:  MsMpEng.exe
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 03:30:22.815 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-7125-01.dmp]
    System Uptime: 0 days 0:27:06.592
    BugCheck 1E, {ffffffffc0000005, fffff802cfd7fcb6, 1, 0}
    Arguments:
    Arg2: fffff802cfd7fcb6, The address that the exception occurred at
    Arg3: 0000000000000001, Parameter 0 of the exception
    BUGCHECK_STR:  0x1E_c0000005_W
    FAILURE_BUCKET_ID:  0x1E_c0000005_W_nt!KiFatalExceptionHandler
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
    Debug session time: Mon Nov 18 03:02:58.655 2013 (UTC - 5:00)
    Loading Dump File [C:\Users\Owner\Bsodapps\SysnativeBSODApps\111813-7156-01.dmp]
    System Uptime: 0 days 0:00:43.431
    Probably caused by : ntkrnlmp.exe ( nt!KiExecuteAllDpcs+1f0 )
    BugCheck A, {ffffc01e70e25558, 2, 0, fffff803ceaf34f0}
    Arguments:
    Arg1: ffffc01e70e25558, memory referenced
    Arg4: fffff803ceaf34f0, address which referenced memory
    BUGCHECK_STR:  AV
    MaxSpeed:     2800
    CurrentSpeed: 2794
    BiosVersion = A05
  3. #3
    Thank you for your reply.
    I did try MemTest86+, will re-run the process and let it overnight.
    I don't think VMWare is the cause because I am getting the same problems with it uninstalled.
    Will post as soon as I will have result from MemTest86+
  4. #4
    Unable to edit my previous post, sorry about double-posting.
    Wanted to ask if we can pin-point this to the specific hardware part causing the errors. I just want to avoid endless service times, also since this is not a 200$ system maybe I can request the system to be exchanged in full with a new one ( don't know if it's possible yet ).
    I will let memtest run tonight and check it out in the morning.
    Is there anything else I can do meantime ?
  5. #5
    Wrench97's Avatar
    Join Date
    Feb 2012
    S.E. Pennsylvania
    Memtest86+ is the starting point to test the memory part of the hardware, the rest gets tougher.
    Do you have a SSD or a Platter hard drive?
  6. #6
    Quote Originally Posted by Wrench97 View Post
    I have both, 1 mSATA Liteonit LMT-256M6M and 1 Hitachi HTS727575A9E364.
    Will have a definite answer in the morning for memtest, the first time I ran it was quite fast 1 hour and 30 minutes or so and received the message: *** Pass complete, no errors, press Esc to exit ***
    Should I let it do more passes ?
  7. #7
    Wrench97's Avatar
    Join Date
    Feb 2012
    S.E. Pennsylvania
    We usually recommend at least 6 or until you see a error on screen but Memtest86+ appears to have changed with the latest version, it use to just run until you shut it off...........
    It's new so the SSD should not need a firmware update but it's worth checking on the Alienware site to see if there is one.
  8. #8
    Already went and updated the ssd firmware a few days ago, there was an optional update on dell's support page, same goes for bios, they have released 2 bios updates in 3 days.
    I am running the system with 20% of the drivers installed. I got a DPC_WATCHDOG_VIOLATION BSOD a few minutes ago, if needed I can upload the dmp, just let me know.
    I have no video drivers, no sound drivers, no lan drivers, etc etc... This makes the system BSOD once in 2 - 3 days.
    Before the DPC_WATCHDOG_VIOLATION BSOD the system froze for about 30 seconds...
  9. #9
    Wrench97's Avatar
    Join Date
    Feb 2012
    S.E. Pennsylvania
    The freeze would be related since a deferred procedure call(DPC) spent a prolonged time at an interrupt request level (IRQL) of dispatch level or higher.
    I think you need to contact Alienware and have it sent in for warranty repairs or replacement although replacements are seldom offered on the first attempt.
    Do they still offer the onsite repair within 24 hrs?
  10. #10
    I was hoping to pin down the hardware causing the problems before sending it, since it's hardware related the system will 100% end up at dell, but wanted to know the exact cause of the problems to provide it to them for faster servicing.
    I think they are aware of some errors since they released 2 critical bios updates in 3 days.
    I will try with memtest and see what the result will tell.
    Their hardware diagnostics tool is kind of useless since it is doing a surface scan on parts.
    I am afraid of sending the system into dell cause of the long waiting time, I already lost a big amount of money since my work got ruined each time BSOD came up and had to take it up from the beginning.
Similar Threads
  1. Windows 7 - Driver Problems/BSOD
    By Caj109 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 12-20-2012, 03:22 PM
  2. Problems/ Questions about the BSOD dump processing apps?
    By jcgriff2 in forum BSOD Processing Apps Download | Info + Discussion
    Last Post: 08-24-2012, 10:19 AM
  3. More PHP problems =[
    By silverj2k7 in forum Programming
    Last Post: 04-16-2012, 08:06 AM
Log in
Log in
