B Boabyboy Member Joined Mar 3, 2013 Posts 8 May 10, 2013 #1 Hi folks, I have a very unusual problem? I have 3 monitors. I have a Intel 4000 HD GPU with 3 ports on the back of the GPU. 2 Display Ports and 1 VGA. Monitor 1 & 2 connect straight from Display Port to Display Port = No problems. However using Monitor 3 via VGA to VGA is causing the screen to flicker and causing a BSOD to appear at times. I have attached the BSOD dump file for analysis. I am sorry that I cant follow the guidelines suggested on the BSOD forum thread as I am posting this from a Macintosh machine. I don't have a Windows machine in my house to give you the debugger analysis you need. I am doing this on behalf of a friend while I am trying to resolve his problem. It has totally baffled me. Any ideas or assistance would be much appreciated. Attachments WER-39983-0.sysdata copy.txt 194.1 KB · Views: 5
Tekno Venus Senior Administrator, Developer Staff member Joined Jul 21, 2012 Posts 7,199 Location UK May 10, 2013 #2 We are going to need the minidump files as a minimum from the problem machine. Navigate to C:\Windows\Minidump and zip up and attach all the files in that folder to your next post. If you can run the bsod collection app in the posting app on the problem machine, that would be fantastic. Regards, Stephen
Wrench97 Administrator, Hardware Expert Staff member Joined Feb 20, 2012 Posts 3,070 Location S.E. Pennsylvania May 10, 2013 #3 Which motherboard are you using? Or if a OEM PC(Dell,HP, Packard Bell Etc) what brand and model? Not all Intel chipsets support the use of triple monitors in all configurations.> 3rd Generation Intel® Core™ Processors with Intel® HD Graphics 4000/2500 — Configuration 3-Displays FAQ
B Boabyboy Member Joined Mar 3, 2013 Posts 8 May 12, 2013 #4 Stephen, I will try to get the mini dump file you requested. Techno, the machine is a Dell branded desktop machine. I think it is an Optiplex 9010 I think. I would need to get back to you to get the exact model and specifications.
Wrench97 Administrator, Hardware Expert Staff member Joined Feb 20, 2012 Posts 3,070 Location S.E. Pennsylvania May 12, 2013 #5 Are monitors 1 and 2 display port monitors or is there a display port to DVI adapter involved? The Opti 9010 does support 3 monitors providing if adapters are used they are "Active" adapters or of course native display port monitors. I would also suggest(since the PC is new) you contact Dell support as it appears there are several complaints about this around the net.
B Boabyboy Member Joined Mar 3, 2013 Posts 8 May 12, 2013 #6 Hi Folks, Thank you for your replies so far, keep them coming. I have attach the dump file, (I think). Let me know if I have done this correctly. Thank you. Attachments Sysdump.zip 68.7 KB · Views: 3
x BlueRobot Administrator Staff member Joined May 7, 2013 Posts 10,171 Location %systemroot% May 12, 2013 #7 Code: BugCheck 116, {fffffa800427f0a0, fffff88005cf55f0, 0, d} Unable to load image igdkmd64.sys, Win32 error 0n2 *** WARNING: Unable to verify timestamp for igdkmd64.sys *** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys Probably caused by : igdkmd64.sys ( igdkmd64+105f0 ) Code: Usual causes: Video driver, overheating, bad video card, BIOS, Power to card It appears that the graphics driver has entered a hung state and was unable to recover within the allocated time period. Code: 2: kd> lmvm igdkmd64 start end module name fffff880`05ce5000 fffff880`06138200 igdkmd64 T (no symbols) Loaded symbol image file: igdkmd64.sys Image path: igdkmd64.sys Image name: igdkmd64.sys Timestamp: Wed Mar 20 04:25:41 2013 (51493A45) CheckSum: 0045CA50 ImageSize: 00453200 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 The crash primarily blames your Intel Graphics driver, however, this seems to be most up to date version, I believe it's most likely the driver doesn't support three monitors in one setup which may explain may it hung and then was unable to recover. Additionally, I also noticed this: Code: 2: kd> lmvm BHDrvx64 start end module name fffff880`04a97000 fffff880`04bed000 BHDrvx64 T (no symbols) Loaded symbol image file: BHDrvx64.sys Image path: BHDrvx64.sys Image name: BHDrvx64.sys Timestamp: Fri Oct 19 05:40:41 2012 (5080D9C9) CheckSum: 0015564F ImageSize: 00156000 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 This driver belongs to your Symantec Heuristics Driver, Symantec products have be known to cause some NTFS driver problems, either check for any updates from the the Symantec support page, or use the official Symantec Removal Tool and then install these free and proven alternatives: Malwarebytes : Free anti-malware download Microsoft Security Essentials | Protect against viruses, spyware, and other malware Remember to install the free version of Malwarebytes not the free trail; untick the free trial box during installation. MSE is the most lightweight and compatible with the Windows 7 operating system. Code: 2: kd> !sysinfo machineid Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=3174] BiosMajorRelease = 4 BiosMinorRelease = 6 BiosVendor = Dell Inc. BiosVersion = A12 BiosReleaseDate = 01/10/2013 SystemManufacturer = Dell Inc. SystemProductName = OptiPlex 7010 SystemVersion = 01 BaseBoardManufacturer = Dell Inc. BaseBoardProduct = 0V8WGR BaseBoardVersion = A02 As already suggested, I would check if the motherboard and any drivers are compatible with a three monitor setup on the Dell support page.
B Boabyboy Member Joined Mar 3, 2013 Posts 8 May 19, 2013 #8 BlueRobot and to the others who have replied to this thread. A massive thank you. My friend is going to have a look at the problem into more detail. Certainly the BSOD information has helped my friend to further look into the problem. I will report back on the subject but for now the issue has been resolved with the diagnostic information I need from the BSOD. Regards, Boabyboy
